Good morning, Herbert.
Thank you for your reply!
Quote: |
Is the 1Y engine a naturally aspirated diesel engine with a swirl chamber?
Yes, that is correct!
Quote: |
The injection system likely consists almost entirely of mechanical components.
"Yes, that's also correct. (Except, I suspect, for the valve for injection start, and the sensors for injection duration)."
Quote: |
Does the poor engine performance occur with "active" EGR when the engine is cold or warm?
It always happens, regardless of whether it's cold or warm.
Tonight, however, I made a significant leap forward in understanding the problem.
The catalytic converter is so degraded that the back pressure in the engine becomes so high that, when the EGR valve opens, it forces most of the exhaust gases back into the intake manifold.
That's why, when the EGR valve is deactivated, the engine runs normally at idle. However, as soon as I reactivate the EGR valve, the engine immediately stalls.
Then, I slightly loosened the exhaust pipe before the catalytic converter, and sure enough:
All problems are gone. Now it also runs smoothly at idle with the EGR valve open. An initial test drive was also completed without any noticeable issues.
(Admittedly, it was pitch black.)
So, we're putting in a new exhaust system now, and then we'll see how it goes.
What, however, is bothering me again:
Quote: |
In the AAZ engine, which is comparable in some respects, the valve only opens above 50°C, under partial load (switch on the ESP), and at an engine speed below 3200 rpm; it closes during sudden acceleration (according to Etzold). This requires a small control unit that can be mounted on a relay socket.
To what extent can I apply this to the 1Y as well?
On my 1Y engine, it's definitely the case that the EGR valve is fully open even when the engine is cold and idling. This means it's not being partially opened, but the EGR valve is 100% open.
I've experienced problems with the EGR system being active before. (Specifically, I've noticed hesitation or rough running at partial throttle.)
Therefore, the breather hose for the EGR system has sometimes been disconnected. (This resolved the issue of engine misfires at partial load).
(...but they could also be early signs of a blocked catheter. I will observe this more closely in the near future.)
Thank you again for your help.
Best regards.
Chris.
