Can TPMS sensors be programmed with VCDS?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
stolley
Karma: +38 / -1   Thank you, like it!
Post07-07-2024, 15:03    Subject: Can TPMS sensors be programmed with VCDS? Quote
Hello everyone,
I've already searched the forum for relevant terms, but I haven't found anything.
I have a new used vehicle with tires that have TPMS (Tire Pressure Monitoring System). It's the first time I've had something this modern! icon_wink.gif
I guess these sensors need to be paired, especially when you buy the wheels online, like I'm planning to do. Question: Can I do that with VCDS?
Volker.
Karma: +796 / -0   Thank you, like it!
Post07-07-2024, 18:24    Subject: Can TPMS sensors be programmed with VCDS? Quote
Hello.
It's important that the sensors are compatible with the vehicle, as there are different frequencies and protocols.
Autoscan?
Warning: Taking an old wheel as a spare tire and installing it in the original wheel position may lead to confusion with the new wheel.
stolley
Post07-07-2024, 20:28    Subject: Can TPMS sensors be programmed with VCDS? Quote
Thank you very much, Rainer!
I'll definitely try Autoscan sometime soon!
Volker.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wie Lenkwinkelsensor neu anlernen? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi R8 Gen 2 Steering Wheel Alignment with VCDS On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts PDE anlernen? On-Board Diagnostics (OBD)
No new posts WFS anlernen On-Board Diagnostics (OBD)
