Boost pressure control error, HELP
Go to page: 1, 2  Next
Kalle81
Post31-01-2023, 19:20    Subject: Boost pressure control error, HELP Quote
I have an Amarok with the CDCA 2.0 Bi-TDI engine.
He's throwing the following error:
5294 - Charge pressure control.
P154F00 (039) - Malfunction.
I have already tested the boost pressure sensor and the mass airflow sensor, and the readings are okay.
In the initial inspection, I checked the turbocharger, the bi-turbocharger, and the EGR system, and everything was in good working order.
He only throws the aforementioned error when testing the boost pressure control.
It doesn't generate any boost pressure; in fact, when you accelerate while the engine is idling, the value displayed by the boost pressure sensor, located before the intake manifold, actually drops slightly below atmospheric pressure.
I have checked the vacuum hoses, and the turbine blades of both turbos also show no abnormalities.
According to VCDS, the calculated amount of ash in the DPF is approximately 20 grams.
I hope you can help me; I'm not a fan of just randomly exchanging things.
I can't find anything about this error online either.
Karma: +807 / -0   Thank you, like it!
Post31-01-2023, 19:46    Subject: Boost pressure control error, HELP Quote
Autoscan?
Karma: +649 / -0   Thank you, like it!
dieselschrauber likes this.
Post31-01-2023, 20:08    Subject: Boost pressure control error, HELP Quote
Is the intercooler ducting printed?
Kalle81
Post31-01-2023, 20:39    Subject: Boost pressure control error, HELP Quote
Tuesday, January 31, 2023, 17:54:26:45078
VCDS, a Windows-based VAG/VAS emulator, now runs on Windows 11 x64.
VCDS Version: DRV 22.10.0.1
Data as of: 20221111 DS344.0
shop.dieselschrauber.org
Vehicle Identification Number: WV1ZZZ2HZB8069570 License Plate:
Mileage: 176,530 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 2H-VN81 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 56 69
Mileage: 176,530 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
69 followers -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CDCA) Label file: . DRV\03L-906-022-CAA.clb
Part number SW: 03L 906 019 FC, HW: 03L 907 309 K.
Part: R4 2.0l BTD H40 9978
Revision: 26H40--- Serial number: 00000000000000 CVN: 7FDAF74D
Encoding: 01194012232600080000
Operating number: WSC 55851 001 1048576
ASAM Dataset: EV_ECM20BTD01103L906019FC 004006
ROD: EV_ECM20BTD01103L906019FC_004.rod
VCID: 71EE5301A0190C057D-8024
VINID: 9E606AAAA098A9220018914700C3FFF1AE
"1 error found:"
5249 - Charge pressure control.
P154F 00 [039] - Malfunction.
unconfirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1
Mileage: 176,536 km
Date: 2023.01.31
Time: 03:15:35
Motor speed: 2799.00 RPM.
Normalized load value: 26.3%
Vehicle speed: 0 km/h
Coolant temperature: 85 °C
Intake air temperature: 33 °C
Ambient air pressure: 950 mbar.
Voltage at terminal 30: 14.040 V.
Lost count after OBD: 40
Boost pressure: Target value: 1348 hPa.
Boost pressure: Actual value: 916.2 hPa.
Air mass: Actual value (mg/stroke): 461.3 mg/stroke.
Air filter contamination level: 0.00%
Throttle valve positioner: Actual value: 99.96%.
Bypass valve for turbocharger, high-pressure turbine inlet: Actual value: 4.83%.
Average injection amount: 6.38 mg/stroke.
Readiness: 1010 0000
Address 03: Brake Electronics (-----)
Label file: 2H0-907-37x-ESP.clb
Part number SW: 2H0 907 379 G, HW: 2H0 907 379 D.
Component: ESP MK25A XT H44 0106
Revision: 00H44001
Encoding: C07324B69A9A039E24A759AA6F5010
Operating number: WSC 07456 790 49164
VCID: 34609A15978B792D56-8060
No error codes found.
Address 08: Climate Control/Heating Module (J255) Label file:| DRV\7E5-907-040.clb
Part number SW: 2H0 907 040 D, Part number HW: 2H0 907 040 D.
Part: Climatronic T5 H11 0304
Revision: 00002001
Encoding: 0000000002
Operating number: WSC 07456 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN81.rod
VCID: 224C6C4D357FE79DB4-8076
"1 error found:"
9478145 - Control of the front fresh air blower.
B10A0 01 [009] - Electrical fault.
Error priority: 2
Error frequency: 1
Lost Count: 149
Mileage: 176,536 km
Date: 2023.01.31
Time: 03:17:19
Address 09: Central Electronics (J519)
Label file: . DRV\6R0-937-08x-09.clb
Part number SW: 6R7 937 087 H HW: 6R7 937 087 H
Component: PQ25 BCM H12 0022
Revision: -1------ Serial Number: 1002480801
Encoding: 240002380C010000003008003C0A04C40080412E600000003000
Operating Number: WSC 32345 000 1048576
VCID: 499EDBE1E00914C515-801C
Subsystem 1 - Part number SW: 6R0 959 801 M, HW: 6R0 959 801 M, Label file: 6R0-959-801.CLB.
Part: J386__TSG_FT 002 3321
Serial number: --------------------
Encoding: 100000
Subsystem 2 - Part number SW: 6R0 959 802 P HW: 6R0 959 802 P Label file: 6R0-959-802.CLB
Part: J387__TSG_BT 002 3325
Encoding: 000000
Subsystem 3 - Part number SW: 6R0 959 811 D, HW: 6R0 959 811 D.
Part: J388__TSG_HL 002 3321
Encoding: 100000
Subsystem 4 - Part number SW: 6R0 959 812 D, HW: 6R0 959 812 D.
Part: J389__TSG_HR 002 3321
Encoding: 100000
Address 10: Parking Assist 2 (J446) Label file:| DRV\7E0-919-475.clb
Part number SW: 7E0 919 475 B, HW: 7E0 919 475.
Component: PARKHILFE 4K H10 0010
Revision: -------- Serial Number: 24531100503048
Encoding: 118003
Operating number: WSC 95555 115 65579
ASAM Dataset: EV_VW75XParkAssis4K A01005
ROD: EV_VW75XParkAssis4K_A01.rod
VCID: 316E930160994C053D-8064
Address 15: Airbag (J234) Label file:| DRV\5K0-959-655.clb
Part number SW: 2H0 959 655 B, Hardware number: 2H0 959 655 B.
Part number: VW10Airbag00B H06 0013
Revision: -------- Serial Number: 003HN002YS5Q
Encoding: 0000000000000000000000000000000
Operating number: WSC 07446 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 336299099A857E154F-8066
Crash sensor for driver-side side airbag:
Serial number: 3495RRB40570BTBED12B
Crash sensor for side airbag, passenger side:
Serial number: 3505RRB40670BTBEKPB1.
Crash sensor for front airbag, driver's side:
Serial number: 3555YRB405P08IF88GO6
Crash sensor for front airbag, passenger side:
Serial number: 3565YRB406505BDSOGOC
Address 17: Terminal block insert (J285) icon_neutral.gif Label file: DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 2H0 920 863 A, HW: 2H0 920 863 A.
Component: COMBINATION UNIT H05 0304
Encoding: 150A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 275A7D595E5D02B5E3-8072
Address 19: Diagnostic interface (J533)
Label file: . DRV\6N0-909-901-6R.clb
Part number SW: 6N0 909 901, HW: 6R7 937 087 H.
Component: GW-K-CAN TP20 0022
Revision: -1
Encoding: 742200
VCID: 70E85605A313050D72-8024
Address 25: Immobilizer (J334) Label file:| DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0304
Serial number:
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADC446D8DCFFFDD3C-803E
Address 37: Navigation (J794) Label file:| DRV\1K0-035-27x-37.clb
Part number SW: 3C0 035 279 HW: 3C0 035 279
Component: RNS315 H05 0010
Serial number: VWZAZ2L3338041
Encoding: 000004110200000000031000
ASAM Dataset: EV_RNS315VWEUV1UDS A01005
ROD: EV_RNS315VWEUV1UDS.rod
VCID: 60C826457BF3B58DE2-8034
Address 69: Trailer (J345) Label file: . DRV\1K0-907-383-V2.clb
Part number SW: 1K0 907 383 F, HW: 1K0 907 383 F.
Part: Trailer H09 0100
Revision: 3A001001 Serial number: 00000151690017
Encoding: 0100000100000000
VCID: 306896056393450D32-8064
Ende----------------------------(Duration: 01:5icon_cool.gif-----------------------------
Kalle81
Post31-01-2023, 20:41    Subject: Boost pressure control error, HELP Quote
The intake air path, from the air intake to the turbocharger and then to the intake manifold, has been inspected.
Post31-01-2023, 22:17    Subject: Boost pressure control error, HELP Quote
On the back of the engine, a corrugated pipe (AGR) runs from the exhaust manifold/turbine inlet side of the turbocharger.
If it's broken or detached, the engine not only smells terrible when it's idling, but the superchargers also won't receive any power.
You need a lift platform to reach it.
Kalle81
Post31-01-2023, 23:23    Subject: Boost pressure control error, HELP Quote
I've already checked that as well, and it's fine.
What's surprising is that I'm not getting any error messages like "boost pressure below the limit."
I searched online for the error, but I didn't find anything really useful.
Karma: +1359 / -0   Thank you, like it!
Post01-02-2023, 6:24    Subject: Boost pressure control error, HELP Quote
You're not saying anything about the performance under load. Could you also record the boost pressure from the start, at idle, under partial load, and at full load?
If, for example, the compressor bypass malfunctions, you'll get too little air into the engine when idling or under light load. That's just a thought that came to mind while reading the bi-turbo description from VW.
Does the wastegate function (close) properly?
Kalle81
Post01-02-2023, 11:39    Subject: Boost pressure control error, HELP Quote
It drives like a naturally aspirated diesel engine.
Where should the bypass valve for the compressor be located? I'm only familiar with this valve from the T5 Biturbo, and I couldn't find any information about it for the Amarok.
The wastegate is closed. I removed the particulate filter and inspected it because one of my initial suspicions was a stuck or broken flap.
I'd be happy to log the boost pressure while driving this afternoon, once I've managed to reassemble it.
Post01-02-2023, 14:56    Subject: Boost pressure control error, HELP Quote
It could be complete nonsense, but I remember seeing a video from "Auto Doktoren" where a T5 or T6 had similar problems, and the cause was the small turbocharger not generating any pressure.
As I said, it might be nonsense.
Kalle81
Post01-02-2023, 15:20    Subject: Boost pressure control error, HELP Quote
The impeller on the small turbocharger is easy to turn and exhibits no significant play.
Post01-02-2023, 16:07    Subject: Boost pressure control error, HELP Quote
The same thing happened in the video, unfortunately, but no cause was mentioned.
Post01-02-2023, 19:12    Subject: Boost pressure control error, HELP Quote
It's possible that the bi-turbo systems differ between the T5 and the Amarok. I could only review this topic in two technical service bulletins (TSS), one for the T5 and one for the EA288 engine. And even in the latter, there is a vacuum-controlled bypass (wastegate) on the exhaust side for each of the two turbines, and a bypass for the high-pressure compressor. And the error could be located in one of these three components.
Do you have a charging schedule? Please send a picture for reference. Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
Kalle81
Post01-02-2023, 23:17    Subject: Boost pressure control error, HELP Quote
Okay, so I took out the bypass valve today, and it was fine; it wasn't stuck or anything like that.
I only have a single SSP (Software Control Unit) from a T5 2.0 BiTDI.
The structure appears to be identical.
The large turbocharger has a wastegate, while the smaller one is connected via a valve in the exhaust manifold.
Both vacuum cups are working, and the rods move smoothly.
Post01-02-2023, 23:37    Subject: Boost pressure control error, HELP Quote
Take a look at the air mass setpoint and actual values to rule out any leaks. It's best to create a log. icon_idea.gif
Kalle81
Post02-02-2023, 1:58    Subject: Boost pressure control error, HELP Quote
I compared the LMM values at standstill and during operation, and nothing unusual was observed.
I will drive again tomorrow and log the boost pressure and mass airflow sensor values.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf AJM Error 17958: Troubleshooting & Photos On-Board Diagnostics (OBD)
No new posts Turbocharger Problems: Troubleshooting & Repair Upload
No new posts 1.4 TDI Turbocharger Problem: Boost Control Error 17964 Diesel Engine Technology
No new posts TDI Timing Help: Strange Error Message? On-Board Diagnostics (OBD)
