VW Auxiliary Heater Not Working - Troubleshooting
Go to page: 1, 2  Next
georgmech
Post17-02-2021, 19:32    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
The Seat Alhambra 7N does not have a built-in auxiliary heating function.
The error memory indicated a short circuit in the temperature sensor, which were replaced. I was able to clear the error codes, but the function still doesn't work.
I can start the auxiliary heater in workshop mode, and there are still no error codes stored. The heater is unlocked; it's a Webasto wiring harness with a remote control. The ventilation fan turns on, but the water pump and the heater itself do not activate.
Does anyone have an idea? What should be connected to pin 1 of the cable that connects to the heating device? This cable comes from inside.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 22-10-2026, 3:22.
Back to top Profile PM Email
Ich_Can_nix
dieselschrauber likes this.
Post17-02-2021, 20:28    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Good evening.
I'm trying to learn more about your auxiliary heater.
The first thing that comes to mind spontaneously when there are no errors stored and the ventilation turns on is the summer mode!
Is the system set to recirculation mode / summer operation? If so, the heating will not turn on.
Otherwise, I would appreciate it if you could tell me more about the car. Ideally, just provide the car's scan data.
The flame sensor is located on pin 1.
Michael.
Translated on 22-10-2026, 3:24.
Post17-02-2021, 20:52    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
... and please initiate a full system scan.
Translated on 22-10-2026, 3:25.
georgmech
Post17-02-2021, 22:15    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
It is a Seat Alhambra 7N CFF 2.0 103 kW, manufactured in 2013.
Wednesday, February 17, 2021, 10:15:04 PM: 44616
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 20.12.0.3
Data as of: 20210211 DS322.1
www.Ross-Tech.de
Vehicle Identification Number: VSSZZZ7NZDV517172. License plate: [space for license plate]
Vehicle type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 22 25 2E 36 37 42 44 46 4C
4F 52 53 55 56 61 62 69 6C 6D 72 BE BF
Mileage: 138,960 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
High Beam Assist -- Status: OK 0000
22-All-wheel drive -- Status: OK 0000
Immobilizer system -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-seat adjustable passenger seat -- Status: OK 0000.
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
4C Tire Pressure II -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Brightness adjustment. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
6C Rear-view camera -- Status: OK 0000
6D tailgate -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
Rear left sliding door -- Status: OK 0000.
Rear right sliding door -- Status: OK 0000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module (J623-CFFB)
Label file: .DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 NE
Part number HW: 03L 906 018 M
Component: R4 2.0l TDI, H28 9978.
Revision: 44H28--- Serial number:
Encoding: 0019001A043601080000
Operating number: WSC 05219 605 00000
ASAM Dataset: EV_ECM20TDI01103L906018NE 003011
ROD: EV_ECM20TDI01103L906018H_VW36.rod
VCID: 7AFDA9D4FD7111544E-802E
No error codes found.
Readiness: 0 0 0 0 1
Address 03: Brake Electronics
Label file: 7N0-614-109.clb
Part number SW: 7N0 614 109 P. Hardware: 7N0 614 109 P.
Component: J104 C3 450M VD07 0030
Revision: --H07--- Serial Number: 00000006851090
Encoding: 0019073
Operating number: WSC 00020 790 00000
VCID: 3A7D69D475F1D1540E-806E
Address 08: Climate Control/Heater (J255)
Label file: | DRV\5K0-907-044.clb
Part number SW: 7N0 907 044 J, Hardware number: 7N0 907 044 J.
Component: Clima-Sharan H01 0303.
Revision: 00001K03
Encoding: 0210104549
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_ClimatronicSharan A01005
ROD file: EV_ClimaAutoSharaBasis.rod
VCID: 377B70E08EE3CC3CF1-8062
Slave 1:
Subsystem 1 - Part number SW: 7N0 907 049 B, HW: 7N0 907 049 B.
Component: KBT-H 004 0102
Serial number: 20130408000000111575.
Address 09: Central Electronics (J519)
Label file: .DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 086 M, Part number HW: 5K0 937 086 M.
Component: BCM PQ35 M 021 0068
Revision: BC021001
Encoding: 40590A3B89251AC0508800C87400896443559388636D2F626484C72000C1
VCID: 3E7565C4A9D9FD7432-806A
Subsystem 1 - Part number SW: 7N1 955 119 A, HW: 7N1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 130320 31 0032
Serial number: 130402115200
Encoding: 004DBD
Subsystem 2 - Part number SW: 7N0 955 559 HW: 7N0 955 559 Label file: DRV\7N0-955-559.CLB
Component: RLFS 021 0024
Serial number: Y13M04D08H00M33S13S1
Encoding: 0280DD
Address 10: Parking Assist 2 (J446) Label file: | DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 A, HW: 7N0 919 475
Part: PARKING ASSIST 8K H06 0012
Revision: -------- Serial Number: 28231309504209
Encoding: 318002
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 397F76D8B8F7DA4C07-806C
Address 15: Airbag (J234) Label file: | DRV\5K0-959-655.clb
Part number SW: 7N0 959 655 C, HW: 7N0 959 655 C.
Part number: VW10Airbag004 H12 0014
Serial number: 003LGP6UAC2$
Encoding: 003034
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3F8B18C0A6D3F47C39-806A
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60AC52C5179D0
Encoding: 000000
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Left --- ---
Serial number: 3503ETS6030ACC1179DR
Encoding: 000000
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60DB33C2179DY
Encoding: 000000
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Right --- ---
Serial number: 3523ETS60871DC1179DX
Encoding: 000000
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS602015C517DDA
Encoding: 000000
Address 16: Steering Wheel Electronics (J527)
Label file: | DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 BA, HW: 5K0 953 569 H.
Component: STEERING MODULE 016 0140
Revision: FF010041 Serial number: 20130409101832
Encoding: 118A240000
Operating number: WSC 00020 999 00000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6ADD99948DD1A1D4BE-803E
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 1P0 959 538 D, HW: 1P0 959 538 D, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TAP H02 0103
Encoding: E20000
Address 17: Control panel module (J285)
Label file: | DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 7N5 920 870 G, HW: 7N5 920 870 G.
Component: KOMBI H05 0715
Serial number: 00000000000000
Encoding: 141F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3B736CD0B2CBE85C15-806E
Address 18: Auxiliary heater
Label file: DRV\1K0-815-071.clb
Part number: 7N0 963 271 E
Component: Auxiliary Heater 051 2940
Revision: 00051000 Serial Number: 09024297000000
Encoding: 0000011
VCID: 36657DE441E93534EA-8062
Address 19: Diagnostic interface (J533)
Label file: .DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 AH, HW: 7N0 907 530 AH.
Component: J533 Gateway H50 1634
Revision: H50
Serial Number: 070413F1000337
Encoding: 468202
VCID: 76E5BDE4C16975342A-8022
Address 20: High Beam Assist (J844)
Label file: .DRV\8K0-857-511.clb
Part number SW: 7N0 857 511 P, HW: 8P0 857 511 C.
Component: FLA H04 0012
Revision: AA001002
Encoding: 0201816B74745D545420363E01
VCID: 40891B3CD32D8B8440-8014
Address 22: All-wheel drive
Label file: DRV\0AY-907-554-V1.clb
Part number SW: 0AY 907 554 E, Hardware number: 0AY 907 554 E.
Component: Haldex 4Motion, part number 0043.
Encoding: 0000005
Operating Number: WSC 00000 000 00000
VCID: 4D973208D47F56ECBB-8018
Address 25: Immobilizer (J334)
Label file: | DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0715
Serial number:
Encoding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
Address 2E: Media Player 3 (J650) Label file: .DRV\5N0-035-342.lbl
Part number SW: 5N0 035 342 F, Hardware: 5N0 035 342 F.
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial Number: 7664560647
Encoding: 020100
VCID: 2A5D5994455161D47E-807E
Address 36: Seat adjustment for driver (J810)
Label file: 3C0-959-760.lbl
Part number SW: 3C8 959 760 C. Hardware: 3C8 959 760 C.
Component: Seat Memory. Part Number: H05 2901.
Revision: 00H05000
Coding: 000018
Operating number: WSC 12336 024 394758.
VCID: 35677AE89CEF3E2CE3-8060
Address 37: Navigation (J794)
Label file: | DRV\1K0-035-27x-37.clb
Part number SW: 5P0 035 191 N, Hardware: 5P0 035 191 N.
Part number: RNS315-EU H59 0321
Serial number: SEZAZ2N0228667.
Encoding: 040004010400240000061001
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 36657DE489E93534EA-8062
Storage media:
Subsystem 1 - Part number: 3AA 919 866.
Component: EUR_W_V4 0050
Address 42: Door electrical driver (J386) Label file: 7N0-959-793.clb
Part number SW: 7N0 959 793 G, HW: 7N0 959 793 G.
Component: TSG FA H03 0553
Revision: Serial number: 0000056907911
Encoding: 01112E209E00411001
VCID: 46850D24F109A5B47A-8012
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 P, HW: 5N1 909 148 J.
Component: J500__APA-BS, Class 325, 1202.
Revision: 1BH04737 Serial Number: 00130800123801
Coding: 0000258
VCID: 3F8B18C06ED3F47C39-806A
Address 4F: Central Electrics II (J520)
Label file: .DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 7N0 907 530, AH: [untranslated]
Component: EZE_2 H50 1634
Revision: H50
Encoding: 050B0500
VCID: 6FEB8880BE3344FCE9-803A
Subsystem 1 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Component: J245EE20SKB13 H05 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part number SW: 8R0 959 591 A, HW: 8R0 959 591.
Component: J394EE20SKB13 H05 0220
Address 52: Power door lock, front passenger side (J387) Label file: 7N0-959-792.clb
Part number SW: 7N0 959 792 G, HW: 7N0 959 792 G.
Component: TSG BF H03 0553
Revision: Serial number: 0000056397673
Encoding: 01112C209E00411001
VCID: 45870A28CC0FAEAC73-8010
Address 53: Parking brake
Label file: DRV\3AA-907-801.clb
Part number SW: 3AA 907 801 H HW: 3AA 907 801 H
Part number: J540 EPB4 VW-86594 0010
Revision: H19 Serial Number: 00000000872471
Encoding: 0024167
Address 55: Headlight range control (J745) Label file: .DRV\5M0-907-357-V3.clb
Part number SW: 5M0 907 357 F, HW: 7L6 907 357 C.
Component: AFS-ECU H04 0111
Revision: -------- Serial Number: --------------
Encoding: 068A00000B000000
Operating number: WSC 00020 999 39850
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
Left headlight power output stage:
Subsystem 1 - Part number: 1T0 941 329 B
Label file: 3D0-941-329.CLB
Right headlight power output stage:
Subsystem 2 - Part number: 1T0 941 329 B. Label file: 3D0-941-329.CLB.
Address 61: Battery Management (J840) Label file: .DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 7N0 907 530, AH: 7N0 907 530.
Component: Battery management system H50 1634.
Serial number: 070413F1000337
Encoding: 330F7859
VCID: 71EF8EF8A807520CFF-8024
Subsystem 1 - Part number SW: 1K0 915 181 H, HW: 1K0 915 181 A.
Component: J367-BDM H07 0180
Serial number: 40095I17061491190598
Address 62: Door electric, left/right (J388) Label file: .7N0-959-794.clb
Part number SW: 7N0 959 794 J, HW: 7N0 959 794 H.
Component: TSG HL H01 0556
Revision: Serial number: 0000057146854
Encoding: 01006C200000411001
Operating Number: WSC 21644 002 1048576
VCID: 4A9D3914E51141D49E-801E
Address 69: Trailer (J345) Label file: .DRV\7N0-907-383.clb
Part number SW: 7N0 907 383 HW: 7N0 907 383
Component: Trailer H09 0120
Revision: 3I001003 Serial Number: 00008160089143
Encoding: 410C040001000000
VCID: 73E384F0D21B601C0D-8026
Address 6C: Rear-view camera
Label file: DRV\5N0-907-441.clb
Part number SW: 7N0 907 441 HW: 7N0 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial Number: 525 PA8J331797
Encoding: 0030011
VCID: 6ED5958479394DF4E2-803A
Address 6D: Rear door (----)
Label file: | DRV\7N0-959-107.clb
Part number SW: 7N0 959 107 E, HW: 7N0 959 107 A.
Component: HDSG Module H11 0243
Revision: 41011001 Serial Number: 074300636
Encoding: 0733334003
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door electric strike, high, right (J389) Label file: .7N0-959-794.clb
Component: TSG HR H01 0556
Revision: Serial number: 0000057146914
Operating number: WSC 21644 002 1048576
Address BE: Rear left sliding door (J558)
Label file: 7N0-959-244.clb
Part number SW: 7N0 959 244 B. Part number HW: 7N0 959 244 B.
Component: Sliding door_l 005 2414
Serial number: 13103660.
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 387973DC83FDC344F8-806C
Address BF: Rear right sliding door (J731)
Part number SW: 7N0 959 244 B, HW: 7N0 959 244 B.
Component: Sliding door_r 005 2414
Serial number: 13114747
ROD: EV_AST.rod
End----------------------------(Duration: 04:39)-----------------------------
Translated on 22-10-2026, 4:12.
georgmech
Post17-02-2021, 22:29    Subject: Screenshot: How to, Tutorial, and Examples Quote
Perhaps this will help.
Post17-02-2021, 22:40    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
If the error log shows nothing after a failed attempt to start the heater, it's reasonable to assume that no start attempt actually took place.
Has the auxiliary heater ever functioned as a standing heater?
I can start the auxiliary heater in workshop mode, and I still don't have any error codes stored. The heater is unlocked; it's a Webasto wiring harness with a remote control. The ventilation turns on, but the water pump and the heater itself do not activate.
Not that some smart person installed the wiring harness for the auxiliary heater, but they forgot to properly flash the auxiliary heater. icon_razz.gif
There are also ways to do it without flashing the device, but these methods use an intermediary electronic component and, for example, the Webasto clock to control it.
What exactly is installed?
As a supplementary heater, it starts (if nothing else is configured) at a temperature below 5°C when the engine is started.
Translated on 22-10-2026, 4:13.
dieselschrauber and Duese likes this.
Post17-02-2021, 22:45    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
And what does the aforementioned summer mode say?
Depending on the year of manufacture, it can be adjusted either in the MFA's "STH" menu or in the "STH" menu of the radio/navigation system.
It would perfectly match your error. If the driver has set the thing to summer mode, then it will now behave properly when you press the STH button. While it's true that this doesn't make sense in winter, the software doesn't care icon_wink.gif.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 22-10-2026, 4:16.
georgmech
Post18-02-2021, 9:50    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Okay, our technician says it's a T90 (D90) remote control installed. When you turn on the heater, you see the three bars on the transmitter display. What we just noticed is that on the heater, there's an 8-pin connector, and the yellow cable is connected to pin 1. Could it be that it should be connected to pin 2? It's hard to see clearly. However, the customer, who is new, said that the heater used to work, but who knows if that's true, or if someone else has already tampered with it?
Translated on 22-10-2026, 4:17.
Ich_Can_nix
Post18-02-2021, 10:51    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Good morning.
It's definitely much easier icon_smile.gif for my Fin.
Yellow wire connected to pin 2 - correct.
Is the summer mode enabled?
Switch between heating and ventilation.
Press the ON and OFF buttons within 1 second, 2 times.
briefly activate.
The operating mode indicator changes color. The next time the remote control is used, the heating device will execute the selected operating mode until the operating mode is changed.
 File size:  174.9 KB
 Viewed:  748 times
Translated on 22-10-2026, 4:18.
georgmech
Post18-02-2021, 12:34    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Okay, I've checked again, the cable is connected to PIN 2, and the heater is set to "heat." I double-checked both to be sure. I'm not sure if the auxiliary heater is activating when the engine starts, because it's constantly too warm. Does it also work based on the coolant sensor? However, it works in workshop mode. I was even thinking about ordering a coolant sensor and spraying it with ice spray.
Translated on 22-10-2026, 4:19.
georgmech
Post18-02-2021, 13:03    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
"If there's voltage on the yellow cable, could someone have tampered with the coding? Is it possible to use VCDS to take a Screenshot of all the important settings that can be changed and send it to me?"
Translated on 22-10-2026, 4:20.
Ich_Can_nix
Post18-02-2021, 13:45    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
If it starts up in diagnostic mode, then it should be working correctly.
Otherwise, it would be interrupted and an error would be logged.
You can hear or feel the auxiliary water pump running?
Then I can think of two more possibilities:
1.) Rainer, did you install the software correctly? Is the auxiliary heater upgrade complete?
2) Which retrofit kit was installed? Is it the original Webasto or an aftermarket kit? Aftermarket kits sometimes come with a toggle switch for summer mode! - In that case, only the ventilation will work again.
Have you checked if there's an additional toggle switch installed near the fuse box?
You can also bypass the connector for the temperature sensor; if you do that, it should start.
Michael.
Translated on 22-10-2026, 4:21.
georgmech
Post18-02-2021, 15:05    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Thanks, I just disassembled the water pump and discovered that it doesn't start on its own.
If I give it a push, it runs, but it doesn't start on its own. I'm surprised that I didn't find any errors, because it should be drawing too much power if that were the case. Well, I hope it works now.
Thank you in advance for your great tips.
Translated on 22-10-2026, 4:22.
georgmech
Post18-02-2021, 18:43    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Okay, so the heating system now runs for a longer time in workshop mode, and the water pump is also running, which is new. However, the heating system still doesn't turn on with the remote control.
Could the problem be related to the wiring of the Webasto cable harness, or to the programming?
Is there anyone who can take a look at my TeamViewer issue and help me fix it, for a fee?
Otherwise, I still have three days of work left.
Translated on 22-10-2026, 4:23.
Ich_Can_nix
Post18-02-2021, 23:10    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Good evening, Georg.
We can also access your auxiliary heater remotely using TeamViewer, if necessary.
If you want to get rid of some money, you can donate it to Kinderträume e.V. Alternatively, you can buy a ticket from Rainer.
I don't want anything...
And it's also questionable whether I can actually help you through TeamViewer.
I still have a few questions, though.
Does the auxiliary heater run automatically during operation, or only in diagnostic mode? Are the auxiliary heater, water pump, and temperature sensor now functioning correctly?
What exactly does the remote control do?
Does the fan turn on, or what's happening?
How does the LED on the remote control behave?
The vehicle was delivered with a supplementary heater - if it works, it does what it's supposed to do.
Then the source of the error can be found in the retrofitted parts.
Did you mean the toggle switch? Can we rule that out?
An accessory kit includes an additional control unit in the wiring harness. Does such a control unit exist?
Is it definitely an original, built-in kit from Webasto?
Which pin does the yellow cable connect to on the radio receiver?
Is there a timer?
Do you have the diagnostic software from Webasto?
Do you have the original wiring diagrams for the vehicle?
Keep the issue of W and H buses in mind.
Michael.
Translated on 22-10-2026, 4:26.
georgmech
Post18-02-2021, 23:22    Subject: VW Auxiliary Heater Not Working - Troubleshooting Quote
Thank you for everything. The heater has a defect in the control unit, which is strange. I now received a used one and installed it. Then, following your instructions, I configured it using VCDS, and it started up immediately. It seems like the electronics in the old heater had no connection to pin 2, because it's as if it didn't want to turn on at all.
Translated on 22-10-2026, 4:28.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: Troubleshooting Guide (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater Upgrade for Parking Heaters Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater for Audi A4 2.5 Qtip Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater Conversion to Stand Heater On-Board Diagnostics (OBD)
No new posts Auxiliary Heater Unlock for Parking Heater On-Board Diagnostics (OBD)
