Error 01279 after attempting to encode an HHA
Florian320
2004 Audi Cabriolet
Post27-11-2021, 10:21    Subject: Error 01279 after attempting to encode an HHA Quote
Dear forum members,
I tried to code the hill-hold assist feature on a gasoline-powered Skoda Yeti (not 4WD).
The owner was aware that it might not work due to the possible lack of a suitable sensor, as the corresponding control unit does not always have a longitudinal acceleration sensor installed.
After the encoding process was completed, error code 01279 appeared. A data block for longitudinal acceleration could not be read, which led me to conclude that the sensor is likely not installed.
I then changed the encoding of the SG to exactly match the old encoding. However, even after that, the error code 01279 still appeared, even after deleting everything.
Did I do something wrong, or do I need to "delete" the sensor somewhere?
Translated on 18-07-2026, 17:42.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber likes this.
Post27-11-2021, 23:35    Subject: Error 01279 after attempting to encode an HHA Quote
Good evening, Florian,
Could you please provide us with a complete vehicle scan? That would allow us to identify the specific make and model of the car, as well as its features and equipment.
Error code 01279 indicates that the calibration data from the G251 is missing. If we had a FIN (Final Inspection), we could check whether the sensor is installed.
Michael.
Translated on 18-07-2026, 17:44.
Florian320
2004 Audi Cabriolet
Post29-11-2021, 11:28    Subject: Error 01279 after attempting to encode an HHA Quote
Hello Michael,
Thank you for your reply!
Attached is the Autoscan report.
Florian.
Log-MTK YE 21-TMBJJ75L7D6074841-89170km.txt
 File name:  Log-MTK YE 21-TMBJJ75L7D6074841-89170km.txt
 File size:  13.11 KB
 Downloaded:  509 times
Translated on 18-07-2026, 17:45.
Post29-11-2021, 13:44    Subject: Error 01279 after attempting to encode an HHA Quote
I would suggest checking the `coding.log` file and the adaptation log in the VCDS folder to see if you can find anything there. It's possible that a simple error occurred when writing the original coding or when reverting it.
Translated on 18-07-2026, 17:46.
Post29-11-2021, 22:29    Subject: Error 01279 after attempting to encode an HHA Quote
Just try performing a basic configuration of the G251; here's the general procedure:
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics
Lateral/Longitudinal Acceleration & Yaw Rate Sensor (G200/G202/G251)
Prerequisites:
System voltage must be at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004.
[Go!Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Check fields 2, 3, and 4 – their values must be between -1.5 and icon_smile_thumb_up.gif.5 m/s² or °/s.
[Done, Go Back]
[Security Access - 16]
Enter 40168 to activate the basic settings.
[Do it!Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
[Basic Settings - 04]
Group 061.
Activate the basic settings.
[ON/OFF/Next]
After a successful initial setup, field 2 should display "OK".
[Done, Go Back]
To ensure that the initial setup was successful, please check the sensor again.
Group 004.
[Done, Go Back]
[Close Controller, Go Back - 06]
Translated on 18-07-2026, 17:49.
Florian320
2004 Audi Cabriolet
Post30-11-2021, 8:11    Subject: Error 01279 after attempting to encode an HHA Quote
Good morning.
Thank you very much for the answers!
The encoding was definitely as desired, and after reverting the change, it was definitely back to how it was before (I had, of course, saved the original encoding and compared it at the end).
Could the missing login have been a problem?
I will definitely perform the basic setup; I had already chosen that option. Now I just need to find a suitable time slot with the client.
Here is the excerpt from the Coding.log file:
Address 03;1K0 907 379 BK;re-encoded (long encoding);from;913F200E092905FE891304E8901AA040340000;to;913F200E092905FE891304E8901AA040350000;(33361/790/00071);Thursday;25;November;2021;18:36:55:63257
Address 03;1K0 907 379 BK;re-encoded (long encoding);from;913F200E092905FE891304E8901AA040350000;to;913F200E092905FE891304E8901AA040340000;(33361/790/00071);Thursday;25;November;2021;18:42:26:63257
Translated on 18-07-2026, 17:54.
Florian320
2004 Audi Cabriolet
Post04-12-2021, 13:45    Subject: Error 01279 after attempting to encode an HHA Quote
A quick update: the error (which I originally forgot to mention) was already present before my coding attempt, but without a warning light.
Today, we were trying to perform a basic calibration, but the previous error was gone. Instead, code 01486 (ESP system function test active) appeared in the fault memory, which wasn't there before.
We weren't able to adjust the basic settings due to a lack of space (all available parking spaces were too crowded), but I hope we can do it soon, perhaps in the evening.
I will provide further updates.
Translated on 18-07-2026, 17:57.
Florian320
2004 Audi Cabriolet
Post08-12-2021, 10:36    Subject: Error 01279 after attempting to encode an HHA Quote
Good morning!
After the initial setup for the ESP was performed in a sufficiently large parking area, the error memory is now empty.
Thanks again for your help!
Translated on 18-07-2026, 17:58.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts High Beam Error: Coding Issues & Fixes On-Board Diagnostics (OBD)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
No new posts T5 GP BCM Coding: Error After Replacement? On-Board Diagnostics (OBD)
