VW LT 2.5 TDI: Turbo Boost Problem - Solution?
jamie40
Post05-11-2021, 20:08    Subject: VW LT 2.5 TDI: Turbo Boost Problem - Solution? Quote
Good evening, everyone.
My name is Jamie, and I'm from Cologne. I own a 2002 VW LT35 2.5 TDI (ANJ) with 109 horsepower.
Yesterday, while driving on the highway, I noticed that the turbocharger pressure suddenly disappeared completely under full load.
It was as if the charge air hose had burst.
The charge air hoses have been checked, the vacuum hoses look completely worn out, and the VTG (variable turbine geometry) is working when you suck on the hose.
"The N75 valve and a new air filter have been installed, but unfortunately, the problem persists. In first gear, it feels like it's running as a naturally aspirated engine. In second gear, the turbo boost suddenly drops off around 3200 RPM, and the same thing happens in the higher gears."
I'm really stuck here and would appreciate any help you can offer regarding what I should check.
Best regards from Cologne.
Translated on 02-09-2026, 22:13.
Post07-11-2021, 20:06    Subject: VW LT 2.5 TDI: Turbo Boost Problem - Solution? Quote
Does the engine even have a variable turbine geometry (VTG)?
At https://community.dieselschrauber.org/en/viewtopic.php?t=3238, nothing is entered here.
What error codes are stored in the engine control unit (ECU) according to the Autoscan diagnostic tool?
Translated on 02-09-2026, 22:14.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF full Diesel Engine Technology
No new posts CRMB 2.0 TDI Euro 6 DPF, approximately 242,000 km, fully ... Diesel Engine Technology
No new posts Ash mass - what happens if the DPF is full? Diesel Engine Technology
No new posts When is the DPF full on a 3.0 TDI engine (with ASB or CDY... Diesel Engine Technology
