Audi A6 Allroad: Two Tire Sizes Available
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Ste.Bo
Karma: +89 / -0   Thank you, like it!
dieselschrauber likes this.
Post21-10-2020, 18:42    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Hello everyone,
I can't find anything using the search function.
My Allroad has a second set of tire sizes programmed into it and is adjusted for the 225/65 R17 AT3 (All-Terrain) tires, which it received instead of winter tires when it was originally delivered.
The speedometer always worked correctly, and it had the advantage that I could use large 19-inch tires as summer tires without having to change them seasonally. But now, that's exactly the question!
How do I switch from the second tire size to the first one?
Unfortunately, this is the first time I'm taking the car to the TÜV (technical inspection) with the standard tires because all my other tire sets are worn out. The overly zealous inspector noticed that two very large wheel and tire combinations are registered but not currently installed, and he asked me if I wouldn't need a speedometer recalibration for the standard tires.
"To that, I replied, no, because I have two sets of tire circumference values coded in." Then, when I tried to show him (on the AVL tester) which circumferences were entered and how to switch between them, I completely drew a blank.
Zu Hause angekommen habe ich mit VCDS nachgesehen. Situation:
- In STG 17, a second pair is encoded.
- However, in the vehicle registration document (Fahrzeugschein), I only find the middle and maximum wheel circumference values for the first axle, with the values specified for the standard tire size. (MWB 29-0 = 2065 & MWB 29-1 = 2106)
- The speedometer shows a certain speed with standard tires, but when driving at 100 km/h, the GPS indicates a whopping 12 km/h less than what the speedometer displays, especially when using worn-out AT3 tires.
So:
1. In which technical manual can I find the 2168 (average) and 2212 (maximum) values for the second set of tire circumferences?
2. How do I change the tire rotation when changing tires?
Maybe I completely misunderstood something, and I'm always happy to learn more.
Best regards.
Translated on 08-08-2026, 17:15.
Post21-10-2020, 18:57    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Hi Bo,
It should involve coding within the instrument cluster (control unit address 17).
As far as I know, depending on which of the two tire sizes is fitted, either a value is added or subtracted. The encoding is essentially a bitmask.
I might be able to tell you more using Autoscan.
When you hover the mouse cursor over the encoding input field, a tooltip appears with information about the old encoding function.
Instead, your instrument cluster likely has a long coding sequence; simply click through the options in the LCode menu.
Translated on 08-08-2026, 17:18.
Ste.Bo
Post21-10-2020, 20:37    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Thank you for the quick response!
Unfortunately, no long-form coding is possible.
Theoretically, when using the standard coding procedure, you would need to enter +8 for the second tire size setting. I understood that this setting indicates there are two tires of a certain size, but that the actual value is adjusted elsewhere. However, I'll try entering -8 and see if it then displays the correct speed on the speedometer.
Somewhere, those different values must be stored within the MWB system. I'm going crazy trying to figure this out.
Translated on 08-08-2026, 17:20.
Ste.Bo
Post21-10-2020, 21:20    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Autoscan, screenshots of the coding menu, customization options, and vehicle data sheet (VDS).
I would have expected the second set of data to be found in MWB sections 29-3 and 29-4. I'm also not sure where or how to enter these values.
 File size:  104.5 KB
 Viewed:  979 times
 File size:  195.02 KB
 Viewed:  968 times
 File size:  179.44 KB
 Viewed:  1132 times
Log-WAUZZZ4F38N023476-268980km.txt
 File name:  Log-WAUZZZ4F38N023476-268980km.txt
 File size:  18.7 KB
 Downloaded:  576 times
Translated on 08-08-2026, 17:21.
Post21-10-2020, 21:30    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Switching via coding +0008: second tire circumference pair, or not.
Have you already searched for terms like "second" or "tire" within the measurement values? You can type them into the search bar at the top of the list.
Perhaps it's also possible to simply switch between two fixed wheel circumferences?
VCDS Version: DRV 19.6.1.0
Translated on 08-08-2026, 17:22.
Ste.Bo
Post22-10-2020, 0:30    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Best regards, Rainer
Now that I have it at home, because of the data, then I'll do it if you insist. But my youngest VAG vehicle is from 2014. I guess it probably doesn't matter anyway. icon_wink.gif
Translated on 08-08-2026, 17:23.
vag-driver
Post22-10-2020, 12:12    Subject: A6 Allroad: Two Tire Sizes Explained Quote
Ste.Bo wrote:
Unfortunately, this is the first time I'm taking the car to the TÜV (technical inspection) with the standard tires because all my other tire sets are worn out. The overly zealous inspector noticed that two very large wheel and tire combinations are registered but not currently installed, and he asked me if I need a speedometer recalibration for the standard tires.
Tire and wheel combinations are only permitted (and can be registered) if...
1. The rolling circumference is identical to the standard configuration.
2. A speedometer calibration is required, which will then allow the standard combination to be implemented.
"Given this, I don't understand the examiner's objection. Does your rolling circumference differ significantly from the combinations you are driving, or which combinations are registered?"
Andreas
Translated on 08-08-2026, 17:25.
Ste.Bo
Post22-10-2020, 15:31    Subject: A6 Allroad: Two Tire Sizes Explained Quote
Given this, I don't understand the examiner's objection. Does your declared rolling circumference differ significantly from the combinations you are driving, or which combinations are registered?
Yes, it's very different!
- The smallest registered tire size is the original M&S 215/55R17 with a circumference of 2032 mm.
- The largest registered dimension (recorded at delivery, with reference) is 2212 mm.
The speedometer is correct for the larger tire size. However, no speedometer calibration was performed; instead, a second tire size was specified and activated by the dealer. According to this dealer, this is possible up to a mileage of 100 kilometers using the workshop tester.
However, it seems that an error occurred because the return path does not work.
Now, with the original summer tires (size 225/55R17), it displays a value that is far too low. With the 215s, it would be even lower.
Translated on 08-08-2026, 17:28.
Herbert, Turbinchen, vag-driver and Ste.Bo likes this.
Post22-10-2020, 16:01    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Hi Bo,
So, your AI coding is 7273058.
Relevant to the tire issue is 7273, which breaks down into 4096 + 2048 + 1024 + (0 * 512) + (0 * 256) + (0 * 128) + 64 + 32 + (0 * 16) + 8 + (0 * 4) + (0 * 2) + 1.
So, the second tire combination is currently active. To activate the other one, you need to subtract 8, which means that 7265 is the new first part of the code.
The complete code is then: 7265058.
"Have you checked that yet? It's tricky because only the first 4 digits are a bitmask, so simply subtracting 8 from the entire encoding won't work..."
Translated on 08-08-2026, 17:31.
Ste.Bo
Post23-12-2020, 0:25    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Hi Bo,
Relevant for the tire issue is 7273, which breaks down into 4096 + 2048 + 1024 + (0 * 512) + (0 * 256) + (0 * 128) + 64 + 32 + (0 * 16) + 8 + (0 * 4) + (0 * 2) + 1.
Hello Rainer,
sorry für die späte Rückmeldung es hat nicht funktioniert. Ich habe es beim anderen Allroad in der Familie probiert, da geht das umschalten problemlos. IcI have given up.
Best regards and Merry Christmas.
Translated on 08-08-2026, 17:33.
Post23-12-2020, 17:17    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Thank you for the feedback! It would also be interesting to know if the other Allroad is programmed in the same way.
Translated on 08-08-2026, 17:35.
Ste.Bo
Post30-12-2020, 19:01    Subject: Audi A6 Allroad: Two Tire Sizes Available Quote
Thank you for the feedback! It would also be interesting to know if the other Allroad is coded in the same way.
The other one has an AAC codec, mine doesn't, so it's encoded differently anyway.
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Second ECU for Experiments: A Guide On-Board Diagnostics (OBD)
No new posts Timing Belt Failure: VW Golf V - Twice in 2 Years? Diesel Engine Technology
No new posts Audi A6 2.5 TDI: Logbook, 2005, Allroad, Tip Upload
No new posts Audi A6 2.5 TDI Allroad: Logbook, Tips & Tricks Upload
