Replacing bi-xenon projectors with D2S for proper lighting
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Steffen W
Karma: +104 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-09-2018, 11:46    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Yesterday, I took a small step in that direction. I purchased and installed Evo XR 1.0 projectors from retrofitlabs.com. It went quite well. There was also the Evo XR 2.0 version available at the same price, which is supposed to be even brighter. However, there were some uncertainties regarding the compatibility of the 2.0 version.
The installation went pretty well. I didn't have to drill, file, or anything like that. The flap for adjusting the high and low beams is working, and the automatic headlight range adjustment is still functioning. And the lenses are seated exactly in the designated hole in the headlight, not 5mm behind (which would have been the case with the 2.0 models because they are shorter).
The initial configuration was roughly as follows:
- Osram Nightbreaker Unlimited D2S and Osram Nightbreaker Laser H7, additionally for the high beam headlights.
-The condition of the reflectors was excellent. (They are original but not highly polished chrome, just matte.)
- Condition of the headlight lenses is also excellent. No yellowing or anything like that.
- Clean the lens.
- New Hella ballasts.
The subjective perception of the light could be described as "quite okay" or "so-so." The high beam was actually pretty good.
It looks like this now:
- Aharon Evo XR 1.0 Bi-Xenon projectors (with highly chrome-plated reflectors and other lenses).
-Philips Xtreme Vision Gen2 D2s, +150% brightness.
- Philips Racing H7 bulbs, providing an additional +150% brightness for your high beam headlights.
Subjektives Empfinden nach Umbau:breites Grinsen.Oder 300% mehr Licht.Gefühlt natürlich. {icon_biggrin.gif icon_smile_thumb_up.gif
Regarding the bulbs, I stuck with models that comply with the German Road Traffic Licensing Regulations (StVZO). However, I chose the most powerful models they currently offer. I've had mostly unsatisfactory experiences with the X-tremeVision 1 D2S and, before that, the Philips Ultra Blue D2S. That's why I tried Osram last year.
Now I've decided to trust Philips again.
Reason: When comparing the two reflectors alone, it becomes clear that it is pointless to compare light sources based on the stated percentage of additional light output. Or, read reviews on retailer websites about these light sources.
The dull reflector doesn't really achieve much, and you can also put an Osram Blue Cool bulb in the chrome housing, which would likely still provide excellent illumination even in the rain.
I'm saying that it's not always just the burner that's the problem, but also other factors, like the projector itself. And the ones I've refurbished are still in very good condition. There are also some that are completely dull, yellowed, rusted, etc. You could even put in incredibly powerful 8500k burners, and you still wouldn't see anything.
 aufgeblendet
 File size:  997 KB
 Viewed:  807 times
 abgeblendet
 File size:  994.85 KB
 Viewed:  810 times
 alter und neuer Reflektor im Vergleich
 File size:  1.04 MB
 Viewed:  869 times
 Innnenleben Xenonscheinwerfer
 File size:  1.03 MB
 Viewed:  1012 times
 ausgewählte Leuchtmittel
 File size:  1.02 MB
 Viewed:  857 times
 neue Projektoren ausgepackt
 File size:  1 MB
 Viewed:  844 times
 neue Projektoren eingepackt
 File size:  1.02 MB
 Viewed:  822 times
Passat Variant BGW 2005
Translated on 09-07-2026, 14:17.
Karma: +1102 / -0   Thank you, like it!
Post15-09-2018, 14:30    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Only why are the turn signal lights orange and not silver?
Translated on 09-07-2026, 14:21.
Steffen W
Post15-09-2018, 17:42    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Because tastes differ.
The oranges are fulfilling their purpose.
 File size:  1016.39 KB
 Viewed:  805 times
Post15-09-2018, 21:02    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Certainly, these things also light up. But if you're already using light to highlight something... icon_wink.gif
Steffen W
Post16-09-2018, 7:07    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
I have some experience with headlight issues when driving at night, but not much with silver-colored turn signal bulbs.
Steffen W
Post16-09-2018, 7:18    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
I know you enjoy experiments with light. Maybe you'd like to take a look at this. They also have those turn signal bulbs in an LED version. Personally, I wouldn't go for that. And to make matters worse, the price is also a factor. But as I said, tastes differ, and everyone has their own hobbies. And it doesn't cost anything to look.
https://www.retrofitlab.com/de/led-lampe/py21w-bau15s-led-2.html
Translated on 09-07-2026, 14:22.
Post17-09-2018, 12:37    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
So far, I haven't had anything in my hands that could be used as a replacement for the turn signal and brake lights – something that could provide sufficient brightness. Within my circle of friends, we have two VW T5.2 vehicles equipped with LED daytime running lights and LED reversing lights. The latter are a real improvement. Both T5 owners are anglers, and they can now see very well thanks to the increased brightness of the reversing lights.
I've also installed these on my Smart and my Swift. Both only have a single reversing light, and the one on the Smart didn't produce much light. The one on the Swift produced more light, but it's located deep in the rear bumper, so it had very limited range. Both are now usable for their purpose with the LED lights; at least you can see something. On the two T5.2s, the rear lights are now incredibly bright.
Translated on 09-07-2026, 14:23.
haithamina
Post18-09-2018, 8:09    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
I also prefer bright lights for my car.
Looking at the two photos showing the street and surrounding area illumination, I prefer the top one (before). It provides a more even and wider illumination, and it extends higher in the distance. The bottom option has very bright spots directly in front of the car, which are likely to be distracting to your eyes when looking into the distance, and may not effectively illuminate objects or people close to the car.
Haithamina.
Translated on 09-07-2026, 14:25.
Post18-09-2018, 10:00    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
You seem to have overlooked the fact that the photos were overexposed and underexposed.
Steffen W
Post19-09-2018, 5:50    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
That's how it is. On and off.
Tomorrow, the SW (presumably referring to some kind of system or equipment) will be reconfigured because I had expanded it. After that, I'd be happy to take some more pictures.
Compared to before, this is still a big difference. Let's see how it performs in the rain.
Translated on 09-07-2026, 14:26.
haithamina
Post19-09-2018, 6:08    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Hutfahrer wrote:
You apparently overlooked the fact that the photos were overexposed and underexposed.
You're right, I missed that!
Thank you.
I am unable to translate "haithamina" because it does not appear to be a word or phrase in the German language. It may be a misspelling, a proper noun, or a term from a specialized field. If you can provide more context or clarify the intended meaning, I would be happy to assist you with the translation.
Translated on 09-07-2026, 14:27.
Steffen W
Post03-11-2018, 13:14    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Okay, friends, I've made a small update. After I finished the conversion, Osram came out with the new Nightbreaker Laser D2S. As you know, I couldn't resist and I converted it again, and adjusted the headlights. There was a significant improvement, especially with the low beam. The illumination is no longer so spotty, but nicely even. If the question ever comes up again about which bulb is currently number 1 on the market, my answer is clear. I'm very satisfied. icon_biggrin.gif
 abgeblendet
 File size:  58.2 KB
 Viewed:  456 times
 Fernlicht
 File size:  101.44 KB
 Viewed:  454 times
Steffen W
Post15-05-2019, 7:19    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
So Freunde,das Material für das nächste Upgrade habe ich beisammen.Demnächst kommen Morimoto Vorschaltgeräte mit 50W Leistung statt der üblichen 35W zum Einsatz.Ebenso der neue Osram Brennner D2S Cool Blue Boost."The CBB" heisst sie in Szenekreisen. icon_biggrin.gif
I'm very excited to see what comes out of this. Hopefully, the high performance won't affect the color of the light.
 File size:  85.71 KB
 Viewed:  410 times
 File size:  100.06 KB
 Viewed:  378 times
Translated on 09-07-2026, 14:28.
Post22-05-2019, 9:59    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
35W bulb on a 50W controller?
Will it last long? I'm looking forward to hearing reports icon_wink.gif.
Translated on 09-07-2026, 14:29.
Steffen W
Post22-05-2019, 17:08    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Sicherlich werden die Brenner kein biblisches Alter dann mehr erreichen.Aber da ja regelmässig die bekannten Premiummarken mit neuen Superbrennern auf den Markt kommen,habe ich die sowieso nicht bis sie hinüber sind.icon_smile.gif
The projectors have already been replaced. The EVO XR models are supposed to handle heat quite well.
Maybe I'll build it this Saturday.
Steffen W
Post30-05-2019, 5:45    Subject: Replacing bi-xenon projectors with D2S for proper lighting Quote
Everything is installed. The English word "bright" came to mind immediately after I flipped the light switch.
The light color is a bright white. This is certainly due to the 50W drivers. A CBB with 35W would have a slight bluish tint.
The pictures speak for themselves. No mouse can hide anymore. And it wasn't even completely dark when the pictures were taken. I like it very much.
 aufgeblendet
 File size:  133.2 KB
 Viewed:  320 times
 abgeblendet
 File size:  106.24 KB
 Viewed:  317 times
Translated on 09-07-2026, 14:30.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Light warning buzzer no longer works after renovation KI Transmission, Chassis, Body & Interior
No new posts Summer Light: Capturing the Perfect Glow Transmission, Chassis, Body & Interior
No new posts No Light: A Dark and Mysterious Tale Diesel Engine Technology
No new posts Electrical Lighting: Solutions & Ideas Transmission, Chassis, Body & Interior
