My Passat Variant B6 is equipped with a multifunction steering wheel (see photo: Steering Wheel Passat B6 2009.jpeg), which probably uses the DDP protocol. To use the user profile dialog from the UHV-Premium, I need a steering wheel that uses the BAP protocol (see
/viewtopic.php?t=30593).
A multi-function steering wheel from a Passat B7 with 12 buttons should be compatible with my Passat Variant B6. I hope that despite the two buttons on the back, it is still a 12-button steering wheel (I mean functionally, see photo: Steering Wheel Passat B7.jpg).
The connector for the steering wheel buttons on the steering wheel of the B7 is not compatible with the socket on the airbag module (see image: Steering Wheel Connector B7.jpg).
The connector for the steering wheel buttons has 5 pins, with 4 of them being used.
The locking mechanism on the connector of the airbag module can be reversibly removed (see photo: Connector on the airbag module.jpg). After that, there is
one way to connect it, with the free poles mirrored opposite each other. Only 3 pins are connected.[/url]
Does the airbag module also need to be replaced, and will the connector on the steering column still fit after that?
Is it enough to simply rewire the cables of the steering wheel connector from the B7 model?
"Could anyone provide me with the pinouts for the steering wheel airbag module (Passat B6 2009) and the steering wheel of the Passat B7?"
