Audi A4 B8: Reset Service Interval
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
a4b82.0tdi
Post11-07-2020, 22:54    Subject: Audi A4 B8: Reset Service Interval Quote
Hello everyone,
I have performed the oil service and inspections and reset the maintenance indicator – using longlife oil.
The oil service function worked, but when resetting the inspection service (for regions outside of Europe), the time since the last inspection was not updated.
Therefore, the dashboard displayed: "Inspection due for 160 days" and when starting the engine, it showed: "Inspection due!".
Now I've changed channel 55, which displays "Time since inspection," from 895 days to 3, and now it matches the information on the instrument cluster.
-Question: Shouldn't this value be automatically set to 0?
Attached is the error-free Autoscan report along with the values for oil service and inspection.
But I still get the message "Inspection due!" when starting and turning off the car.
-Maybe a value is incorrect?
And when I ran the car scan, the message appeared: "Stability program fault - see owner's manual."
However, I couldn't find anything about malfunctions in the user manual. And I can turn the ASR (Anti-Slip Regulation) and ESP (Electronic Stability Program) on and off while driving, and it also displays that they are active.
-What can I do to get rid of this message: "Inspection due"?
Log-WAUZZZ8K5BA124556-240620km-Audi A4B8.txt
 File name:  Log-WAUZZZ8K5BA124556-240620km-Audi A4B8.txt
 File size:  12.03 KB
 Downloaded:  881 times
Log-240620km-Audi A4B8 Serviceintervall Werte.txt
 File name:  Log-240620km-Audi A4B8 Serviceintervall Werte.txt
 File size:  7.16 KB
 Downloaded:  785 times
Log-240620km-Audi A4B8 Serviceinspektion zurĂŒckstellen.txt
 File name:  Log-240620km-Audi A4B8 Serviceinspektion zurĂŒckstellen.txt
 File size:  2.47 KB
 Downloaded:  846 times
Translated on 11-08-2026, 21:40.
Post13-07-2020, 19:03    Subject: Audi A4 B8: Reset Service Interval Quote
Hi.
Data as of: 20200518 DS317.0
There is a newer data version available, which also includes updated service reset functions. Please first install the latest version of VCDS from your customer account and try again.
Did you perform the reset using the assistant tool, which first reads the adaptation channels from the instrument cluster and then describes them accordingly, correct?
Generally speaking:
Service interval display / Maintenance interval display Audi
Translated on 11-08-2026, 21:43.
a4b82.0tdi
Post22-07-2020, 19:57    Subject: Audi A4 B8: Reset Service Interval Quote
Hello.
I reinstalled VCWS yesterday and performed the service reset procedure again, but the "Service due!" message still appears when starting and stopping the engine.
I selected the option "Switch to flexible maintenance intervals (rest of the world/diesel engine)" in the "Service Reset" menu.
But as soon as I started it, the same error message appeared again, and it also shows up when I shut it down.
The automatic scan found no errors. However, during the automatic scan, a brief message appeared stating: "Stability program malfunction - see owner's manual."
I went to the ÖAMTC (Austrian Automobile Club) in Dornbirn today, and they used a Gutmann and a Bosch diagnostic tool to check the car, but they didn't find any errors.
- How can the service be stopped so that the error message no longer appears?
After starting the device, I changed the value of channel 02 from "service due" to "0 service". This was reflected in the log, but after restarting, the error message "service due!" reappeared, and the value of channel 02 reverted back to 1.
"Would it be possible or necessary to switch back to a fixed service interval without using long-life oil, and to individually adjust all the required parameters to 30,000 km, 730 days, and for long-life oil?"
And Rainer, what do you understand by "fundamentally" – with your link?
- Are you suggesting that I should first use the "Service Reset" option in the menu (is that the assistant?), and then correct certain channels?
Thank you for your help.
Log-AUDI A4 B8-WAUZZZ8K5BA124556-240820km-4_Auto-Scan.txt
 File name:  Log-AUDI A4 B8-WAUZZZ8K5BA124556-240820km-4_Auto-Scan.txt
 File size:  12.05 KB
 Downloaded:  724 times
Log-AUDI A4 B8 3_nach_Service_RĂŒcksetzung_im_Kanal_02.txt
 File name:  Log-AUDI A4 B8 3_nach_Service_RĂŒcksetzung_im_Kanal_02.txt
 File size:  2.47 KB
 Downloaded:  657 times
Log-Audi A4 B8 2_nach_Service_RĂŒcksetzung_mit_MenĂŒ.txt
 File name:  Log-Audi A4 B8 2_nach_Service_RĂŒcksetzung_mit_MenĂŒ.txt
 File size:  2.62 KB
 Downloaded:  655 times
Translated on 11-08-2026, 21:46.
Post22-07-2020, 21:00    Subject: Audi A4 B8: Reset Service Interval Quote
"Could you please take a Screenshot of what you see when performing the service reset in VCDS, and show me the available options?"
Translated on 11-08-2026, 21:49.
a4b82.0tdi
Post27-07-2020, 21:12    Subject: Audi A4 B8: Reset Service Interval Quote
I have the software installed on a tablet PC, and it doesn't have a "print" button.
I found on Google that pressing the "Windows key + volume down button" should save a Screenshot, but unfortunately, I didn't see any reaction, and I couldn't find any files related to it (from today's date).
Attached is a picture of the keyboard.
- Is there perhaps another keyboard shortcut that works?
 File size:  3.72 MB
 Viewed:  11206 times
Post29-07-2020, 18:27    Subject: Audi A4 B8: Reset Service Interval Quote
Perhaps you could take a picture of the screen with your phone instead of the keyboard? Just as a suggestion for another way to get a Screenshot... icon_confused.gif
Translated on 11-08-2026, 21:50.
a4b82.0tdi
Post29-07-2020, 20:48    Subject: Audi A4 B8: Reset Service Interval Quote
Okay, I'll do that tomorrow evening.
Translated on 11-08-2026, 21:51.
a4b82.0tdi
Post29-07-2020, 21:35    Subject: Audi A4 B8: Reset Service Interval Quote
I also received information that for these engines, it's important to pay attention to the soot value or soot level after driving over 180,000 kilometers.
- Could that be the reason why I'm still getting the "Service due" message?
- Does anyone here have experience and might be able to help?
Thank you in advance.
Post29-07-2020, 21:47    Subject: Audi A4 B8: Reset Service Interval Quote
Read and follow the link I provided. Your control unit uses UDS, so:
/viewtopic.php?t=28677
It's very likely to be the same.
a4b82.0tdi wrote:
I also received information that with these engines, it's important to pay attention to the soot value or soot level after more than 180,000 km.
Just have the person who gave you this information explain it to you directly.
As it stands written, it's nonsense; perhaps he meant something else, but no one here can know that. icon_idea.gif
Translated on 11-08-2026, 21:53.
a4b82.0tdi
Post30-07-2020, 8:11    Subject: Audi A4 B8: Reset Service Interval Quote
Here are the options:
VCDS Möglichkeiten Wartungsintervalle.pdf
 File name:  VCDS Möglichkeiten Wartungsintervalle.pdf
 File size:  247.19 KB
 Downloaded:  445 times
Translated on 11-08-2026, 21:54.
Post30-07-2020, 20:29    Subject: Audi A4 B8: Reset Service Interval Quote
Verstehe das Problem nicht... Everything is there.
Switch to flexible maintenance intervals, for the rest of the world, diesel engine. Usually unnecessary, just because you clicked something somewhere before.
Reset flexible oil change service for long-life intervals, applicable to vehicles outside of specific regions and with diesel engines.
Reset additional tasks.
4. Reset inspection service, rest of the world.
5. Exit the control unit with the "back" button.
6. Ignition off for 5 seconds.
7. Ignition on.
8. Report here.
Translated on 11-08-2026, 21:55.
Karma: +1349 / -0   Thank you, like it!
dieselschrauber likes this.
Post30-07-2020, 20:38    Subject: Audi A4 B8: Reset Service Interval Quote
Hi there,
As someone who has driven an A4 B8 with varying degrees of success (see my signature), I'd like to offer my input.
The "Oil change due" message is cleared by setting two adaptation channels (APKs) to "0", namely "kilometers since..." and "time since...", and then resetting the APK for the service message.
Similarly, for "Inspection due," there are two other APK fields: "kilometers since..." and "time since...".
For now, I'm leaving out the details regarding tasks that are time- or mileage-based (such as brake fluid changes and timing belt replacements).
Translated on 11-08-2026, 21:57.
a4b82.0tdi
Post31-07-2020, 7:21    Subject: Audi A4 B8: Reset Service Interval Quote
Good morning.
Thank you - that's a very good and clear answer, perfect for me as a layperson.
I will do it in the same order and report back.
Since the car won't be available for several days, it will take some time.
A big thank you – also to the second council.
Translated on 11-08-2026, 21:59.
Post31-07-2020, 10:25    Subject: Audi A4 B8: Reset Service Interval Quote
Hi there,
Perhaps regarding the Screenshot I posted earlier about "resetting maintenance intervals," I'd like to know, before using it, which adjustment channels each function accesses.
Otherwise, I prefer to reset things manually by installing individual APK files.
Incidentally, when resetting the inspection service, Audi/VW proceeds in two ways (at least that's how SSP 438 describes it). The mileage until the next inspection service is always set to the full 30,000 km interval (i.e., it is reset and the base value is changed). Example: Inspection at 58,000 km - a reset is performed with a new mileage of 32,000 km.
The runtime is set to the next event to be performed (or left as is), or a maximum of 730 days. Example: Inspection in July 2020. Brake fluid due in January 2021. Therefore, the time until the next inspection should only be 182 days.
Translated on 11-08-2026, 22:01.
a4b82.0tdi
Post09-08-2020, 19:16    Subject: Audi A4 B8: Reset Service Interval Quote
Hello everyone,
Okay, it finally worked! And great that the "Service due!" message has finally disappeared.
Rainer, it only worked when I followed that exact order.
Finally, a big thank you.
Best regards.
Translated on 11-08-2026, 22:03.
Post10-08-2020, 17:16    Subject: Audi A4 B8: Reset Service Interval Quote
Translated on 11-08-2026, 22:04.
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resetting the service interval display on a Volkswagen Go... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Service Interval Reset: How To On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. VAG-COM: Reset Service Interval - How To Diesel Engine Technology
No new posts Reset Service Interval with VAG-COM 0.81? Diesel Engine Technology
No new posts Reschedule inspection for Audi Q5 models from 2019 onwards Diesel Engine Technology
