Audi A3 8P: Trailer Light Check Functionality
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post25-02-2019, 19:39    Subject: Audi A3 8P: Trailer Light Check Functionality Quote
Hello everyone,
Can anyone tell me if the trailer light failure control system works for trailers when it's installed by the manufacturer?
"Thank you!"
pretzelman01
Translated on 27-07-2026, 17:07.
vag-driver
Post26-02-2019, 9:23    Subject: Audi A3 8P: Trailer Light Check Functionality Quote
It should be like that. However, this has nothing to do with factory or aftermarket installation, but rather with the control unit of the trailer hitch.
On my 2005 A4 B7, I had a Westfalia hitch installed afterwards. It supported the function you're looking for.
Andreas
brezelmann01
dieselschrauber likes this.
Post27-02-2019, 20:56    Subject: Audi A3 8P: Trailer Light Check Functionality Quote
Problem erkannt! Die Kennzeichenbeleuchtung hat ebenfalls 5W und hängt parallel zur Rückleuchte. Da merkt das Steuergerät und der A3 nix davon, wenn eine der beiden ausfällt. TolThe sausage.
Sure, no problem!
Pretzelman.
Translated on 27-07-2026, 17:08.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Headlight Failure Monitoring FIS A3 8P On-Board Diagnostics (OBD)
No new posts Audi A4 mit MKB-AVG auch ÖL 0W 30 Longlive ?? Diesel Engine Technology
No new posts Climate control motors Audi C4 / BOSCH motor, also later ... Transmission, Chassis, Body & Interior
No new posts Trailer On-Board Diagnostics (OBD)
