Climate Error Pressure Sensor
TDI_12
Post06-08-2020, 22:50    Subject: Climate Error Pressure Sensor Quote
Address 08: Climate Control Module. Label file: DRV\8D0-820-043-1D.lbl
Part number: 8D0 820 043 N
Component: A4
Automatic Climate Control D57
Encoding: 00043
Operating number: WSC 06335
VCID: 2B02F1E66A1EC9C3D68-25B6
"One error found:"
00792 - Pressure switch for air conditioner (F129)
31-00 - Short circuit to ground / Interruption.
Can this error also occur with an empty system, or only with a defective pressure switch?
Translated on 14-10-2026, 16:04.
Karma: +646 / -0   Thank you, like it!
dieselschrauber and Duese likes this.
Post10-08-2020, 7:08    Subject: Climate Error Pressure Sensor Quote
Hi.
"I recently had the same issue with a '98 A4. The connector to the sensor was disconnected for some reason. I reconnected it, cleared the error code, and the system started working again, both heating and cooling."
Translated on 14-10-2026, 16:05.
vag-driver
Post11-08-2020, 9:03    Subject: Climate Error Pressure Sensor Quote
As Rüdi already mentioned:
1. Check the wiring for corrosion and cable breaks.
2. Or the pressure switch is defective.
Andreas
Translated on 14-10-2026, 16:06.
Post02-09-2020, 10:42    Subject: Climate Error Pressure Sensor Quote
No new posts P2453 - Diesel Particulate Filter Pressure Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2452 - Diesel Particulate Filter Pressure Sensor 'A', Ma... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pressure Sensor BMM: Buy Now! Diesel Engine Technology
No new posts Defective Pressure Sensor: STG Diagnostics Diesel Engine Technology
No new posts Pressure Sensor: Model 00519 Diesel Engine Technology
No new posts Test pressure sensor: How to check & troubleshoot On-Board Diagnostics (OBD)
