Octavia 5E: Unlock Parking Heater Function
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
harzer1
Post17-05-2018, 9:12    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Good day, I need the access code to unlock the auxiliary heater.
Translated on 01-09-2026, 8:46.
Post17-05-2018, 10:04    Subject: Octavia 5E: Unlock Parking Heater Function Quote
We cordially invite you to participate. The requirement for posting in diagnosis-related topics (everything for which a vehicle diagnostic system is needed) is...Dieselschrauber customers receive enhanced support (expert assistance) and full access.
Edit: Okay, the name seemed familiar, I checked, and it's a customer. icon_biggrin.gif
Please ensure that the email address used for the customer account in the shop is the same as the email address used for the forum registration; this will automatically enable customer recognition. icon_idea.gif
Nevertheless: It is always most sensible to start with a vehicle scan, because then you know which vehicle and which control units are involved. icon_idea.gif
Unlocking the auxiliary heater:
Any potential errors should, of course, be corrected.
Translated on 01-09-2026, 8:48.
harzer1
Post17-05-2018, 10:31    Subject: SEO: Best Practices for Ranking Higher on Google Quote
Among the adjustments, I only found channels with IDE..., MAS..., and ENG... labels. The "circulator pump lock" channel already has a value of 1 stored.
Translated on 01-09-2026, 8:51.
Post17-05-2018, 10:59    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Then just make it a 0 and then change it back to a 1.
Further posts without the automatic scan feature will be useless.
harzer1
Post18-05-2018, 8:20    Subject: Car Scan: Diagnose und FehlerprĂŒfung Quote
Friday, May 18, 2018, 08:12:15:05205
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x64.
VCDS Version: DRV 18.2.1.0
Data as of: 20180313 DS287.1
https://shop.dieselschrauber.org/en
Vehicle Identification Number: TMBLJ7NE0H0049007 License plate:
Vehicle type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 42 44 52 5F 69
Mileage: 30,212 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-inch heater -- Status: Error 0010.
19-Diagnosis interface -- Status: OK 0000.
22-All-wheel drive -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
69 followers -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CRMB)
Label file: .DRV\04L-907-309-V1.clb
Part number SW: 04L 906 026 BQ, HW: 04L 907 309 R.
Part: R4 2.0L EDC H23 1199
Revision: B5H23---
Encoding: 0119001A043601090000
Operating number: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906026BQ 002002
ROD: EV_ECM20TDI01104L906026BN_002.rod
VCID: 7AFE51AFFDCB0C946F-802E
No error codes found.
Readiness: 0 0 0 0 1 0
Address 03: Brake Electronics (J104)
Label file: | 5Q0-907-379-ESP-V1.clb
Part number SW: 5Q0 614 517 AF, HW: 5Q0 614 517 AF.
Component: ESC H62 0398
Revision: 00000000 Serial Number: 51846000001237
Encoding: 1B076291242409754077470041CA29D846249002E282947200630070C00903
Operating number: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
VCID: 75E44293D4D563EC02-8020
Address 08: Climate Control/Heating Unit (J255)
Label file: | DRV\5G0-907-044.clb
Part number SW: 5E0 907 044 AE, HW: 5E0 907 044 AE.
Component: Climatronic
Part number: H04 1601
Revision: 00001K07
Encoding: 02010104004111011005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 006142
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 68DA1BE793678E0489-803C
Control unit for the fresh air blower (front).
Refrigerant pressure and refrigerant temperature sensors:
Air quality sensor:
Address 09: Central Electronics (J519)
Label file: | 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 086 AK, Hardware: 5Q0 937 086 AK.
Part: BCM PQ37BOSCH 028 0162
Revision: -------- Serial Number: 8658150716001H
Encoding: 0C020846424702FB47E04000000C07080400000000000000000000000000
Operating number: WSC 73430 790 00000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 03002C4B8A014D5C3C-8056
Wiper motor control unit:
Subsystem 1 - Part number SW: 5E1 955 119 HW: 5E1 955 119 Label file: DRV\5QX-955-119-V1.CLB
Component: WWS371 160716 041 0570
Serial number: 160722192051
Encoding: 065DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 B HW: 5Q0 955 547 B Label file: DRV\5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M07D26H01M18S44.
Encoding: 00885D
Humidity sensor: indoor:
Address 10: Parking Assist 2 (J446) Label file: | DRV\5Q0-919-283.clb
Part number SW: 5Q0 919 283 F, HW: 5Q0 919 283 F.
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial Number: 39231621201904
Encoding: 0001050101
ASAM Dataset: EV_EPHVA14AU3700000 002024
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3C7297B7B77FF2A43D-8068
Address 15: Airbag (J234) Label file: | DRV\5Q0-959-655.clb
Part number SW: 3Q0 959 655 AS, Hardware: 3Q0 959 655 AS.
Part: VW20 Airbag, Part Number: 013 0200.
Revision: -------- Serial Number: 003SQPEXV6XR
Encoding: 98CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F28107BD649393CA8-805A
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 454 002 107 16
Component: SideSensor_Df 008 0887
Serial number: 3576U00000087B8D5C1U
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 454 001 507 16
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000A61243C15.
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: ----------- HW: 454 801 707 16
Component: SideSensor_Dr 301 0148
Serial number: 3516RCC4AB50B000000L
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 454 801 107 16
Component: SideSensor_Pr 301 0148
Serial number: 3526R9A35B10B0000007
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 454 801 007 16
Component: FrontSensor_D, Part Number: 304 0149.
Serial number: 3556V40724E0B0000006.
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527)
Label file: | DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 GD, HW: 5Q0 953 549 F.
Bauteil: Lenks. Module 003 0140.
Revision: -------- Serial Number: 05081604400437
Encoding: 1400
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7EF65DBFE1E320B453-802A
Address 17: Control panel module (J285)
Label file: | DRV\5G0-920-XXX-17.clb-SRI3
Part number SW: 5E0 920 749 C, HW: 5E0 920 749 C.
Part: KOMBI 205 8311
Encoding: 07A40801A1800008010C2A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 2C52A7F7471F6224AD-8078
Address 18: Auxiliary Heater (J364)
Label file: | DRV\5Q0-963-272.clb
Part number SW: 5Q0 963 272 G. Hardware number: 5Q0 963 272 G.
Component: STH-MQB 008 0075
Encoding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3A7E91AFBD4BCC942F-806E
Remote control for the auxiliary heater.
Subsystem 1 - Part number SW: 3Q0 963 513, HW: 3Q0 963 513.
Component: R64 D208L 004 0401
Serial number: 00000000000000085376
3 error codes found:
0056 - No flame formation.
B1389 F0 [009] - initial start.
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 3
Error frequency: 1.
Lost Count: 34
Mileage: 9311 km
Date: 2017.05.09
Time: 18:04:20
Auxiliary heater: Operating status: Starting.
74
Coolant temperature of the auxiliary heater: 51 °C.
Coolant temperature: 57 °C
Motor running status: not recognized.
Fuel capacity: 30 liters.
Heating power: 5000 W
0002 - no flame formation.
B1389 F1 [009] - restart after initial run.
Error priority: 3
Error frequency: 1.
Lost Count: 34
Mileage: 9311 km
Date: 2017.05.09
Time: 18:06:21
Auxiliary heater: Operating status: Afterglow - Overheating.
92
Coolant temperature of the auxiliary heater: 46 °C.
Coolant temperature: 49 °C.
0135 - Heater locked.
B138F 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Error priority: 2
Error frequency: 1.
Lost Count: 169
Mileage: 11,505 km
Date: 2017.06.23
Time: 06:41:47
92
Coolant temperature of the auxiliary heater: 22 °C.
Coolant temperature: 21 °C
Fuel level: 17 liters.
Heating power: 0 W
Address 19: Diagnostic Interface (J533)
Label file: | DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AL, HW: 5Q0 907 530 E.
Component: GW MQB Mid, Part Number: 127 1265.
Revision: -------- Serial Number: 0005160257
Encoding: 030100345F087300EB000248080F000100010500000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013_VW37.rod
VCID: 7BF054ABF2F1359C74-802E
Generator:
Control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 3V0 919 719 A, HW: 3V0 919 719 A.
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D0863190716
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001607292937.
Address 22: All-wheel drive (J492) Label file: * DRV\0CQ-907-554.clb
Part number SW: 0CQ 907 554 H, HW: 0CQ 525 130.
Part: Haldex 4Motion H52 7083
Serial number: HA1-00022.06.16.
Encoding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4A9EC16FEDAB5C14BF-801E
Address 42: Door Electric Driver (J386) Label file: |5QX-959-X93-42.clb
Part number SW: 5Q4 959 393 E. Part number HW: 5Q4 959 393 B.
Component: TSG FS 010 0031
Serial number: 0000211528835
Encoding: 001001208000040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4584F253C4B5B36C52-8010
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q0 959 811 A, HW: 5Q0 959 811 A, Label file: DRV\5QX-959-81X-V1.CLB.
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000010913514
Encoding: 010200
Address 44: Steering Assist (J500)
Label file: | DRV\5Q0-909-144.clb
Part number SW: 5Q0 909 144 T, HW: 5Q0 909 144 R.
Part number: EPS_MQB_ZFLS 129 1072
Encoding: 0107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Address 52: Power door lock, front passenger side (J387) Label file: | 5QX-959-X92-52.clb
Part number SW: 5Q4 959 392 E, HW: 5Q4 959 392 B.
Component: TSG BFS 010 0031
Serial number: 0000211698718
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4482EF57CF8F8A6445-8010
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q0 959 812 A, HW: 5Q0 959 812 A, Label file: DRV\5QX-959-81X-V1.CLB.
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000010813830
Encoding: 190200
Address 5F: Information Selection. I (J794) Label file: * None.
Part number SW: 5E0 035 871 B. Hardware: 5E0 035 871 B.
Component: MU-E--ER 050 7060
Serial number: 09061600012555
Encoding: 03734200FF00000011110001000002232F0000C40000810000
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 24424FD72FCFAA6465-8070
Address 69: Trailer (J345) Label file: | DRV\5Q0-907-383.clb
Part number SW: 5Q0 907 383 J, HW: 5Q0 907 383 B.
Part: Trailer H21 0204
Revision: 8C001003 Serial Number: 0411917980
Encoding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 3E769DBFA163E0B413-806A
End----------------------------(Duration: 04:0icon_cool.gif-----------
I am unable to change the value from 1 to 0 because I do not have the necessary access permissions.
Translated on 01-09-2026, 9:32.
harzer1
Post18-05-2018, 9:54    Subject: Octavia 5E: Unlock Parking Heater Function Quote
I am unable to change the value from 1 to 0 because I do not have the necessary access permissions for the code.
Post18-05-2018, 10:36    Subject: Octavia 5E: Unlock Parking Heater Function Quote
First, clear all the error codes in the auxiliary heater, unlock it, and attempt to start it. Then, you can see what errors reappear.
harzer1
Post18-05-2018, 11:22    Subject: Octavia 5E: Unlock Parking Heater Function Quote
The deletion of the parking heater error codes is being denied.
I've also used it with my other testers, including Bosch and Snap-on.
The change is located under "Adjustments / Circulation Pump Lock".
The request to change the value from 1 to 0 was also denied due to insufficient access rights.
Translated on 01-09-2026, 9:33.
Post18-05-2018, 11:45    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Please post a Screenshot of the control unit information from the auxiliary heating control unit.
Translated on 01-09-2026, 9:34.
harzer1
Post18-05-2018, 12:26    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Okay, please provide the German text you want me to translate. I will then provide the English translation.
 File size:  1.91 MB
 Viewed:  1354 times
Post18-05-2018, 12:41    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Have you already clicked "YES" in the dialog box?
harzer1
Post18-05-2018, 12:49    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Yes, I have. Then a window pops up that says "Access permission required," and the only option is to click "OK," which then brings you back to the starting point.
Post18-05-2018, 17:33    Subject: Octavia 5E: Unlock Parking Heater Function Quote
If you call the "Security Access 16" function and hover the mouse cursor over the input field, does a tooltip appear?
Translated on 01-09-2026, 9:35.
harzer1
Post18-05-2018, 18:05    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Okay, so if I click on "Point 16: Access Permissions," this window opens. Nothing opens automatically just by hovering the mouse cursor over it.
 File size:  1.5 MB
 Viewed:  660 times
Post18-05-2018, 18:24    Subject: Octavia 5E: Unlock Parking Heater Function Quote
The mouse cursor in the image is not positioned over the input field.
harzer1
Post18-05-2018, 19:16    Subject: Octavia 5E: Unlock Parking Heater Function Quote
Yes, okay. But I already did that.
It just looks bad in this photo.
Translated on 01-09-2026, 9:36.
No new posts Unlock Vehicle Diagnostic Protection (SFD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Transmission, Chassis, Body & Interior
No new posts Log BKD Octavia 2.0 TDI Upload
No new posts Octavia Control Unit: Buy Online Now! On-Board Diagnostics (OBD)
No new posts Octavia 1U 1.8T power fluctuation Gasoline Engine Technology
