I'm having a problem with my Golf 6 2.0 TDI. The instrument cluster is staying dark, and the car starts briefly due to the immobilizer but then shuts off again. I haven't done anything else yet. The fuses are okay, and both KL15 and KL50 relays are working. I'll probably have to remove it in the next few days. I've already obtained the wiring diagram, so hopefully it's just a power supply issue. Is it possible to replace the control unit from the dashboard without any problems? Here's the
Autoscan I'm attaching.
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: Error 0010.
03-Brake electronics -- Status: Error 0010.
04-Steering angle sensor -- Status: Intermittent communication error 1000.
08-Climate/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: Error 0010.
16-inch wheel electronics -- Status: Error 0010.
17-Terminal block -- Status: unreachable 1100
19-Diagnostic interface -- Status: Error 0010.
Immobilizer -- Status: unreachable 1100.
42-door electric. Driver -- Status: Error 0010.
44-Steering Assist -- Status: Error 1010.
46-Comfort System -- Status: OK 0000
52-door electric. Co-driver. -- Status: Error 0010.
56-Radio -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000.
72-Door, electric, high, right side -- Status: OK 0000.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (ECM) Label file: DRV\03L-906-022-CBA.clb
Part number SW: 03L 906 022 AH, HW: 03L 906 022 G.
Part: R4 2.0l TDI G000AG 9979
Revision: 13H01--- Serial number:
Encoding: 0000078
Operating number: WSC 49157 002 1048576
VCID: 6BD20A394A33E8175C-803E
2 error codes found:
049493 - Control unit for switch panel installation.
U0155 - 000 - No communication.
Environmental conditions:
Error status: 01100000
Error priority: 6
Error frequency: 17
Lost Counter: 255
Mileage: 0 km
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Temperature: 5.4°C
Voltage: 11.86 V
Binary value: 00000000
Torque: 93.0 Nm
Temperature: 12.6°C
001299 - Incorrect immobilizer code.
P0513 - 000 -
Error priority: 2
Error frequency: 1
Lost Counter: 255
Mileage: 0 km
Time: 0
Speed: 1012 RPM.
Speed: 0.0 km/h
Voltage: 11.32 V
Pressure: 989.4 mbar
Pressure: 958.8 mbar
Temperature: 5.4°C
Temperature: 12.6°C
Readiness: 0 0 0 0 1
Address 02: Transmission Label file: DRV\02E-927-770.clb
Part number SW: 02E 300 052, HW: 02E 927 770 AJ.
Part: GSG DSG AG6 440 1904
Revision: 04844002 Serial Number: 00000812080299
Encoding: 0000020
Operating number: WSC 00028 028 00001
VCID: 51AEB8D1C85F22C746-8004
18270 - Data bus driver.
P1862 - 000 - Missing message from the instrument cluster.
Error priority: 0
Error frequency: 255
Lost Count: 40
Mileage: 0 km
Time: 0
18036 - Data bus driver.
P1628 - 000 - Missing message from steering angle sensor - Intermittent.
Error status: 00100000
Error priority: 0
Lost Count: 40
Mileage: 0 km
Time: 0
Address 03: Brake Electronics (-----)
Label file: . DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 CE, HW: 1K0 907 379 AE.
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Encoding: 1462401A094A00222833020C90410042B100
Operating number: WSC 31230 001 1048576
VCID: 77FA2649C67B5CF7A8-8022
5 error codes found:
01309 - Steering assist control unit (J500)
004 - No signal/communication - Sporadically.
Error status: 00100100
Error priority: 3.
Error frequency: 1
Lost Count: 12
Time: 0
Quantity: 0
Quantity: 12
Quantity: 4608
Quantity: 8213
Quantity: 40704
Quantity: 1
Quantity: 0
Quantity: 0
00778 - Steering angle sensor (G85)
004 - No signal/communication.
Error status: 01100100
Error priority: 2
Error frequency: 1
Lost Count: 12
Time: 0
Quantity: 0
Quantity: 12
Quantity: 4608
Quantity: 166
Quantity: 40192
Quantity: 1
Quantity: 0
Quantity: 0
01317 - Control unit in the instrument panel carrier (J285)
Error priority: 3.
Error frequency: 1
Lost Count: 12
Time: 0
Quantity: 0
Quantity: 12
Quantity: 4096
Quantity: 8208
Quantity: 37632
Quantity: 1
Quantity: 0
Quantity: 0
03391 - Encoding not possible.
text
000 - -
Error priority: 6
Error frequency: 1
Lost Count: 12
Time: 0
Quantity: 2
Quantity: 12
Quantity: 4096
Quantity: 8254
Quantity: 41472
Quantity: 1
Quantity: 0
Quantity: 0
00474 - Immobilizer control unit.
Error priority: 2
Error frequency: 1
Lost Count: 12
Time: 0
Quantity: 2
Quantity: 12
Quantity: 4096
Quantity: 8211
Quantity: 41472
Quantity: 1
Quantity: 0
Quantity: 0
Address 08: Climate Control/Heater (J255) Label file:| DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0305
Revision: 00002001
Encoding: 0000000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 73E21259DA0330D794-8026
"1 error found:"
13701456 - Functionality restriction due to missing message.
U1111 00 [009] - -
[New feature!] Extended UDS error code information is only supported by current hardware generations.
confirmed - checked since last deletion.
Error status: 00000001
Error priority: 6
Error frequency: 1
Lost Count: 12
Date: 2000.00.00
Time: 00:00:00
Address 09: Central Electronics (J519)
Label file: . DRV\1K0-937-08x-09.clb
Part number SW: 1K0 937 086 Part number HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Encoding: 40180A3A90251AC040080081100081E445010088424D89605080000000000
Operating number: WSC 12345 123 61029
VCID: 6DD60421B427E62742-8038
Subsystem 1 - Part number: 1K1 955 119 E. Label file: DRV\1KX-955-119.CLB.
Part: Wiper 26010 21 0501
Encoding: 009795
00907 - Load Management Procedure.
text
000 - -
Error priority: 6
Error frequency: 2
Lost Count: 12
Mileage: 138,339 km
Time: 0
Class 15, Entry.
Voltage: 11.90 V
one
one
Size 50, SOLD OUT.
text
from
text
from
Error priority: 6
Error frequency: 1
Lost Count: 12
Mileage: 138,339 km
Time: 0
Class 15, Entry.
Voltage: 11.90 V
one
one
Size 50, SOLD OUT.
text
from
text
from
Address 15: Airbag (J234) Label file:| DRV\5K0-959-655.clb
Part number SW: 5K0 959 655 HW: 5K0 959 655
Part number: Airbag VW10, 033 0604.
Serial number: 003C2D08TR9H
Encoding: 00003135
Operating number: WSC 00028 028 00312
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FA2649CE7B5CF7A8-8022
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Fahr.V U01 ----
Serial number: 0D2A0645ZZZZZZZZZZZZ
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Front Passenger, U01 ----
Serial number: 77760545ZZZZZZZZZZZZ
Rear side airbag crash sensor (driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 36051830ZZZZZZZZZZZZ
Crash sensor for rear side airbag, passenger side:
Component: S. Sensor, Front, Right --- ----
Serial number: 0C4D1C10ZZZZZZZZZZZZ
"1 error found:"
12670208 - Control unit for switchboard installation.
U0155 00 [009] - No communication.
Error priority: 6
Error frequency: 3
Lost Count: 12
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY9.lbl
Part number SW: 1K0 953 549 CD, HW: 1K0 953 549 CD.
Part: J0527 855 0111
Encoding: 0001632
VCID: 76E42B4D017125FFB3-8022
Subsystem 1 - Part number: 3C8 959 537 B Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Encoding: 00000227
00576 - Terminal 15.
012 - Electrical fault in the circuit - Intermittent.
00883 - Ignition switch (D) Terminal S.
00884 - Ignition switch (D) Terminal X.
01744 - Ignition switch, terminal D (pin P).
00885 - Ignition switch (D) Terminal 50.
Address 17: Terminal block module.
unavailable
Address 19: Diagnostic interface. Label file: . DRV\1K0-907-530-V4.clb
Part number SW: 1K0 907 530 S, HW: 1K0 907 951.
Component: J533, Gateway, H07 0071.
Revision: H07 01 Serial Number: 300109F1001371
Encoding: ED807F06000202000002
VCID: 377AE64946FB9CF768-8062
Error status: 00110100
Error priority: 2
Error frequency: 1
Lost Count: 52
Time: 0
Error priority: 2
Error frequency: 1
Lost Count: 52
Time: 0
00381 - Data bus combination instrument.
Error priority: 1.
Error frequency: 14
Lost Count: 52
Time: 0
Error priority: 2
Error frequency: 1
Lost Count: 12
Time: 0
Error priority: 2
Error frequency: 1
Lost Count: 12
Time: 0
Address 25: Immobilizer.
unavailable
Address 42: Door electric driver. Label file: . DRV\1K0-959-701-MIN3.clb
Part number SW: 1K0 959 701 AF, HW: 1K0 959 701 AF.
Part: Door seal 008 2041
Encoding: 0000180
VCID: 72EC175D6D1939DF9F-8026
01321 - Airbag control unit (J234)
Address 44: Steering Assist
Label file: DRV\1K0-909-14x-GEN3.clb
Part number: 1K0 909 144 E
Component: EPS_ZFLS, Size 70 2501
Revision: 00H15000
VCID: 2C50C9258FBD2F2F15-8078
"1 error found:"
Error priority: 3.
Error frequency: 1
Lost Count: 12
Time: 0
Voltage: 11.25 V
DD
Temperature: 3.0°C
Speed: 0 RPM.
Speed: 0.0 km/h
Speed: 0.0 km/h
Quantity: 0
Address 52: Door electronics, passenger side. Label file: . DRV\1K0-959-702-MIN3.clb
Part number SW: 1K0 959 702 AF, HW: 1K0 959 702 AF.
Encoding: 0000180
VCID: 73E21259120330D794-8026
Address 56: Radio (J0503) Label file: . DRV\5M0-035-1xx-56.clb
Part number SW: 3C8 035 195 HW: 3C8 035 195
Part: Radio RCD510, part number 036 0130.
Revision: 00000001 Serial number: VWZ1Z3I4210138
Encoding: 0500040004
VCID: 65C67C016CD7DE670A-8030
Error priority: 6
Error frequency: 1
Lost Count: 12
Mileage: 0 km
Time: 0
03138 - AUX IN input.
011 - Interruption.
Error status: 01101011
Error priority: 5
Error frequency: 1
Lost Count: 120
Mileage: 134,105 km
Time: 0
Date: 2056.14.18
Time: 00:41:49
Address 62: Door electric, left/right. Label file: . DRV\1K0-959-703-GEN3.clb
Part number SW: 1K0 959 703 AL Hardware number: 1K0 959 703 AL
Part: Door Seal 007 2009
Encoding: 0000144
Operating number: WSC 00028 028 1012545
VCID: 7AFC3F7D3569419FD7-802E
No error codes found.
Address 72: Door electrical, high, right. Label file: . DRV\1K0-959-704-GEN3.clb
Part number SW: 1K0 959 704 AL Hardware number: 1K0 959 704 AL
Encoding: 0000144
VCID: 7BF23A793A537897CC-802E
End----------------------------(Duration: 02:10)-----------------------------
Maybe someone can help me.
