Pump Nozzle Problems: Troubleshooting & Repair
Pirellig60
Post30-04-2020, 16:25    Subject: Pump Nozzle Problems: Troubleshooting & Repair Quote
I have a Caddy from 2007 with a 77kW BLS engine and 190,000 km on the odometer.
The car starts perfectly when it's cold, but it has major problems when it's warm.
Perhaps someone here can give me a tip about what I can do.
 File size:  88.06 KB
 Viewed:  1154 times
Translated on 20-09-2026, 13:10.
a dancer
dieselschrauber likes this.
Post09-06-2020, 20:58    Subject: Pump Nozzle Problems: Troubleshooting & Repair Quote
How does the starting process behave when using a tow start or bump start in a warm condition?
There have been numerous lengthy troubleshooting efforts online regarding warm start problems in VW TDI vehicles, which were ultimately resolved by replacing the starter motor. I had (and still have) an AFN engine.
Karma: +649 / -0   Thank you, like it!
Post12-06-2020, 21:32    Subject: Pump Nozzle Problems: Troubleshooting & Repair Quote
Hi.
Disconnect the engine temperature sensor and test it, but be aware that this will likely trigger an error code.
At the AFN, I reconfigured the MSG (Message Generator) from switch mode to automatic mode, and since then, the problem has disappeared.
Translated on 20-09-2026, 13:11.
Karma: +1359 / -0   Thank you, like it!
Post13-06-2020, 20:21    Subject: Pump Nozzle Problems: Troubleshooting & Repair Quote
Translated on 20-09-2026, 13:12.
Karma: +807 / -0   Thank you, like it!
Post14-06-2020, 14:21    Subject: Pump Nozzle Problems: Troubleshooting & Repair Quote
However, it could still be due to a too-low starter motor speed. icon_wink.gif
Therefore: Observe/log these.
The reason why recoding some TDI engines to automatic mode can help is because it allows the engine to start at lower RPMs. When the coolant temperature sensor is disconnected, the engine control unit (ECU) assumes a very low temperature value, causing the ECU to interpret it as a cold start. During a cold start, any existing RPM threshold for starting is typically much lower, or even at 0.
There are various discussions about the "warm start" problem in this forum. Simply search for "warm start problem" and click through the similar topics (located in the bottom left corner of each topic).
That was a response related to the comment before mine; it suggested that he should try it with the plug.
Translated on 20-09-2026, 13:14.
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Which injector pump unit is used in the 1.9 TDI AVF engine? Diesel Engine Technology
No new posts Pump Nozzle Service: Long Life for T5 with DPF On-Board Diagnostics (OBD)
No new posts Pump Nozzle Tuning: Cheap DIY Guide & Tips Diesel Engine Technology
No new posts Golf4 TDI Pump Injector: I want to have a cruise control ... Transmission, Chassis, Body & Interior
