Windshield wipers not working, need advice
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
stolley
Karma: +38 / -1   Thank you, like it!
Post09-10-2019, 13:06    Subject: Windshield wipers not working, need advice Quote
Hello everyone,
Perhaps someone here can help me:
The windshield wipers on my Polo 9N3 stopped working suddenly and without any warning!
Quite annoying with this rainy weather!
Okay, please provide the German text you would like me to translate into English.
1. The fuse in the main fuse box (20A) is okay.
2. Rear wiper works.
3. When the windshield wiper lever is activated, a clicking sound from a relay is only audible when the highest setting is selected.
Can anyone give me a tip on where the problem might lie, or what I can read out using VCDS to get more information?
Best regards, Volker.
vag-driver
Post09-10-2019, 14:37    Subject: Windshield wipers not working, need advice Quote
Is the windshield wiper arm still movable? My initial assumption is that the bushings are stuck, and the motor can no longer drive the linkage.
The best approach is to remove the engine so you can thoroughly inspect it. Otherwise, test the engine's functionality. Finally, the steering column lever could also be the culprit.
Andreas
Post09-10-2019, 14:39    Subject: Windshield wipers not working, need advice Quote
Perhaps you could start with a general scan, and then we can proceed from there. There are quite a few things to consider, from levers to engines.
It is possible that the switch positions can be read out in the BNStg.
Otherwise, a windshield wiper linkage can sometimes become stuck, which may not necessarily trigger an OBD error.
Since I don't know much about polo: possible. Also, there's also a component protection feature that activates due to overload; please consult the user manual for more information.
stolley
Post09-10-2019, 16:25    Subject: Windshield wipers not working, need advice Quote
vag-driver wrote:
Is the windshield wiper linkage still movable? My initial assumption is that the bushings are stuck, and the motor can no longer drive the linkage.
The best approach is to remove the engine so you can thoroughly inspect it. Otherwise, test the engine's functionality. As a last possibility, the steering column lever could be the issue.
Thank you for the tip!
The rod was actually stuck before, but I managed to get it working again.
Now, the engine isn't making a single sound... so I doubt it's the linkage.
stolley
Post09-10-2019, 16:36    Subject: Windshield wipers not working, need advice Quote
matthiasTDI96 wrote:
Perhaps you could start with a car scan and we can see what happens next. There are quite a few things to consider, from levers to engines.
Since I don't know much about polo: possible. Is there also a component protection feature activated due to overload? Please consult the user manual for more information...
I'm currently doing an Autoscan...
Result: No error entries. Only that, occasionally, the voltage of the traction battery is too low.
In control unit 09, within diagnostic data byte 003, I can accurately read the wiper lever setting that is currently selected.
I somehow suspect it's the engine.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post09-10-2019, 19:58    Subject: Windshield wipers not working, need advice Quote
Evening.
If equipped: Roof switch; wipers do not operate when the roof is open.
Sincerely,
vag-driver
Post09-10-2019, 21:27    Subject: Windshield wipers not working, need advice Quote
stolley wrote:
I somehow suspect the engine.
Start in sequence, as I described. That will lead to the goal. I don't expect to find anything useful in the error memory.
Andreas
stolley
Post10-10-2019, 19:12    Subject: Windshield wipers not working, need advice Quote
vag-driver wrote:
Start in sequence, as I described. That will lead to the goal. In the error memory, I don't expect to find anything useful.
I will do that, thank you!
I've already gotten a new engine, just to be on the safe side.
I'll try to tackle it this weekend and then I'll let you know how it goes!
stolley
dieselschrauber likes this.
Post12-10-2019, 21:45    Subject: Windshield wipers not working, need advice Quote
Okay, the engine is working again!
It was probably just a corroded contact.
The pole was definitely easy to move. And after I had disconnected and reconnected the motor several times, there was suddenly power flowing through the line again. I carefully applied contact cleaner to the connector, freshly lubricated the rod, and reassembled everything.
Thank you for your tips!
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, valid until 03/2001, central locking, sin... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Headlight Failure: A4 8D Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP not working On-Board Diagnostics (OBD)
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts Fresh air blowers without function On-Board Diagnostics (OBD)
No new posts Glühstiftheizung ohne Funktion, 1,4 TDI [AMF] Diesel Engine Technology
