Can I retrofit a Ford Focus Ghia TDCi with a new onboard computer?
Varianti
Post18-06-2003, 10:25    Subject: Can I retrofit a Ford Focus Ghia TDCi with a new onboard computer? Quote
The BC (presumably a 'Black Box' or 'Event Data Recorder') is standardly fitted on a 'Focus Ghia exclusiv' model. However, I have a standard 'Ghia' model and it's not present. Does anyone know if it's possible to simply retrofit this BC by plugging it in (similar to how it's possible with, for example, the Golf III TDI)? The probability is quite high that all the cables are already in place. Must I consider something else?
The car is from the year 2003.
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Ford Focus 1.8 TD timing belt replacement Diesel Engine Technology
No new posts 1.6 PSA Diesel in the 2005 Ford Focus Diesel Engine Technology
No new posts Audi A4 8E: Retrofit GRA & Onboard Computer On-Board Diagnostics (OBD)
No new posts Metallisches Quietschen Ford Focus 90PS TD, 2002 Diesel Engine Technology
