VCDS Interface for 24V systems
vwSchrauber
Post09-04-2020, 8:50    Subject: VCDS Interface for 24V systems Quote
Is it actually possible to read engine error codes from commercial vehicles via OBD2 using common VCDS interfaces? "After all, there are 24V present at the B+ terminal."
Post09-04-2020, 22:17    Subject: VCDS Interface for 24V systems Quote
"It doesn't fit; the OBD-2 connector is different: the ridge in the middle has a slot." Putting it away is so impossible. icon_wink.gif
 24V OBD2 Stecker
 File size:  127.46 KB
 Viewed:  655 times
vwSchrauber
Post10-04-2020, 10:44    Subject: VCDS Interface for 24V systems Quote
Thank you very much!
Ideally, I would have connected terminals 30 and 31, as well as CAN L+H, to the interface using stranded wire and individual pin connectors. Regarding OBD access on a Doosan dump truck (Scania DC13, Euro3).
Luckily, I didn't do it icon_lol.gif.
Post10-04-2020, 12:55    Subject: VCDS Interface for 24V systems Quote
I suspect that device doesn't support OBD2. If so, the CAN High/Low and ground should connect to the RKS+CAN interface, which is also powered from the USB port.
vwSchrauber
Post11-04-2020, 11:32    Subject: VCDS Interface for 24V systems Quote
I suspect that part cannot support OBD2
Don't be fooled by that! I've been surprised more than once to find that certain (industrial) engines were compatible with OBD, even if the parameters that could be read were very limited.
If that's the case, the CAN H/L and ground should connect to the RKS+CAN interface, and the latter is also powered from the USB port.
That is brilliant icon_smile_thumb_up.gif icon_smile_thumb_up.gif icon_smile_thumb_up.gif.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Announcements: VCDS-Mobile®, HEX-NET® Interface On-Board Diagnostics (OBD)
No new posts VCDS Interface Hardware: Different Versions? On-Board Diagnostics (OBD)
No new posts Status LEDs on the VCDS interface and their colors On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
