VW Phaeton: VCDS - Transmission Control Module Not Responding.
tobir2501
Post01-10-2020, 21:38    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
Hello everyone,
I have a problem. I had my transmission flushed last week, and approximately 15 liters of oil were used.
I tried to query the transmission temperature using VCDS, but it didn't respond; it says "Control unit does not respond."
I'm using the latest VCDS with the HEX V2.
What can I do?
Translated on 07-10-2026, 11:50.
dieselschrauber likes this.
Post02-10-2020, 8:02    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
Perhaps you could start by saying that there are people who might be able to help you, especially since you have a rather rare vehicle.
1. Autoscan
Translated on 07-10-2026, 11:51.
tobir2501
Post02-10-2020, 20:17    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
Hi and sorry.
Code:
Freitag,02,Oktober,2020,14:23:10:63593
VCDS -- Windows-basierter VAG/VAS-Emulator l‰uft auf Windows 10 x64
VCDS Version: DRV 20.4.2.1  HEX-V2 CB: 0.4513.4
Datenstand: 20200919 DS317.0
shop.dieselschrauber.org
Fahrzeug-Ident.-Nr.: WVWZZZ3DZ88004240   KFZ-Kennzeichen: GI
Kilometerstand: 212490km   Reparaturauftrag:
Fahrzeugtyp: 3D (6N0)
Scan: 01 02 03 05 06 07 08 09 13 15 16 17 18 19 23 28 34 36 37 38
          3C 42 46 47 52 55 57 62 65 66 68 71 72 76 77
Fahrzeug-Ident.-Nr.: WVWZZZ3DZ88004240   Kilometerstand: 212490km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
06-Sitzverst. Beifah. -- Status: i.O. 0000
07-Anz./Bedieneinh. -- Status: Fehler 0010
08-Klima-/Heizungsel. -- Status: Fehler 0010
13-Distanzregelung -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: Fehler 0010
18-Standheizung -- Status: Fehler 0010
19-Diagnoseinterface -- Status: Fehler 0010
23-Bremskraftverst. -- Status: Fehler 0010
28-Heizung/Klima hi. -- Status: i.O. 0000
34-Niveauregelung -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
37-Navigation -- Status: Fehler 0010
38-Dachelektronik -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-T¸relektr. Fahrer -- Status: Sporadischer Kommunikationsfehler 1000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
52-T¸relektr. Beifahr. -- Status: Fehler 0010
55-Leuchtweitenreg. -- Status: i.O. 0000
57-TV Tuner -- Status: i.O. 0000
62-T¸relektr. hi. li. -- Status: i.O. 0000
65-Reifendruck -- Status: i.O. 0000
66-Sitzverst. hinten -- Status: i.O. 0000
68-Wischerelektronik -- Status: i.O. 0000
71-Batterieladeger‰t -- Status: i.O. 0000
72-T¸relektr. hi. re. -- Status: Fehler 0010
76-Einparkhilfe -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Adresse 01: Motorelektronik (CAR)       Labeldatei: Keine
   Teilenummer SW: 3D0 907 401 F    HW: 3D0 907 401 D
   Bauteil: 3.0TDI EDC17A100AG  0040
   Revision: --H01---    Seriennummer: VWX3Z0G3696936
   Codierung: 0406002C191F0260
   Betriebsnr.: WSC 19530 666 59056
   VCID: 221C12B4C8D0778B646-5184
Readiness: 0 0 0 0 0
Adresse 02: Getriebe
nicht erreichbar
Adresse 03: Bremsenelektronik        Labeldatei: 3D0-614-517.lbl
   Teilenummer: 3D0 614 517 AK
   Bauteil: ESP 5.7 allrad  H33 0047
   Codierung: 0008356
   Betriebsnr.: WSC 01065 000 00000
   VCID: 6B823F907F9A76C3970-51F2
Adresse 05: Zugangs-/Startber.        Labeldatei: DRV\3D0-909-13x-05.lbl
   Teilenummer SW: 3D0 909 137 D    HW: 5WK 485 05
   Bauteil:    Kessy            6840
   Revision: 68406620    Seriennummer: VWX3Z0G3696936
   Codierung: 0217324
   VCID: 2808009CAEBC9DDB3A2-807C
   Subsystem 1 - Teilenummer: XXXXXXXXXXX
   Bauteil: ELV                 XXXX
Adresse 06: Sitzverst. Beifah.        Labeldatei: 3D0-959-759.lbl
   Teilenummer: 3D0 959 759 CA
   Bauteil: Sitzmemory D1 BF    1720
   Codierung: 0000003
   VCID: 77AA13E03382C223638-8022
Adresse 07: Anz./Bedieneinh.        Labeldatei: DRV\3D0-035-00x-07.lbl
   Teilenummer: 3D0 035 007 CX
   Bauteil:    ZAB COCKPIT      2257
   Codierung: 0500737
   Betriebsnr.: WSC 68144 133 85564
   VCID: 71BE2DF85DB69C13ADC-5160
1 Fehler gefunden:
00668 - Bordspannung Klemme 30
            002 - unterer Grenzwert unterschritten - Sporadisch
Adresse 08: Klima-/Heizungsel.        Labeldatei: 3D0-907-040.lbl
   Teilenummer: 3D0 907 040 J
   Bauteil: Climatronic D1      2031
   Codierung: 0000001
   VCID: 251609A8D9AE80B3014-8070
2 Fehlercodes gefunden:
00716 - Stellmotor f¸r Umluftklappe (V113)
            014 - defekt
00057 - Stellmotor Absperrklappe B-S‰ule und Fuflraum rechts (V211)
            014 - defekt
Adresse 09: Zentralelektrik        Labeldatei:. DRV\3D0-937-049-V2.clb
   Teilenummer SW: 3D0 937 049 M    HW: 3D0 937 049 M
   Bauteil: J519                6500
   Revision: -4004---    Seriennummer: --------------
   Codierung: 610C0000EB3115060000000000000000
   VCID: 3430E4EC6274E93B86A-8060
Adresse 13: Distanzregelung        Labeldatei: Umleit. fehlgeschl.!
   Teilenummer SW: 3D0 907 567 M    HW: 3D0 907 567 M
   Bauteil: AC201  RDW 1    031 0711
   Revision: 00031000    Seriennummer: 00000000018191
   Codierung: 0010000
   Betriebsnr.: WSC 52396 133 95161
   VCID: 3634DEE47408FB2BB8E-8062
Adresse 15: Airbag        Labeldatei: DRV\3D0-909-601.lbl
   Teilenummer: 3D0 909 601 E
   Bauteil: 0H Airbag 8.4E+ H12 0935
   Codierung: 0012360
Adresse 16: Lenkradelektronik        Labeldatei: DRV\7L6-953-549.lbl
   Teilenummer: 7L6 953 549 L
   Bauteil: J527                3601
   Codierung: 0001222
   VCID: 48C8A01C0EFC7DDBDA2-801C
Adresse 17: Schalttafeleinsatz        Labeldatei: DRV\3D0-920-xxx-17.lbl
   Teilenummer SW: 3D0 920 885 K    HW: 3D0 920 885 K
   Bauteil: J285 KOMBI-INST.    4227
   Revision: KPH06V02
   Codierung: 0007101
   Betriebsnr.: WSC 01535 002 1048576
   VCID: 323CE2F49820E70B946-8066
1 Fehler gefunden:
01331 - T¸rsteuerger‰t Fahrerseite (J386)
            004 - kein Signal/Kommunikation - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00100100
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 32
                    Kilometerstand: 211778 km
                    Zeitangabe: 0
                    Datum: 2020.09.21
                    Zeit: 18:32:52
Adresse 18: Standheizung        Labeldatei: DRV\3D0-815-005.clb
   Teilenummer: 3D0 815 005 AK
   Bauteil: Standheizung        3426
   VCID: 66944EA464284BABC8E-8032
1 Fehler gefunden:
01415 - Umw‰lzpumpe (V55)
            010 - Unterbrechung/Kurzschluss nach Plus - Sporadisch
Adresse 19: Diagnoseinterface        Labeldatei:. DRV\6N0-909-901-7L.clb
   Teilenummer SW: 6N0 909 901     HW: 3D0 920 885 K
   Bauteil: J533  GW-K-CAN TP20 4227
   Codierung: FFF7FFFE3F1002
   VCID: 70B828FC56AC951BA22-8024
1 Fehler gefunden:
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 32
                    Zeitangabe: 0
                    Datum: 2020.09.21
                    Zeit: 18:32:52
Adresse 23: Bremskraftverst.        Labeldatei: Keine
   Teilenummer: 3D0 907 563 G
   Bauteil: BREMSBOOSTER    007 0621
   Revision: 00007000    Seriennummer: 00000000026488
   VCID: 2C00FC8CBA44B1FBDEA-8078
1 Fehler gefunden:
01677 - Ventil f¸r ADR-Bremseneingriff
            011 - Unterbrechung - Sporadisch - Warnleuchte EIN
                    Spannung: 14.10 V
                    Drehmoment: 0.0 Nm
                    Druck: 0.0 bar
                    Inhalt: 0.0 mm
                    Stromst‰rke: 5.100 A
                    Geschwindigkeit: 30.0 km/h
                    Anzahl: 79
Adresse 28: Heizung/Klima hi.        Labeldatei: DRV\3D0-919-158.lbl
   Teilenummer: 3D0 919 158 H
   Bauteil: Klima-Bedienteil D1 0117
   VCID: 3038E8FC966CD51BE22-8064
Adresse 34: Niveauregelung        Labeldatei: DRV\3D0-907-553-V2.clb
   Teilenummer: 3D0 907 553 C
   Bauteil: LUFTFDR.-CDC- 3C3V0 1122
   Codierung: 0005521
   Betriebsnr.: WSC 30238 002 1048576
   VCID: 270A03A0A3A292A3338-8072
Adresse 36: Sitzverst. Fahr.        Labeldatei: DRV\3D0-959-760.lbl
   Teilenummer: 3D0 959 760 CA
   Bauteil: Sitzmemory D1 F     1720
   Codierung: 0000004
   VCID: 6FBA2B804BD28AE3BB8-803A
1 Fehler gefunden:
01892 - Temperaturf¸hler f¸r Sitzlehne (G371)
Adresse 37: Navigation        Labeldatei:
   VCID: 55F67968CC0ED033514-8000
   Hinweis: Zu viele Kommunikationsfehler
Adresse 38: Dachelektronik        Labeldatei: 3D0-907-135.lbl
   Teilenummer: 3D0 907 135 D
   Bauteil: Dachmodul           0802
   Codierung: 0004119
   Betriebsnr.: WSC 02275 169 175918
   VCID: 241014ACD29479BB16A-8070
Adresse 3C: Spurwechsel        Labeldatei: DRV\7E0-907-566-V1.clb
   Teilenummer SW: 7L6 907 566 B    HW: 7L6 907 566 A
   Bauteil: J0769_SWA_MasterH10 0070
   Revision: 00H10000    Seriennummer: 6PZ 009 014-01
   Codierung: 0000152
   VCID: 3C20CCCC4A24217B4EA-8068
   Subsystem 1 - Teilenummer: 7L6 907 568 B
   Bauteil: J0770_SWA_Slave_H08 0070
   Subsystem 2 - Seriennummer: 6PZ 009 014-21
   Subsystem 3 - Seriennummer: 3F17.12.0700H0800000010022ˇ
   Subsystem 4 - Seriennummer: 010022ˇ
Adresse 46: Komfortsystem        Labeldatei: 3D0-959-933.lbl
   Teilenummer: 3D0 959 933 F
   Bauteil: 1B HSG              0102
   Codierung: 0000040
   VCID: 3332E7F0672AEE039F0-4B00
   Subsystem 1 - Teilenummer: 3D1 959 701 L
   Bauteil: Tuersteuergeraet FS 6002
   Subsystem 2 - Teilenummer: 3D1 959 702 L
   Bauteil: Tuersteuergeraet BF 6001
   Subsystem 3 - Teilenummer: 3D0 959 703 K
   Bauteil: Tuersteuergeraet HL 6001
   Subsystem 4 - Teilenummer: 3D0 959 704 K
   Bauteil: Tuersteuergeraet HR 6001
   Subsystem 5 - Teilenummer: 3D0 909 610 C
   Bauteil: 3L HDSG             2330
   Subsystem 6 - Teilenummer: 7L0 907 719 A
   Bauteil:    Neigungssensor   0020
00486 - Taster f¸r Zentralverriegelung; T¸rauflengriff Beifahrerseite (E370)
            007 - Kurzschluss nach Masse
00488 - Taster f¸r Zentralverriegelung; T¸rauflengriff hinten rechts (E372)
Adresse 47: Soundsystem        Labeldatei: DRV\7Lx-035-4xx-47.lbl
   Teilenummer: 3D0 035 466 A
   Bauteil: 12K-AUDIOVERST      0118
   VCID: 201818BCC68C659B722-8074
Adresse 55: Leuchtweitenreg.        Labeldatei: 7L6-907-357-A.lbl
   Teilenummer SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Bauteil: AFS-Steuergeraet    0001
   Revision:   H02       Seriennummer:
   Codierung: 2213953
   VCID: 392ED5D84516145355C-806C
   Subsystem 1 - Teilenummer: 7L6 941 329 A  Labeldatei: 3D0-941-329.CLB
   Bauteil: AFS-Lst.-Modul l    0002
   Codierung: 00000033
   Subsystem 2 - Teilenummer: 7L6 941 329 A  Labeldatei: 3D0-941-329.CLB
   Bauteil: AFS-Lst.-Modul r    0002
   Codierung: 00000033
Adresse 57: TV Tuner        Labeldatei: Keine
   Teilenummer SW: 3D0 919 148     HW: 3D0 919 148
   Bauteil: TV-Tuner            0160
   Revision: R0H16000    Seriennummer: 91100500331202
   Codierung: 0000001
   VCID: 678A43A0632252A3F38-8032
Adresse 65: Reifendruck        Labeldatei: Umleit. fehlgeschl.!
   Teilenummer SW: 3D0 907 273 F    HW: 3D0 907 273 F
   Bauteil: J0502 RDK           0005
   Revision: 00004005    Seriennummer: 00000900002188
   Codierung: 264900648C759D86AE426A0000
   VCID: 290E0598B5B6A4D325C-807C
Adresse 66: Sitzverst. hinten        Labeldatei: Keine
   Teilenummer: 3D0 959 860 CA
   Bauteil: Sitzmemory D1 H     1721
   Codierung: 0000001
   VCID: 70B828FC56EC951BA22-8024
Adresse 68: Wischerelektronik        Labeldatei: 3Dx-955-1xx-V2.clb
   Teilenummer: 3D1 955 119 B
   Bauteil: Front Wiper         3501
   Codierung: 0013685
   Betriebsnr.: WSC 01065 000 376832
Adresse 71: Batterieladeger‰t        Labeldatei: DRV\3D0-915-181.lbl
   Teilenummer: 3D0 915 181 D
   Bauteil: Batteriemanagement  2800
Adresse 76: Einparkhilfe        Labeldatei: Keine
   Teilenummer: 3D0 919 283 D
   Bauteil: 01 Einparkhilfe     0907
   VCID: 2B02FF90BF4AB6C3D70-807E
Adresse 77: Telefon        Labeldatei: Keine
   Teilenummer SW: 3W0 035 385 AS    HW: 3W0 035 385 AS
   Bauteil: VW rSAP Phaeton     0262
   Revision: 00008000    Seriennummer: 30700000093013
   Codierung: 0011000
   VCID: 06546E244468ABAB68E-8052
Ende--(Dauer: 03:34, Batt.-Spannung Start/Ende: 12.0V/12.0V. VIgn 12.0V)---
Adresse 17: Fehlercodes gelˆscht
Adresse 19: Fehlercodes gelˆscht
Adresse 05: Fehlercodes gelˆscht
Adresse 08: Fehlercodes gelˆscht
Adresse 18: Fehlercodes gelˆscht
vag-driver
Post05-10-2020, 10:55    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
Given that both the control panel and the diagnostic interface are showing errors, I suspect there's a fundamental problem with the CAN communication.
What repairs have been made to this vehicle in the past regarding this issue? Is the interior dry?
Andreas
Translated on 07-10-2026, 11:52.
tobir2501
Post05-10-2020, 11:15    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
The interior is completely dry.
The car has no issues and runs like a dream.
vag-driver
Post05-10-2020, 12:28    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
Since when have these diagnostic errors been present? Are there any visible cable breaks?
Andreas
tobir2501
Post05-10-2020, 14:05    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
"No diagnostic errors found, only a transmission control unit issue, with no apparent cable breaks."
Translated on 07-10-2026, 11:53.
Post05-10-2020, 14:13    Subject: VW Phaeton: VCDS - Transmission Control Module Not Responding. Quote
Okay, I think we should clarify the terminology. You mentioned "diagnosis errors"... what's meant here is that your diagnosis, in this case, the car's diagnostic scan, is not entirely accurate. In addition to a partially low voltage (which, on its own, can cause significant errors, although it doesn't necessarily have to), there are a number of communication problems.
After saving the data, it would be good to adjust the on-board voltage (charge the battery...), clear any error codes, and drive the car for a bit, then run another diagnostic scan.
Okay, let's establish this: you're not detecting any moisture inside.
In the event of cable failures, I would proceed with caution in such a complex vehicle, as that could theoretically always happen. Now, the important thing is to figure out what's wrong with your machine.
No new posts Phaeton Repair: 3D2 Seat Wiring Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Transmission Control Unit: Recording Issues On-Board Diagnostics (OBD)
No new posts Golf 4 TDI: Transmission Control Module Not Found Transmission, Chassis, Body & Interior
No new posts 1Z No Response: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Control Unit Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
