Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic
Schmierpfote
Karma: +21 / -0   Thank you, like it!
dieselschrauber likes this.
Post27-05-2023, 13:31    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
Hello forum, the CO2 adjustment screw is located in a hole between the metering valve and the choke plate.
However, this vehicle does not have a hole; instead, there is a circular indentation in the casting.
I have read that on some vehicles, a hole is drilled for the CO2 adjustment only after the marking is made.
Can someone confirm this? Thank you for your help.
Hello Wolfgang, and have a wonderful Pentecost!
Back to top Profile PM Email
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
Post27-05-2023, 15:25    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
One thing to note, I've never heard of a KA-Jetronic...
If it is a KE-Jetronic (Continuously injecting, Electronically controlled), then an electrohydraulic pressure regulator is mounted on the metering valve.
From this pressure regulator, which functions similarly to a nozzle-impact plate system and is electrically controlled, the mixture enrichment factor varies linearly.
On the mounting arm of the flow sensor, there is a potentiometer that measures the displacement of the flow sensor and, consequently, the amount of air sucked in, and sends this information to the MSG.
D.h. a manual adjustment of the fuel mixture control screw, as was possible in a purely mechanical K-Jetronic, is not possible at all in a KE-Jetronic.
since this task now also takes over the electro-hydraulic pressure controller and the potentiometer.
Therefore, Bosch has opted out of the opening, as it is simply not necessary.
Wishing everyone who is reading this a relaxing and enjoyable long weekend.
Best regards, Richard
Polo V 1,6 Tdi (CAY)
Schmierpfote
Post27-05-2023, 16:24    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
Thank you, Richard, for your response.KA-Jetronic is purely mechanical (analog). KE-Jetronic came later. Greetings, Wolfgang.
E30_V8
Post27-05-2023, 17:21    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
According to Bosch's technical documentation, the "A" stands for "Non-driven", but this was never officially used as a designation, as all K-Jetronic injection systems
"Regardless of whether it's K-Jetronic or KE-Jetronic, the engine will feel sluggish."
In contrast, components like Kugelfischer injectors, diesel inline injectors, or VEPs are driven by the engine using a timing belt/gears.
Schmierpfote wrote:
KA-Jetronic is purely mechanical (analog). KE-Jetronic was introduced later.
E30_V8 wrote:
This means that a manual adjustment of the fuel mixture regulating screw, as was possible with a purely mechanical K-Jetronic system, is not possible with a KE-Jetronic.
Schmierpfote
Post27-05-2023, 17:42    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
Hello Richard, the Golf has a mechanical KA-Jetronic fuel injection system, manufactured in 1987, with a JH engine.
I have replaced all the brake and fuel lines, the tank, the water pump, the ZR (presumably a part), etc. The Golf belongs to a relative, and I have got it running again. I have no idea what modifications the previous owners made. Thank you, Wolfgang.
Karma: +1348 / -0   Thank you, like it!
dieselschrauber and E30_V8 likes this.
Post27-05-2023, 18:04    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
A cautious objection: We had an Audi 80B2, CC, manufactured in 1985 with 90 hp and KE-Jetronic (control unit, 4 injectors, originally with a regulated catalytic converter in the accompanying documentation). Motor likely JN.
Between the air filter and the distributor, there was an air flow meter (with a metal housing) with a valve and potentiometer, and under a metal plug, an adjustment screw that, according to Etzold, was described as an adjustment screw for idle speed and CO (?), (as far as I remember). The plug had to be drilled. I only drilled it and pulled it out with a screwed-in screw. The action at the time was actually pointless; the poor idle speed was caused by a small leak in the coolant temperature sensor and incorrect temperature measurement. I hadn't encountered "blinken" before.
Schmierpfote
Post28-05-2023, 12:02    Subject: Golf 1 Cabrio, JH Motor, Year of Manufacture 1987, KA-Jetronic Quote
Thank you for your responses.
I have taken a Screenshot. The Allen key is inserted into the hole of the CO2 screw. Greetings, Wolfgang
 File size:  1.18 MB
 Viewed:  886 times
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Cabrio 1Z Engine Problems - More Power? Diesel Engine Technology
No new posts Golf Cabrio Performance Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Window Switch VW Golf 4 Convertible Transmission, Chassis, Body & Interior
No new posts Golf Cabrio TDI: Clutch Problems & Repair Diesel Engine Technology
