Concealing wavy metal - T6 tailgate
Post15-10-2021, 22:14    Subject: Concealing wavy metal - T6 tailgate Quote
"While reversing with my T6, I bumped into something in the rear. Now, it's questionable whether the lower edge of the tailgate can be dented enough to make the damage less visible."
Does anyone have any ideas for hiding something?
 File size:  304.25 KB
 Viewed:  375 times
dieselschrauber likes this.
Post16-10-2021, 6:23    Subject: Concealing wavy metal - T6 tailgate Quote
Hi Rainer,
That's a real shame. "Smart Repair" can work wonders if done correctly. I had a dent in the roof of my Audi 80, about the size of my hand, and it was inaccessible from the inside. There was the bicycle, with the pedal that had fallen off.
She completely and permanently disappeared from Bremen in just over an hour.
Just as an example, here are the reference images of the business: https://www.carstyle-bremen.de/beulenkuenstler/
There are likely similar options available to you. It would be important to see pictures of previously completed repairs beforehand. That's how you can tell if a store is any good.
Post16-10-2021, 9:22    Subject: Concealing wavy metal - T6 tailgate Quote
Hello Herbert,
Thank you for the assessment! Here are two recommendations for repair shops. Someone who knows about these things considers the dent to be "borderline." So, it's likely that we'll still see each other a bit.
That's why my idea is to stick a strip, a sticker, or some lettering above it. X
Sure, I could install a new tailgate, but I'm not really in the mood to do that right now, because various components are already installed in the old tailgate, and I'm the most familiar with them (since I installed them myself). I would have to retrofit all of that again...
Post16-10-2021, 10:00    Subject: Concealing wavy metal - T6 tailgate Quote
You know that there can be vast differences between the opinions of experts?
At the time, I had three options: Audi/VW wanted to apply filler and repaint (a large, technically competent and flawless operation); a "dent doctor" wanted to use tools to push the dent out from the side, underneath the panel, and from the inside (they could even make new cars from **** ready for delivery) - but that wouldn't have been possible due to the car's construction; and the third option (the one with the beard in the picture of the linked company) used suction cups (glued on?).
What is visible on your tailgate might, in my admittedly non-expert opinion, be fixable without any painting.
The bumper cover and the underlying structure are likely damaged; you'll need to inspect the metal underneath. I would definitely try to save the tailgate; it's certainly better than having a new part painted and installed later.
Sure, here's the translation:
"Best regards."
Post16-10-2021, 10:04    Subject: Concealing wavy metal - T6 tailgate Quote
I'm sorry, but I can't translate that. It appears to be a single character, and I don't have enough context to understand its meaning or purpose. Could you please provide more information or the full text you want me to translate?
vag-driver
Post25-10-2021, 15:58    Subject: Concealing wavy metal - T6 tailgate Quote
Okay. I assume it's going to be an insurance claim that will be covered by the other party. Therefore, I would insist on a new, original VW rear hatch and accept the time it takes for the modifications.
Andreas
No new posts Tapping noises, Audi A3 8P rear hatch/trunk lid Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Problems: Tailgate/Rear Door Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clanging metal from the wheel arch? Transmission, Chassis, Body & Interior
No new posts Does the A6 C4 Avant rear door fit the rear door? Transmission, Chassis, Body & Interior
No new posts Golf 5/A3 Control Arms - Cast/Steel Transmission, Chassis, Body & Interior
No new posts Rear hatch Transmission, Chassis, Body & Interior
