Unlock code adjustments, brake control unit, ESP, Mark 60
lwltdi
Post31-03-2021, 8:24    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
Hello friends,
I am looking for the unlock code for the customization options in an MK60E1 control unit, such as the one used in an Audi RS3 8P. I upgraded to ceramic brakes, and unfortunately, the brake disc wipers are now very noticeable. I would like to disable them (adaptation channel 55).
Perhaps someone can help me and send me a private message.
Post31-03-2021, 9:07    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
Do you have a vehicle diagnostic scan?
lwltdi
Post31-03-2021, 10:03    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
Here is the current log.
Log-ME-INS 3-WUAZZZ8P.txt
 File name:  Log-ME-INS 3-WUAZZZ8P.txt
 File size:  14.18 KB
 Downloaded:  808 times
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post31-03-2021, 17:10    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
Hello, and good day.
I cannot provide you with the login code.
However, I would like to give you the following piece of advice.
The ceramic brake system is slightly less powerful than the standard brake system when it is cold. To take advantage of the benefits of ceramic brakes, they need to reach a certain temperature.
Disabling the "brake disc wiping" feature essentially means sacrificing the full braking performance – at least for the first few meters. The purpose of the wiping function is primarily to remove the water film. It should be barely noticeable.
If you notice it very clearly, or if it feels disturbing, the problem is likely located in the brake calipers or the brake block.
What modifications have you made to the vehicle?
Only replaced with different pads and rotors?
Org. Audi or ATE, etc.?
Of course, new parts were installed. Can we rule out a broken window?
Are counterweights installed?
(In some current vehicles, it can also be subtly noticeable and is considered state-of-the-art. - again, there is no customer-facing solution here.)
Michael.
lwltdi
Post31-03-2021, 22:41    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
Hello Michael,
"The usefulness of this feature is definitely debatable, but I don't want to argue about it or start a discussion about it. My problem is that the ceramic braking system installed wasn't a standard option, so the associated components aren't compatible with the programming for the brake disc drying function. I will carefully monitor the braking performance in the rain and then decide whether to leave it deactivated or reactivate it." However, I need the login code to make the change.
Mpire and Ich_Can_nix likes this.
Post02-04-2021, 18:09    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
I and others have thought about everything again.
I don't personally have the login code, but I could request it.
The problem is that you can then adjust all sorts of things, and I'm also concerned about the lack of proper wiping, especially regarding adhesion and the risk of accidents.
What if you're involved in an accident, and then someone says, "If he hadn't tampered with the brake settings, the accident wouldn't have happened."
That gives me a stomachache, so I won't do it.
Do your pads fit the rotors? Does the manufacturer recommend this pairing?
If the friction material is too hard for the brake disc, it can quickly lead to a grooved disc, especially if you're unlucky.
PS: I once installed the ATE Ceramic brake pads with the aim of reducing brake dust. Did not prove successful.
lwltdi
Post03-04-2021, 8:18    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
I installed the original complete ceramic brake system from the subsequent 8v model.
Since I will only be driving this vehicle and I will pay close attention to its behavior in the rain, I personally don't see any problem. Especially since I would also be liable in the event of an accident... I would appreciate it if you could send me the code, preferably via private message.
Post03-04-2021, 10:54    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
The problem is that this braking system is not standard equipment for the vehicle and is therefore not approved. You would need to have the system, including the control unit (STG), inspected and approved. And the STG modification is likely only available from the vehicle manufacturer.
A VW workshop probably won't even adjust the wiper function without an entry in the system.
lwltdi
Post03-04-2021, 10:59    Subject: Unlock code adjustments, brake control unit, ESP, Mark 60 Quote
The topic can be closed. Thank you for the feedback.
No new posts Backup encodings and adjustments with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Basic settings for Teves Mark 20 IE / MK20 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Basic Settings for ABS/ESP Teves Mark 60 / MK60 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake System Coding Removed On-Board Diagnostics (OBD)
No new posts Inspection Coding & Adjustments On-Board Diagnostics (OBD)
No new posts ABS Mark 20i: ECU Reprogramming Issues On-Board Diagnostics (OBD)
No new posts VAG-COM Interface by Mark Neugebauer cannot connect On-Board Diagnostics (OBD)
