AHK Control Unit Coding for Audi Q5 8R
misler11
Post22-10-2019, 7:37    Subject: AHK Control Unit Coding for Audi Q5 8R Quote
Hello everyone.
I installed and coded a trailer hitch on a 2013 Q5.
The following problem has now arisen:
All the functions are present; the trailer is detected (Side Assist deactivates, and the symbol in the MMI changes, and rear parking sensors are disabled). The light is working, and the defective lamp detection is also functioning.
The problem is that as soon as the adaptive cruise control needs to brake, it deactivates and an error is logged in both the ACC and the engine control unit.
The cruise control will not be available again until the vehicle is restarted.
The supplier of the electrical kit (Jäger) insists that the coding is incorrect, but they cannot specify what is wrong with it.
Perhaps someone has time to review the code and check for any errors.
Of course, I am open to receiving any other information regarding the problem.
I have attached the Autoscan results here.
Sure, here's the translation:
"Thank you very much in advance."
Best regards, Marco.
Autoscan Q5.pdf
 File name:  Autoscan Q5.pdf
 File size:  147.56 KB
 Downloaded:  949 times
Post22-10-2019, 16:50    Subject: AHK Control Unit Coding for Audi Q5 8R Quote
Perhaps someone has time to review the code and check for any potential errors?
It doesn't work like that because the probability of someone having the exact same car with the exact same coding as yours is very low.
The error in the distance control system is a secondary error resulting from an entry in the engine control unit, which reports an inappropriate message.
Either the engine control unit is incorrectly programmed (check the programming), or possibly... Post a Screenshot of your available options in VCDS, or your trailer control unit is sending a message that the engine control unit cannot process, even with the correct coding.
misler11
Post23-10-2019, 12:08    Subject: Coding Quote
Hello Rainer,
You're very welcome for the quick response.
I have rechecked the engine control unit, and according to the selection in the long coding help, the trailer hitch is activated.
I've attached pictures of all the available options for your consideration, just to be sure.
Regarding coding, I once received a document for the B8 S4 that clearly showed how each control unit needed to be coded. So, I was wondering if anyone here might have something similar for the Q5.
My suspicion is still that the trailer control module is responsible for the error, but I would appreciate a brief confirmation that you would also confirm that the coding in the engine control unit is correct.
You're welcome.
Marco Isler.
 File size:  101.17 KB
 Viewed:  3736 times
 File size:  101.27 KB
 Viewed:  3023 times
 File size:  101.98 KB
 Viewed:  2948 times
 File size:  104.97 KB
 Viewed:  3025 times
 File size:  110.02 KB
 Viewed:  3355 times
 File size:  107.19 KB
 Viewed:  2916 times
 File size:  107.48 KB
 Viewed:  3140 times
 File size:  101.77 KB
 Viewed:  3032 times
 File size:  104.89 KB
 Viewed:  3197 times
 File size:  103.95 KB
 Viewed:  2998 times
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding for ABS control unit On-Board Diagnostics (OBD)
No new posts ABS control unit coding - custom configuration? On-Board Diagnostics (OBD)
No new posts Seat ABS Control Unit Coding On-Board Diagnostics (OBD)
No new posts ESP Control Unit Coding - Golf 4 4motion TDI (AJM) On-Board Diagnostics (OBD)
