gabor.ruppert
Joined: 11/14/2019 Posts: 2 Karma: +0 / -0 Location: Basel
18-11-2019, 16:39 Subject: Audi S5 8T, 4.2L Manual Transmission, ACC Coding |
I want to retrofit ACC (Adaptive Cruise Control) into my S5. Everything is installed and coded except for the sensor itself.
I received instructions, but unfortunately, the S5 with manual transmission is not documented.
2BA0 is the coding for S4/S5 models with automatic transmission and without a trailer hitch.
The control unit is located at address 13 and has the identifier J428. The coding is a six-digit number with two zeros at the beginning.
I would be very grateful if someone could provide information about the CAUA system, specifically regarding its operation with a manual gear shift.
Sure, here's the translation:
"Thank you in advance!"
Translated on 12-07-2026, 1:50.
Joined: 04/12/2002 Posts: 18121 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
21-11-2019, 23:09 Subject: Audi S5 8T, 4.2L Manual Transmission, ACC Coding |
Just in case someone with a similar configuration to yours can help you, an automatic system scan would be very useful!
Translated on 12-07-2026, 1:51.
Profile PM WWW Garage |
gabor.ruppert
23-11-2019, 15:04 Subject: Solution? |
At first glance, the same encoding seems to work for all S4/S5 models. So far, I haven't encountered any problems. It's possible to switch between modes without issue, and a message appears indicating that the speed is too low.
Code: | Saturday,23,November,2019,07:37:23:38133
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8T29Axxxxxx License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 13 15 16 17 19 36 42 46 52 53 55 56 77
VIN: WAUZZZ8T29Axxxxxx Mileage: 115360km-71681miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAUA) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 J HW: 8T0 907 560
Component: 4.2l V8/4V H10 0004
Revision: 76H10---
Coding: 01140003180F0220
Shop #: WSC 06325 123 12345
VCID: 41DEBE7C5180855F869-8014
No fault code found.
Readiness: 0000 1001
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AH HW: 8K0 907 379 AH
Component: ESP8 quattro H04 0230
Revision: -------- Serial number: --------------
Coding: 110D00
Shop #: WSC 06325 000 00000
VCID: 7F5AF88467F433AFB0D-802A
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BP HW: 8K0 907 064 BP
Component: BCM2 1.1 H90 0247
Revision: 00002001
Coding: 030000
Subsystem 1 - Part No SW: 8T0 959 754 Q HW: 8T0 959 754 Q
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000005389011
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0209000011616009
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001235192
Coding: C80170250F2400001000
VCID: 42DCB17054869E479F3-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AD HW: 8T1 820 043 AD
Component: KLIMA 3 ZONEN H06 0150
Revision: C3000000 Serial number: 01120220091392
Coding: 48020006
VCID: 73B224B45BBC67CFC45-8026
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H24 0253
Revision: 05024001 Serial number: 00000000223287
Coding: 260050914134AF010009000000005D5D0F1C038800010141000000
VCID: 3038EBB8EA2A1CD7797-8064
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 030309 H13 0040
Serial number: SWF09030030611
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10406395
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0090
Serial number: 00000000000203090611
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H09 0080
Serial number: 00000000000000
Coding: 002BA0
Shop #: WSC 12345 123 12345
VCID: 6FBA28C43794432F20D-803A
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1ELPHZ
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C20CF8836E2E8B7D5F-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4463792EM
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4433472FG
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME0F1A4908O
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME151B510CE
Crash sensor for front airbag: driver side:
Serial number: 63732SME77213936.
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME00225604J
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HK700028
Coding: 00001E
Shop #: WSC 06335 123 12345
VCID: 3E24C580207EFAA7FBB-806A
Component: E221 - MFL H02 0003
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 15
Mileage: 115368 km
Time Indication: 0
Date: 2019.11.22
Time: 18:04:45
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 B HW: 8T0 920 931 B
Component: KOMBIINSTR. H32 0224
Revision: 00200000 Serial number: 9D7654239
Coding: 0F0D010007000008000000
VCID: 3634DDA0084E32E723B-8062
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 S HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0101
Revision: HB500049 Serial number: 4900H09430000D
Coding: 000303
VCID: 51FE8E3C81E075DF169-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 1906BD04250209
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001235217
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008518133
Coding: 011C02224000120102
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0117211829
Coding: 011A0680003904400330000000000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008531863
Coding: 011C02224C00120102
VCID: 40D8BB785A8A8C57897-8014
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000327134
Shop #: WSC 00000 000 00000
VCID: 3332E4B41B3C27CF045-8066
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 77AA10A443C40BEFF8D-8022
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 AA HW: 8T1 035 195 AA
Component: Symphony3 H01 0300
Revision: 00000003 Serial number: AUZ5Z4I1084698
Coding: 050004820404850053D9470001
VCID: 76B41DA048CE72E7E3B-8022
2 Faults Found:
02259 - Information Display and Control Head (Front) (J685)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 115358 km
Time Indication: 0
Date: 2019.11.22
Time: 13:14:26
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 115358 km
Time Indication: 0
Date: 2019.11.22
Time: 13:14:29
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 C HW: 8T0 862 335 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005062046
Coding: 0010390
VCID: 3A2CC9903056D687C73-806E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.3V)-----------
Translated on 12-07-2026, 1:52.
23-11-2019, 15:32 Subject: Audi S5 8T, 4.2L Manual Transmission, ACC Coding |
Hello.
Was zeigt der Codierungsassistens für das ACC-Steuergerät eigentlich an? SScreenshots?
