A4 1.8T Convertible, engine code BFB, year 2006, error code 16519
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post27-06-2019, 22:07    Subject: A4 1.8T Convertible, engine code BFB, year 2006, error code 16519 Quote
Hello forum members, the Audi mentioned above is displaying the following VCDS error code:
16519 Bank 1 Sensor 1 Heating Circuit P0135 008 - Intermittent electrical fault.
"The coolant temperature sensor has been replaced, and an oil change has been performed. The air filter and spark plugs have also been renewed. The Audi has 182,000 km on the odometer. When accelerating, the engine jerks, and it runs very poorly at idle when the A/C is turned on. My question to the experts is: how can I narrow down the cause of this problem? The exhaust system is leak-free. Can I check the oxygen sensor using VCDS, and if so, how? Or should I first inspect the vacuum hoses?"
I would be very grateful for your help. Have a good evening. Best regards, Wolfgang.
Translated on 10-07-2026, 9:38.
Back to top Profile PM Email
Schmierpfote
Post22-07-2019, 22:46    Subject: A4 1.8T Convertible Quote
Hello, the oxygen sensor was okay, but the crankcase ventilation hose on the oil filter housing was defective.
Translated on 10-07-2026, 9:40.
Post23-07-2019, 17:31    Subject: Re: A4 1.8T Convertible Quote
Schmierpfote wrote:
Hallo, Lambdasonde war OK,KGE Schlauch am Ölfiltergehäuse war defekt.
Schmierpfote
Post23-07-2019, 20:12    Subject: A4 1.8T Quote
Hello Rainer,
"I once took the Audi to a mechanic because the engine was running rough. Audi diagnosed the problem and replaced the ignition coils. However, even after clearing the error codes with VCDS, the engine still ran unevenly. I then replaced the crankcase ventilation hose and valve, and the Audi started running smoothly again. But after two years, the problems returned – this time it was a "lambda sensor" issue. The crankcase ventilation hose near the oil filter housing is not easy to see under the intake manifold. Anyway, it's working now. Have a good evening. Wolfgang."
Translated on 10-07-2026, 9:41.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. ABS Sharan, year 2006, error cannot be fixed Transmission, Chassis, Body & Interior
No new posts TDI Coolant Temp Sensor for Audi Convertible Upload
No new posts Window Switch VW Golf 4 Convertible Transmission, Chassis, Body & Interior
No new posts Audi Cabrio hidden control unit On-Board Diagnostics (OBD)
