Control unit or electrical system? A6 4B2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Marko
Post08-05-2022, 21:12    Subject: Control unit or electrical system? A6 4B2 Quote
Currently, my Audi A6 4B2 (year 2002) with engine code AYM is experiencing sudden and intermittent failures.
(01) MSG:
18043-P1635 Data bus drive.
Missing message from Klima SG, sporadic occurrence, 35-10.
(02) Transmission electronics:
18265-P1857 End-of-line signal.
Error message from motor SG 35-00.
18161-P1753 Switch for Tiptronic (F189)
implausible signal
(02) ABS-SG
Background:
After driving a few kilometers on the highway, the car's information system (FIS) initially displayed a warning indicating that a LWR sensor had failed. After a short pause and restarting the engine, the warning disappeared, but reappeared after driving a few more kilometers.
Upon arrival at the destination and restarting the engine:
Climate control is not working. The windshield wiper motor needs to be tapped twice to activate, then it wipes once and stops halfway on the third attempt. The Tiptronic transmission shows no response, and the gear indicator is completely red, indicating a transmission fault. The oil sensor has failed according to the instrument cluster (FIS), and the rear sunshade is not functioning.
What has been done so far:
- Disconnected the battery to perform an ECU reset (24 hours).
- Relay checked for functionality.
Still to mention:
The error in the SG transmission:
implausible signal
It occasionally disappears during the ride, and the manual "Tiptronic" mode becomes available again.
This also applies to the windshield wiper.
Am I correct in assuming that the MSG (Monosodium Glutamate) is being phased out here? I suspect this because these errors suddenly appeared. Or could it be a problem with the electrical system, perhaps a voltage issue?
Thank you!
Lieber TDI statt lahme Ente!
-A6 4B2 2.5 TDI AYM-
Translated on 13-07-2026, 2:17.
vag-driver
Post09-05-2022, 10:59    Subject: Control unit or electrical system? A6 4B2 Quote
Could you please provide us with a full scan? Also, please be sure to follow the forum rules!
Andreas
Translated on 13-07-2026, 2:21.
Marko
Post09-05-2022, 16:09    Subject: Control unit or electrical system? A6 4B2 Quote
Attached is the car scan report.
Autoscan a6 4b.pdf
 File name:  Autoscan a6 4b.pdf
 File size:  32.78 KB
 Downloaded:  635 times
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Steuergerät oder Geber defekt ? On-Board Diagnostics (OBD)
No new posts Steuergerät ??? Passt oder past nicht Diesel Engine Technology
No new posts [Poll] Steuergerät fßr AJM 115 PS Pumpe Dßse -> Chip, oder... Diesel Engine Technology
No new posts AAT Steuergerät brauche Schaltplan oder BoschNr-Hilfe On-Board Diagnostics (OBD)
