Solarsepp
14-07-2020, 10:52 Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface |
I purchased the interface mentioned above from the "Dieselschrauber-Shop" in 2016. Okay, here's the translation:
"Now, I wanted to make some adjustments in the BCM, and I'm getting a message that..."
"This interface does not support sending telegrams larger than 256 bytes."
Is the interface really too outdated for my 2015 sports van?
| Description: |
| File size: |
214.31 KB |
| Viewed: |
368 times |
| Description: |
| File size: |
214.31 KB |
| Viewed: |
298 times |
Joined: 04/12/2002 Posts: 17994 Karma: +782 / -0 Location: St.Gallen 2018 Volkswagen T6
Profile PM WWW Garage |
Solarsepp
20-07-2020, 15:39 Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface |
Thank you for the quick response.
I have one more question - where can I find the license number? Is it likely that the serial number found in VCDS under "About" is the one we're looking for?
THANK YOU!
20-07-2020, 17:29 Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface |
What do you mean by "license number"? It's only available on the "About..." screen. Or are you referring to the serial number of the interface? It's located on the interface.
Dipl.-Ing. (FH) Rainer Kaufmann - dieselschrauber VCDS Shop |
Solarsepp
20-07-2020, 17:44 Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface |
Hello Rainer,
Thank you for your feedback.
As far as I understand, when upgrading, I need the license number for the VCDS/Interface to verify that it is not a clone?
Josef
22-07-2020, 19:34 Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface |
You need a Screenshot of your "About..." screen. If you are a new customer or the interface is from a different source, please ensure the invoice is addressed to your name.
