Largo98
26-09-2021, 14:02 Subject: VW Polo: Cylinder Head Torque Specs & Data |
After replacing the valve cover gasket on my Polo with the 1.4 TDI engine (engine code BWB, year of manufacture 2008), it still isn't sealing properly even after tightening it by feel. I would like to try again using a new gasket and the correct torque specifications.
Can someone provide the specified tightening sequence and corresponding torque values?
Thank you very much.
Translated on 11-08-2026, 4:27.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
Largo98 likes this. |
26-09-2021, 16:38 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Quote: | | Can someone explain the prescribed order of suits | ?
in several stages, crossing over each other, as is always the case with parts that have a certain spatial extent.
I would estimate the torque to be around 10 Nm based on my experience. For more precise information, please contact Erwin; downloading or printing the relevant repair manuals will be worthwhile.
Translated on 11-08-2026, 4:29.
Profile PM WWW Garage |
Largo98
26-09-2021, 18:07 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Thank you for the quick response.
Where can I find the repair manuals?
Translated on 11-08-2026, 4:30.
26-09-2021, 19:15 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Repair manuals are available from Erwin (see the error database).
Ich_Can_nix Profi-Schrauber
dieselschrauber likes this. |
27-09-2021, 0:20 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Good evening.
As the boss correctly suspected...
10 Nm
First, tighten all the screws by hand.
First, tighten both screws at the top, then tighten the remaining screws from the inside out in a crisscross pattern to the specified torque. Use a socket adapter with a Torx T 30 bit (part number T-10347).
Michael.
Translated on 11-08-2026, 4:31.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
27-09-2021, 0:23 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Normally, the valve cover will seal properly if you tighten it carefully in several stages... so don't try to fully tighten it all at once during the first tightening.
Small beads of sealant (silicone sealant, see RLF) should be applied to the four corners where the ZK section meets the NW storage area. The bonding surfaces must be free of grease. After assembly, it is recommended to wait a few hours before putting the system into operation.
I would also check the VD for cracks.
Translated on 11-08-2026, 4:32.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
12-10-2021, 5:08 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Hi there!
I've experienced this more than once: the cylinder head cover was warped and simply wouldn't seal properly.
Best regards, Rüdi.
Translated on 11-08-2026, 4:33.
Profile PM Garage |
jarobaldu Profi-Schrauber
24-11-2021, 12:37 Subject: VW Polo: Cylinder Head Torque Specs & Data |
Hi there,
It was the same for me.
/viewtopic.php?t=28189&highlight=cylinder head cover
Best regards.
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 11-08-2026, 4:34.
