High Beam Error: Coding Issues & Fixes
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Ranug
2019 Skoda Octavia
Post19-09-2020, 19:02    Subject: High Beam Error: Coding Issues & Fixes Quote
Hello everyone.
I'm having a problem; I was just trying to code my high beam assist. Now I'm getting an error message: "Headlight range control." Attached is my car's scan data from Saturday, September 19, 2020, at 8:13:30 PM.
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 20.4.1.1 HEX-V2 CB: 0.4508.4
Data as of: 20200518 DS317.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number: TMBJR7NE2L0088867
License plate:
Vehicle type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 42 44 4B 52 5F 6C 6D A5
BB BC D6 D7
Mileage: 11242 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
2B steering column lock. -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B Multifunction Device -- Status: Error 0010.
52-door electric passenger door - Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
6C Rear-view camera -- Status: OK 0000
6D tailgate -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: OK 0000
Rear left door electronics -- Status: OK 0000.
Rear right door electronics - Status: OK 0000.
D6-Left lighting control 2 -- Status: not registered 0001.
D7-Light control, right side, 2 -- Status: not registered 0001.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-DPCA)
Label file: None.
Part number SW: 05E 906 018 AS, HW: 05E 907 309 H.
Component: R4 1.5l TFS H20 9596
Revision: 8AH20000
Encoding: 012500322364010810000000000000000000000000000000
Operating number: WSC 31000 790 00268
ASAM Dataset: EV_ECM15TFS01105E906018AS 003003
ROD: EV_ECM15TFS01105E906018AS.rod
VCID: 76B41E93684FDB4B796-8022
No error codes found.
Readiness: 1110 0001
Address 02: Transmission (J743)
Label file: DRV\0CW-927-769.clb
Part number SW: 0CW 300 050 A, HW: 0AM 927 769 E.
Component: GSG DQ200G2_M H05 1701
Revision: 00005008 Serial number: CU501910275951
Encoding: 0014
Operating number: WSC 31000 790 00249
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 3332E7873BBD8E639E8-8066
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 5Q0 614 517 ES
Part number HW: 5Q0 614 517 BP
Component: ESC H35 0190
Revision: 00000000 Serial Number: 63019000003883
Encoding: 25076A9120282174407F060660CA24A456048402600624723621F070D0224B0B0000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 06546E5318AFCBCB696-8052
Address 05: Access/Start Authorization (J518)
Label file: | DRV\5Q0-959-435.clb
Part number SW: 3Q0 959 435 N, Hardware: 3Q0 959 435 N.
Part number: VWKESSYMQB, 037 1307.
Revision: 00037000 Serial Number: 0531453939
Encoding: 032C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D6A95F652900D320C-8010
Address 08: Climate Control/Heating Unit (J255)
Label file: | DRV\5G0-907-044.clb
Part number SW: 5E0 907 044 BB, HW: 5E0 907 044 BB.
Component: Climatronic
Part number: H04 2201
Revision: 00001K00
Encoding: 02010004000110011005004800101026
ASAM Dataset: EV_ACClimaBHBVW37X 006150
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 66944ED338EF2BCBC96-8032
Control unit for the fresh air blower (front).
Refrigerant pressure/refrigerant temperature sensor:
Air quality sensor:
Address 09: Central Electronics (J519)
Label file: None.
Part number SW: 5Q0 937 084 DG
Part number HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H40 0312
Serial number: 01001929200459
Encoding: 0000000000000000000000000000000
Operating number: WSC 12345 123 12345
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 0058784B3A8BE5FB53A-8054
Wiper motor control unit:
Subsystem 1 - Part number: SW: 5E1 955 119 A, HW: 5E1 955 119, Label file: DRV\5QX-955-119-V1.CLB
Component: WWS371 190927 051 0916
Serial number: 887353F0401927002719.
Encoding: 065DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 C, HW: 5Q0 955 547 C, Label file: DRV\5Q0-955-547.CLB.
Component: RLHS 051 0206
Serial number: S4Y19M10D22H19M57S09.
Encoding: 07885D
Steering column switches:
Subsystem 3 - Part number SW: 5Q1 953 507 AG HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000014101904400174
Address 10: Parking Assist 2 (J446) Label file: | DRV\5Q0-919-294.clb
Part number SW: 5QA 919 294 G, HW: 5QA 919 294.
Component: PDC 8-channel, part number H08 0061.
Serial number: 000150058319299
Encoding: 0471151051
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 50F8880BAA6BD57B83A-8004
Address 13: Distance Control (J428)
Label file: 3Q0-907-572.clb
Part number SW: 5Q0 907 572 P, HW: 3QF 907 572 A.
Part: ACC BOSCH MQB H11 0682
Encoding: 3300604149FFC728949C810520400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D0B45B6E1339DB372-8010
Address 15: Airbag (J234) Label file: | DRV\5Q0-959-655.clb
Part number SW: 3Q0 959 655 CM, HW: 3Q0 959 655 CM.
Part: Airbag VW21, Part Number: 006 0720.
Revision: -------- Serial Number: 003Z2PLKH4MK
Encoding: 98CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B425F6703CDB6A3368-805E
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 454 003 009 19
Component: SideSensor_Df 008 0887
Serial number: 3570000000015055404$
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 454 000 510 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000FC7A47F33
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: ----------- HW: 454 801 210 19
Component: SideSensor_Dr 301 0148
Serial number: 3510041B3101A000000.
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 454 802 709 19
Component: SideSensor_Pr 301 0148
Serial number: 35200F973B719000000T
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 454 800 610 19
Component: FrontSensor_D, Part Number: 304 0149.
Serial number: 35500CA81131A000000G
Encoding: 2D2D2D
Address 17: Control panel module (J285)
Label file: | DRV\5G0-920-XXX-17.clb-SRI3
Part number SW: 5E0 920 790 A, HW: 5E0 920 790 A.
Part: KOMBI 509 1711
Encoding: 05A50A186D840008018872031001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001031
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 26140ED3F86FEBCB096-8072
Address 19: Diagnostic Interface (J533)
Label file: | DRV\3Q0-907-530-V1.clb
Part number SW: 3Q0 907 530 AC, HW: 3Q0 907 530 C.
Component: GW MQB High, Part Number: 442 4388.
Revision: -------- Serial Number: 0000284140
Encoding: 030100047F08570021100252100F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 70B8288B0A2BF57BA3A-8024
Generator:
Component: 5-01-14-01-04
Control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 3V0 919 719 F, HW: 3V0 919 719 F.
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000C0568221019
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003001910230612
Address 2B: Steering column lock. (J764) Label file: * DRV\5Q0-905-861.clb
Part number SW: 2Q0 905 861 A, Hardware: 2Q0 905 861 A.
Component: ELV-MQBB H08 0021
Serial number: 19000297363001
Encoding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 313EED8FC1A1BC73EC4-8064
Address 42: Door Electric Driver (J386) Label file: * Bypass failed!
Part number SW: 5Q4 959 593 K, HW: 5Q4 959 593 K.
Component: TSG FS 007 0485
Serial number: 0000394304200
Encoding: 00110920D000020000001100
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 4DC6917FBD59F893E8C-8018
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q0 959 407 A, HW: 5Q0 959 163.
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000035217893
Encoding: 010200
Address 44: Steering Assist (J500)
Label file: | DRV\5Q0-909-144.clb
Part number SW: 5Q0 909 144 AB
Part number HW: 5Q0 909 144 AA
Part number: EPS_MQB_ZFLS 131 1082.
Encoding: 11170000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B0249B7E33C95B472-8020
Address 4B: Multifunction Device (J745) Label file: | 3Q0-907-338-V2.clb
Part number SW: 3Q0 907 338 E, HW: 3Q0 907 338 E.
Component: FCM MQB Low, part number: 003 0367.
Serial number: 26101910803149
Encoding: 000000070900046200003D01010000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372AD3972FC56243A20-8062
2 error codes found:
0037 - Data bus for front light.
U12EB 00 [009] - Excessive build-up detected.
[CAN_AFS_multiple_plug_LED_Leimo_identified]
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 5
Lost Count: 16
Mileage: 11,242 km
Date: 2020.09.19
Time: 18:53:04
0032 - Headlights
C107E 54 [137] - no default setting.
Warning light ON - confirmed - checked since last reset.
Error priority: 2
Error frequency: 1.
Lost Count: 16
Mileage: 11,242 km
Date: 2020.09.19
Time: 18:53:04
Address 52: Door electric, passenger side (J387) Label file: * Bypass due to error!
Part number SW: 5Q4 959 592 K, HW: 5Q4 959 592 K.
Component: TSG BFS 007 0485
Serial number: 0000394542406
Encoding: 00110120DC00020000001100
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 4CC09C7B4643F19BFF2-8018
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q0 959 408 A, HW: 5Q0 959 164.
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000035130801
Encoding: 190200
Address 5F: Information Selection. I (J794) Label file: * None.
Part number SW: 565 035 864 Hardware number: 565 035 864
Component: MU-S-N-ER H41 0478
Serial number: SKZAZ2W1099654
Encoding: 03730201FF00000041110004000802002F0208E401200400CF
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 5AEC6A23FC979F2B7DE-800E
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5E0 919 605 M, HW: 5E0 919 605 M.
Component: ABT_Std-2_Nav H61 8214
Serial number: SKZ6ZHW3061941
Storage devices:
Subsystem 2 - Part number SW: 5L0 051 236 BJ Hardware: -----------
Component: ECE AS 2020 --- 1310
Serial number: --------------------
Address 6C: Rear view camera (J772)
Label file: | DRV\5Q0-980-556.clb
Part number SW: 5Q0 980 556 B, HW: 5Q0 980 556 B.
Component: RVC Compact, Part Number: H18 0231.
Encoding: 0473020122002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392ED5AF19D17433544-806C
Address 6D: Rear hatch (----)
Label file: | DRV\7N0-959-107.clb
Part number SW: 5E0 959 107 B, HW: 5E0 959 107
Component: HDSG Module H01 0747
Revision: 42001003 Serial number: 289900051
Encoding: 1233074002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462.rod
VCID: 2B02FFE7E38DD6A3D68-807E
Address A5: Front/Forefield Camera (R242)
Label file: | DRV\3Q0-980-65X-A5.clb
Part number SW: 3Q0 980 654 L, HW: 3Q0 980 654 A.
Component: MQB_B_MFK H12 0610
Serial number: 23101915P22102
Encoding: 0203070200000401002213448140A90094000E20000000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D8B84B7A0B25FB13A-8014
Address BB: Door electronics, rear left.
unavailable
Address BC: Rear right door electronics.
unavailable
Address D6: Left lighting control 2 (A31)
Label file: 7P5-941-591.clb
Part number SW: 7P5 941 591 AJ, HW: 7P5 941 591 A.
Component: LED1L H07 0011
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 0450745B2E93F9DB772-8050
Address D7: Right-hand lighting control 2 (A27)
Component: LED1R H07 0011
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End --(Duration: 01:50, Battery voltage start/end: 11.8V/11.8V. Minimum voltage: 11.7V)---
Log-TMBJR7NE2L0088867.txt
 File name:  Log-TMBJR7NE2L0088867.txt
 File size:  1.33 KB
 Downloaded:  431 times
Translated on 05-09-2026, 19:50.
Post19-09-2020, 20:05    Subject: High Beam Error: Coding Issues & Fixes Quote
This is the gateway device list, not an Autoscan.
Ranug
2019 Skoda Octavia
Post19-09-2020, 20:15    Subject: High Beam Error: Coding Issues & Fixes Quote
I hope this is correct now.
Best regards, Gunar.
vag-driver
dieselschrauber likes this.
Post19-09-2020, 21:11    Subject: High Beam Error: Coding Issues & Fixes Quote
What did you want to encode? Hopefully, you saved the original encoding so you can revert to it.
Viele GrĂŒĂŸe
Andreas
*** Ein Ingenieur muss vordenken. Wenn er anfÀngt nachzudenken ist es schon zu spÀt. ***
Translated on 05-09-2026, 19:51.
Ranug
2019 Skoda Octavia
Post19-09-2020, 21:13    Subject: High Beam Error: Coding Issues & Fixes Quote
hi
I wanted to code the high beam assist feature. I reverted the coding to the original settings.
vag-driver
Post19-09-2020, 21:21    Subject: High Beam Error: Coding Issues & Fixes Quote
What exactly did you want to code?
Viele GrĂŒĂŸe
Andreas
Ranug
2019 Skoda Octavia
Post19-09-2020, 21:25    Subject: High Beam Error: Coding Issues & Fixes Quote
To enable the automatic high beam assist.
vag-driver
Post20-09-2020, 21:39    Subject: High Beam Error: Coding Issues & Fixes Quote
Where do you get the information about what needs to be coded? How do you know that the coding is correct for your vehicle?
If you are expecting help here, we need precise information.
Viele GrĂŒĂŸe
Andreas
Translated on 05-09-2026, 19:52.
Ranug
2019 Skoda Octavia
Post20-09-2020, 21:48    Subject: High Beam Error: Coding Issues & Fixes Quote
I obtained the coding from the internet. It's supposed to be compatible with the vehicle, or it worked for other models.
Post21-09-2020, 21:19    Subject: High Beam Error: Coding Issues & Fixes Quote
Ranug wrote:
I got the coding from the internet. It matches the vehicle...
It definitely doesn't fit!
Code:
Adresse 4B: Multifunktionsstg. (J745) Labeldatei:| 3Q0-907-338-V2.clb
Codierung: 000000070900046200003D01010000000000000000000000000000000000
2 Fehlercodes gefunden:
0037 - Datenbus Frontlicht
U12EB 00 [009] - Mehrverbau erkannt
bestĂ€tigt - geprĂŒft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
FehlerprioritÀt: 2
FehlerhÀufigkeit: 5
VerlernzÀhler: 16
Kilometerstand: 11242 km
Datum: 2020.09.19
Zeit: 18:53:04
Something doesn't seem right.
Coding ...709... (Red mark)
I only know the encodings 0, 1, 2, and 3 for the digit "9".
The "Leimo" (power module) error is coded as "7". You need to know exactly which model is installed.
"7" represents (as far as I remember) the largest "Leimo plus" LED module.
Code:
Adresse 09: Zentralelektrik (J519) Labeldatei: Keine
Codierung: 000000000000000000000000000000000000000000000000000000000000
That also seems a bit strange to me.
A module without coding?
Unfortunately, I can't verify that, as I have an MQB platform, but my central locking system is called PQ37.
Translated on 05-09-2026, 19:53.
Ranug
2019 Skoda Octavia
Post23-09-2020, 18:56    Subject: High Beam Error: Coding Issues & Fixes Quote
Hello Bertil,
Here is the Autoscan I performed when I first got the VCDS. The error code 709 is also listed there.
Scan-TMBJR7NE2L0088867-20200703-2006-7211km.txt
 File name:  Scan-TMBJR7NE2L0088867-20200703-2006-7211km.txt
 File size:  15.93 KB
 Downloaded:  385 times
Translated on 05-09-2026, 19:54.
Post23-09-2020, 19:38    Subject: High Beam Error: Coding Issues & Fixes Quote
Hello.
Address 09: Central Electronics (J519) Label file: None.
Part number SW: 5Q0 937 084 DG, hardware: 5Q0 937 084 CF.
So, if the previous post you made contains the original Autoscan data, then the "0000000..." sequence is very strange.
However, you also didn't have a label file for the control unit. Possibly, something is generally not quite right.
Please download the updated version 20.4.2 of VCDS and check what coding options are displayed for the body control module.
Generally, when it comes to "coding guides" on the internet, they can be useful for finding ideas. However, most of these "guides" are so general that they don't really apply to your specific vehicle model. There are many different control units, control unit configurations, and installation variants. Therefore, such "guides" are often useless, and you should not blindly copy numbers
not.
However, you can use LCode to check if the values in the documentation make sense, or whether the desired behavior can be achieved in a different way.
Translated on 05-09-2026, 19:56.
Ranug
2019 Skoda Octavia
Post23-09-2020, 20:12    Subject: High Beam Error: Coding Issues & Fixes Quote
Hello Rainer,
Here's a full scan using the latest version of VCDS. Nothing has changed.
Scan-TMBJR7NE2L0088867-20200921-1742-11259km.txt
 File name:  Scan-TMBJR7NE2L0088867-20200921-1742-11259km.txt
 File size:  16.89 KB
 Downloaded:  372 times
Translated on 05-09-2026, 19:58.
Post24-09-2020, 22:48    Subject: High Beam Error: Coding Issues & Fixes Quote
Your error lies in the fact that modules D6 and D7 are not registered. They need to be registered within the 4B module.
Sorry, I didn't notice that at first.
@Rainer
The thing about the 0000... coding seems to actually work with MQB BNSTs. icon_redface.gif icon_question.gif
Translated on 05-09-2026, 19:59.
Ranug
2019 Skoda Octavia
Post24-09-2020, 22:59    Subject: High Beam Error: Coding Issues & Fixes Quote
Hello Bertil,
No problem icon_smile_thumb_up.gif.
How can I register for the modules in the 4b module?
Translated on 05-09-2026, 20:00.
Post24-09-2020, 23:10    Subject: High Beam Error: Coding Issues & Fixes Quote
Under "Adaptation" (10), there should be an entry in the list labeled "Lighting Control Panel" (separated for left and right). This needs to be set to "yes" for both the left and right sides.
Unfortunately, there will be Channel 1 and Channel 2. Now you just need to know which channel your module is connected to. In my case, it's Channel 2.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error 01279 after attempting to encode an HHA On-Board Diagnostics (OBD)
No new posts High beam assist matrix error Electrical Systems, Vehicle Electronics, Multimedia
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
