A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation
Go to page: 1, 2, 3  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
michiglaser
2007 Audi A4 Avant
Post01-08-2016, 12:34    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Hi!
Does anyone know the correct coding for the ACC (Adaptive Cruise Control) after installing a tow bar?
The system unfortunately doesn't work like that.
Thanks.
Michael
Tuesday, 26, July, 2016, 20:31:23:39738
VCDS -- Windows-based VAG/VAS emulator runs on Windows 10 x86
VCDS Version: RKS 15.7.4.1
Data Status: 20160226
Vehicle Identification Number: WAUZZZ8K5D Vehicle Registration Number:
Odometer: 167390km Repair order:
Vehicle Type: 8K (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 42 44 46 52 53 56 5C 5F 62
69 72
Vehicle Identification Number: WAUZZZ8K5D Odometer: 167390 km
01-Engine Electronics -- Status: Error 0010
02-Transmission -- Status: OK. 0000
03-Brake Electronics -- Status: OK 0000
04-Steering Angle Sensor -- Status: OK 0000
05-Access/Start Report -- Status: OK 0000
08-Climate/Heating System - Status: Error 0010
09-Main Electrical System -- Status: Error 0010
13-Distance Control – Status: Error 0010
15-Airbag -- Status: OK 0000
16-inch steering wheel electronics -- Status: OK 0000
17-Switch Panel Insert -- Status: OK 0000
19-Diagnosis Interface -- Status: OK 0000
42-door electric Driver -- Status: OK 0000
44-Steering Aid -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric Passenger. -- Status: OK. 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Error 0010
5C Lane Keeping Assist -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
62-door electric, right-hand drive -- Status: OK 0000
69 supporters -- Status: OK 0000
72-door electric high roof -- Status: OK 0000
Address 01: Engine Electronics (J623-CDUC) Label file: DRV\059-907-401-V2.clb
Part Number SW: 8K5 907 401 A HW: 4G0 907 401
Part Number: 3.0TDI EDC17 H37 0002
Revision: 53H37---
Encoding: 12254012047603020000
Operating number: WSC 06208 123 12345
ASAM Dataset: EV_ECM30TDI0118K5907401A 001006
ROD: EV_ECM30TDI0118K5907401A.rod
VCID: 2E568D74718C7F4EDC-807A
1 Error found:
4330 - Function limitation due to received error value
U1113 00 [039] - -
Unconfirmed - Checked since last deletion
Environmental conditions:
Error Status: 00000001
Error Priority: 2
Error Frequency: 1
Odometer: 167399 km
Date: 2016.07.26
Time: 20:14:39
Readiness: 0 0 0 0 1
Address 02: Transmission (J217) Label file: DRV\0B5-927-156.clb
Part Number SW: 8K1 927 156 Q HW: 0B5 927 156 F
Part Number: 0B5 30 TDIRdW H10 0007
Revision: --H10--- Serial Number: 0000000676
Encoding: 000001
Operating number: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 4380CCC0CA0EE22623-8016
No error codes found.
Address 03: Brake Electronics (J104) Label File: DRV\8K0-907-379-V1.clb
Part Number SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Part: ESP8 quattro H09 0100
Revision: -------- Serial Number: --------------
Encoding: 39DD4C
Company Number: WSC 06334 123 12345
VCID: 04020FDC8780251E5A-8050
Address 05: Access/Start Report (J393) Label file: DRV\8K0-907-064-05.clb
Part Number SW: 8K0 907 064 FE HW: 8K0 907 064 FE
Part Number: BCM2 2.0 H10 0602
Revision: 00002001
Encoding: 01A20000000000000000
VCID: 78FA6B2CCB4871FE46-802C
Subsystem 1 - Part Number SW: 8T0 959 754 D HW: 8T0 959 754 D
Part Number: FBSAUDIB8 IDG H60 0072
Address 08: Climate/Heating Control (J255) Label file: DRV\8Kx-820-043-3Z.clb
Part Number SW: 8K1 820 043 N HW: 8K1 820 043 N
Component: KLIMA 3 ZONEN H04 0036
Revision: C1000000 Serial Number: 01260420120111
Encoding: 3638028080
Operating Number: WSC 06335 123 12345
VCID: 33609C0092AE52A6B3-8066
2 error codes found:
01207 - Control unit for auxiliary heating (J364)
004 - No signal/communication
Error Status: 01100100
Error Priority: 6
Error Frequency: 1
Interchange Counter: 161
Odometer: 167399 km
Time: 0
Date: 2016.07.26
Time: 20:11:27
00457 - Control unit for the power supply network (J519)
013 - please read diagnostic trouble codes
Error Status: 01101101
Error Priority: 6
Error Frequency: 2
Odometer: 167399 km
Time: 0
Date: 2016.07.26
Time: 20:11:27
Address 09: Central Electrical (J519) Label file: DRV\8K0-907-063.clb
Part Number SW: 8K0 907 063 DH HW: 8K0 907 063 AH
Part Number: BCM1 1.0 H14 0103
Revision: 08014001 Serial Number: 00000029453401
Encoding: 26000011C134AFE20181408300001D0D4F9CE70826090201000008000401030100000024000000
Operating number: WSC 77976 150 85349
Subsystem 1 - Part Number SW: 8K1 955 119 A HW: 8T1 955 119 Label file: DRV\1KX-955-119.CLB
Component: WWS 280412 H07 0070
Encoding: 00FD11
Subsystem 2 - Part Number SW: 8U0 955 559 B HW: 8U0 955 559 B Label file: DRV\8U0-955-559.CLB
Part Number: G397_RLFS H06 0002
Encoding: 02005D
Subsystem 3 - Part Number SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part Number SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
01771 - Control unit for headlight leveling (J431)
Error Priority: 6
Error Frequency: 1
Odometer: 167399 km
Time: 0
Date: 2016.07.26
Time: 20:11:28
03608 - Humidity sensor in fresh air intake duct
014 - Defect
Error Status: 01101110
Error Priority: 3
Error Frequency: 2
Odometer: 167399 km
Time: 0
Date: 2016.07.26
Time: 20:11:31
Address 13: Distance Control (J42 icon_cool.gif Label file: DRV\8K0-907-561.clb)
Part Number SW: 8K0 907 561 B HW: 8K0 907 561 B
Part Number: ACC3 H09 0100
Serial Number: 00000000000000
Encoding: 008190
VCID: 316C960868B260B6C1-8064
1 Error found:
01044 - Incorrectly coded control unit
000 - -
Error Status: 01100000
Error Priority: 2
Error Frequency: 1
Odometer: 167399 km
Time: 0
Date: 2016.07.26
Time: 20:11:27
Temperature: 33.0°C
Voltage: 12.16 V
Hex Value: 0x005D
Speed: 0.0 km/h
Lateral Acceleration: 0.00 m/s^2
Address 15: Airbag (J234) Label file: DRV\8K0-959-655.clb
Part Number SW: 8K0 959 655 N HW: 8K0 959 655 N
Part: AirbagVW-AU10 H45 0610
Serial Number: 003KFD92NTVG
Encoding: 30514435363030303030554A304C384B3053
Plant Number: WSC 49559 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 489ADBECF328C17EF6-801C
Crash sensor for side airbag, driver's side:
Serial Number: 6334MSME6D0355106
Crash sensor for side airbag, passenger side:
Serial Number: 6344MSME6D23024EI
Side airbag sensor for rear driver's side:
Serial Number: 6352QSME3512527EG
Crash sensor for side airbag (rear, driver's side):
Serial Number: 6362QSME271305444
Crash sensor for front airbag, driver's side:
Serial Number: 63732SME52110644M
Crash sensor for front passenger airbag:
Serial Number: 63832SME57113872Y
Address 16: Steering Wheel Electronics (J527) Label file: DRV\8K0-953-568.clb
Part Number SW: 8K0 953 568 M HW: 8K0 953 568 M
Part: Steering Module H03 0004
Revision: -------- Serial Number: 90372LDI0027E
Encoding: 0000DF
VCID: 4482CFDCC700E51E1A-8010
Component: E221 - MFL H03 0003
Address 17: Relay Module (J285) Label file: DRV\8T0-920-xxx-17.clb
Part Number SW: 8K0 920 931 F HW: 8K0 920 931 F
Component: COMBINATION INSTRUMENT H35 0540
Revision: 00000000 Serial Number: NTL74JL4D
Encoding: 136F110047010008000000
Address 19: Diagnostic Interface (J533) Label file: DRV\8T0-907-468.clb
Part Number SW: 8R0 907 468 D HW: 8R0 907 468 D
Part Number: GW-BEM 5CAN-M H10 0025
Revision: 1Z070014 Serial Number: 1441Z12403005C
Encoding: 00CF07FF00
VCID: 408AC3CCD318F93E3E-8014
Subsystem 1 - Part Number SW: 8T0 915 181 HW: 8T0 915 181
Part Number: J367-BDMHella H03 8041
Subsystem 2 - Part Number SW: 8K0 959 663 HW: 8K0 959 663
Part Number: J532_DCDCStab H17 0042
Address 42: Electrical Door Driver (J386) Label file: 8K0-959-793.clb
Part Number SW: 8K0 959 793 P HW: 8K0 959 793 P
Part: TSG FA H02 0506
Revision: Serial Number: 0000028977204
Encoding: 011C02204000410001
VCID: 4D94EAF8144A2456C5-8018
Address 44: Steering Aid (J500) Label file: DRV\8K0-909-144.clb
Part Number SW: 8K0 909 144 F HW: 8K0 909 144 B
Part Number: RCEPS H36 0507
Revision: 00001000 Serial Number: 0011505732
Encoding: 100001010001
Operating Number: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X.rod
VCID: 34629F1C9FA0559EAA-8060
Address 46: Comfort System (J393) Label file: DRV\8K0-907-064-46.clb
Revision: 00002001 Serial Number: 0175560601
Encoding: 0100062020B900148120023680000000
Subsystem 1 - Part Number SW: 8K0 959 591 HW: 8K0 959 591
Part Number: J245 PS150 H08 0043
Subsystem 2 - Part Number SW: 8K0 959 591 HW: 8K0 959 591
Part Number: J394 PS240 H08 0043
Address 52: Electrical Door Passenger. (J387) Label file: 8K0-959-792.clb
Part Number SW: 8K0 959 792 P HW: 8K0 959 792 P
Part: TSG BF H02 0506
Revision: Serial Number: 0000029354243
Encoding: 011C02204C00410001
VCID: 4C92E7FCEF502D5ED2-8018
Address 53: Parking Brake (----) Label file: DRV\8K0-907-801-V2.clb
Part Number SW: 8K0 907 801 J HW: 8K0 907 801 J
Part Number: EPB-4 H01 0001
Revision: -------- Serial Number: 00000000054691
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 3666A51489DC478E94-8062
Address 56: Radio (R) Label file: DRV\4F0-035-0xx-56.clb
Part Number SW: 4G0 035 056 E HW: 4G0 035 056
Part: Radio U STD H60 0093
Revision: AB001007 Serial Number: 230D-0C7561686
Encoding: 010003020100000001
VCID: 23406C40224EC22643-8076
1 Error found:
03029 - Subwoofer (R157)
011 - Interruption
Error Status: 01101011
Error Priority: 5
Error Frequency: 1
Odometer: 167399 km
Time: 0
Date: 2016.07.26
Time: 20:11:29
Voltage: 12.10 V
Address 5C: Lane Departure Warning. Label file: DRV\8T0-907-217.clb
Part Number SW: 8T0 907 217 HW: 4E0 907 217 C
Part Number: J759 HC 0020
Revision: 00H08003 Serial Number: 30021241700039
Encoding: 0022001
VCID: 76E66514015C078E54-8022
Address 5F: Information Selection. I (J794) Label file: DRV\4E0-035-6xx-5F.clb
Part Number SW: 8R1 035 670 C HW: 8R1 035 670 C
Part Number: H-BNT-EU H44 0524
Revision: -------- Serial Number: 207DS0C7500762
Encoding: 0F0100010106EBED2D80EF5E00000403040000000000000000
Subsystem 1 - Part Number: 8R0 060 884 AR
Part Number: ECE 2013 1505
Subsystem 2 - Part Number SW: 8R0 919 604 HW: 8R0 919 604
Part Number: DU7 High H41 0104
Subsystem 3 - Part Number SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Operates H02 0030
Subsystem 4 - Part Number: 8R0 060 961 C
Component: CD Database 3638
Address 62: Door electrical switch, left (J388) Label file: 8K0-959-795.clb)
Part Number SW: 8K0 959 795 D HW: 8K0 959 795 D
Part Number: TSG HL H01 0506
Revision: Serial Number: 0000029143726
Encoding: 010C02204000210001
VCID: 4380CCC0C20EE22623-8016
Address 69: Trailer (J345) Label file: DRV\8K0-907-383.clb
Part Number SW: 8K0 907 383 E HW: 8K0 907 383 E
Part: Trailer H09 0100
Revision: 1A001001 Serial Number: 00000146620353
Encoding: 0100000000000000
Operating Number: WSC 00000 000 00000
VCID: 3666A51481DC478E94-8062
Address 72: Door electrical switch, right (J389) Label file: 8K0-959-795.clb
Part: TSG HR H01 0506
Revision: Serial Number: 0000029143095
Ende----------------------------(Duration: 03:46)-----------------------------
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
DieselBär30x
Avatar-DieselBär30x
Post01-08-2016, 13:08    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Hi Michi!
Please first, on the VCDS main page, in the upper right "Settings" section, change the WSC to a numerical sequence.
Best regards from Munich!
Karma: +1333 / -0   Thank you, like it!
Post01-08-2016, 18:45    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
What exactly was done, and what does the ACC (not) do?
michiglaser
2007 Audi A4 Avant
Post01-08-2016, 22:34    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Ok, I will change the WSC.
I have installed a trailer hitch (Westfalia with Jaeger-E-kit).
Was I was able to successfully re-program all the control units to match the installed trailer hitch - but unfortunately, the ACC control unit.
After starting, he types "Braking guard off" into the display and wants me to activate the cruise control/ACC: "ACC: not available".
According to various online forums, I am not alone in this problem, however, none of the users have the same original encoding as me.
I'm not sure if I should try any kind of coding that has worked for others to get the system running again - after all, the system is actively involved in the driving process.
Of course, I could also get it done at Audi and have them code it using an SMV code.
There might be some complications though, as I only have a 600W fan and Audi probably requires an 800W fan in combination with a tow hitch.
(But I'll take that to heart: even towing a 750kg trailer 3km to the recycling center should be possible with 600W...)
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Post02-08-2016, 0:36    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Please also provide the details of the STG encoding for distance control (i.e., which checkboxes are set). That's something you can easily capture with a Screenshot.
Post02-08-2016, 9:58    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
I'm not sure if I should try any specific coding techniques that have worked for others to get the system running again - after all, the system is actively involved in the driving process.
Please do not randomly try out different encodings and re-discover the original encoding (e.g., Autoscan).
Please take a Screenshot...
Best regards, Rainer
Benni
Post15-05-2017, 9:11    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Since STG 13, the ACC module for the FL model, is unfortunately still not documented in VCDS.
Is there anything new here now?
I can provide a complete scan and Screenshot later.
Post15-05-2017, 9:24    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Hi Benni,
Is the latest dataset from 5.5.2017 already being used?
Benni
Post15-05-2017, 10:51    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Hi Reiner,
yes, I had specifically downloaded and freshly installed the latest version on Saturday.
I now also have a meeting where the entire SVM code will be coded, it would be great if Rosstech could also release the documentation.
I'm a bit sad that there's such a big gap now. But it is also understandable, given the increased complexity.
But they really need to step up their game and compete effectively.
Thank you, as mentioned, the data will be available tonight.
Post15-05-2017, 16:21    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Please perform an auto-scan...
Benni
Post15-05-2017, 20:50    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Saturday, May 13, 2017, 10:34:56:22413
VCDS -- Windows-based VAG/VAS emulator runs on Windows 10 x64 (VirtualBox)
VCDS Version RKS 17.1.3.0
Data Status: 20170505 DS267.9
Vehicle Identification Number: WAUZZZ8F Vehicle Registration Number:
Vehicle Type: 8F (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 26 42 44 46 52 53 56 5C
5F 62 69 72
Vehicle Identification Number: WAUZZZ8F Kilometerstand: 35080km
03-Brake Electronics -- Status: Error 0010
05-Access/Start Report -- Status: Error 0010
08-Climate/Heating System -- Status: OK 0000
09-Main Electrical System -- Status: OK 0000
19-Diagnosis Interface -- Status: Error 0010
20-Long-range headlight assistant -- Status: OK 0000
26-Electrical Roof. -- Status: OK. 0000
56-Radio -- Status: OK 0000
5C Lane Departure Warning Assist -- Status: Error 0010
69 supporters -- Status: not logged in 0001
Address 01: Engine Electronics (J623-CNCD) Label file: 06L-907-115-V1.clb
Part Number SW: 8T2 907 115 HW: 8T2 907 115
Part: 2.0l R4 TFSI H13 0005
Revision: --H13---
Encoding: 222500322446010B2000
Operating Number: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS0218T2907115 001006
ROD: EV_ECM20TFS0218T2907115.rod
VCID: 75EA21F8D496BBE9CA-8021
4 Error codes found:
17176 - Received Data Bus Error Value
U1123 00 [039] - -
Environmental Conditions:
Error Priority: 6
Frequency of Errors: 4
Mileage: 35070 km
Date: 2017.05.12
Time: 21:43:37
Motor Speed: 0.00 /min
Normalized Load Value: 0.0 %
Vehicle Speed: 0 km/h
Coolant Temperature: 31 °C
Intake Air Temperature: 33 °C
Ambient air pressure: 990 mbar
Voltage Terminal 30: 11.718 V
Fault Counter via OBD: 40
Drive System Coordinator: ACC Error Status - ACC: Not active although TSC is passive
Traction Coordinator: ACC Error Status: Approach and Stop Request: When stop speed is set
Drive Coordinator: ACC Error Status Bit 2: Not Sent Simultaneously
Drive System Coordinator: ACC Error Status Bit 3: Does not re-enable after error is cleared
Engine Control Coordinator: ACC Error Status Bit 4: Not Active when Limiter is Active
Drive System Coordinator: ACC Error Status Bit 5: Sending undefined signals
Drive System Coordinator: ACC Error Status Bit 6: Not Active when Main Switch is Off
Brake System Coordinator: ACC Error Status Bit 7: Not Active During Driver Braking
Emergency Brake Coordinator: ACC Error Status Bit 8: Not Active During EPB Emergency Brake
Engine Control Coordinator: Brake Fault Status - ESP: No Fault
Engine Control Coordinator: Brake Fault Status Delay Controller: Available
Engine Control Coordinator: Brake Fault Status Handshake TSK/ESP: No Fault
Engine Control Coordinator: Brake Fault Status Bit 1: No Fault
Engine Torque Coordinator: Brake Fault Status Bit 3: No fault due to inaccurate engine torques
Coordinator: Brake Error Status Bit 4: Indicates no consistency error from the TSK message
Drive System Coordinator: Brake Fault Status Bit 6: Forced Override OK.
Drive System Coordinator: Brake Fault Status: 4
Brake System Coordinator: Brake Function Status - Parking Brake: Not Active
Brake System Coordinator: Brake Function Status - ACC: not braking
Trip Coordinator: Brake Function Status - ESP: Does not perform TSK braking
Tractor Driver Coordinator: Brake Function Status - Driver: brake not working
Traction Control Coordinator: Brake Function Status - Downhill Assist: inactive
Engine Control Coordinator: Brake Function Status - ASR: No intervention
Drive System Coordinator: Brake Function Status - MSR: No Intervention
Engine Control Coordinator: Brake Function Status - ADS: No Intervention
Engine Control Coordinator: Brake Function Status - ABS: No Intervention
Engine Control Coordinator: Brake Function Status - EDS: No intervention
Engine Control Coordinator: Brake Function Status - ASP: No Intervention
Tire Pressure Coordinator: Brake Function Status - AWV2: No Warning Pressure
Engine Control Coordinator: Brake Function Status Bit 4: No Intervention
Actuator Coordinator: Brake Function Status Bit 11: Not Passive Tested
Actuator Coordinator: Brake Function Status Bit 12: Not passively tested
Engine Control Coordinator: Brake Function Status Bit 13: Stopped Detected
17178 - Received Data Bus Error Value
U1123 00 [039] - -
Error Priority: 6
Mileage: 35070 km
Date: 2017.05.12
Time: 21:43:37
Voltage Terminal 30: 11.738 V
15270 - Bank 1; Cam Adjustment (N205)
P1528 00 [032] - Interruption
Sporadisch - unconfirmed - checked since last deletion
15267 - Bank 1; Valve for camshaft adjustment; Outlet (N318)
P1050 00 [032] - Interruption
Readiness: 0000 0000
Part Number SW: 8K9 927 156 C HW: 0B5 927 156 K
Part Number: 0B5 20TFSIRdW H03 0005
Revision: --H03---
Encoding: 000001
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021_VW51.rod
VCID: 3D7AF9D8AC2623A9C2-8069
Address 03: Brake Electronics (J104) Label file: DRV\8K0-907-379-V2.clb
Part Number SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Part Number: ESP8 quattro H09 0020
Encoding: 311DCC01
VCID: 09125D08A06ECF09BE-805D
1 Error found:
000 - -
Error Priority: 2
Frequency of Errors: 3
Lost Count: 163
Mileage: 35070 km
Time: 0
Date: 2017.05.12
Time: 21:43:37
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0045
Hex Value: 0x0393
Hex Value: 0x0000
Part Number SW: 8K0 907 064 KH HW: 8K0 907 064 KH
Part Number: BCM2 2.0 H15 0711
Revision: 00002001
Encoding: 05A34F00000000000000
VCID: 0004402C93548E41E9-8055
1 Error found:
00956 - Key 2
002 - Lower limit exceeded
Error Status: 01100010
Error Priority: 3
Frequency of Errors: 2
Lost Count: 98
Mileage: 30889 km
Time: 0
Date: 2016.12.09
Time: 08:25:49
Part Number SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Part: KLIMA 3 ZONEN H04 0122
Revision: C1000000 Serial Number: 01090220150700
Encoding: 642302C880
VCID: 77F62BF0C69AC9F9D8-8023
Part Number SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Part Number: BCM1 1.0 H16 0103
Revision: 08016001 Serial Number: 00000997298401
Encoding: 260000118174AFE20181408300001D0D4F9CC3882609020100000B004401030100000064000000
VCID: 78F428CCCB84C681D1-802D
Subsystem 1 - Part Number SW: 8F1 955 119 HW: 8K1 955 119 Label file: DRV\1KX-955-119.CLB
Part Number: WWS 300115 H07 0080
Serial Number: SWF15011305827
Encoding: 00FD11
Subsystem 2 - Part Number SW: 8U0 955 559 C HW: 8U0 955 559 B Label file: DRV\8U0-955-559.CLB
Part Number: G397_RLFS H06 0004
Serial Number: 20114410
Encoding: 02005D
Part: E1 - LDS H03 0031
Serial Number: 00000000002701150660
Serial Number: BD184197000000000001
Address 13: Distance Control (J428) Label file: DRV\8K0-907-561.clb
Component: ACC3 H11 0100
Encoding: 00CFB0
VCID: 3162D5E8687ED7C956-8065
3 error codes found:
000 - -
Error Priority: 2
Frequency of Errors: 1
Lost Count: 162
Mileage: 35070 km
Time: 0
Date: 2017.05.12
Time: 21:43:38
Temperature: 18.0°C
Voltage: 11.65 V
Hex Value: 0x005D
Speed: 0.0 km/h
01314 - Engine Control Unit
013 - please read fault codes
Error Priority: 2
Lost Count: 162
Mileage: 35070 km
Time: 0
Date: 2017.05.12
Time: 21:43:38
01316 - Brake Control Unit
Error Priority: 6
Lost Count: 163
Mileage: 35070 km
Time: 0
Date: 2017.05.12
Time: 21:43:38
Temperature: 18.0°C
Voltage: 11.65 V
Hex Value: 0x00C0
Speed: 0.0 km/h
Address 15: Airbag (J234) Label file: 8F0-959-655.clb
Part Number SW: 8F0 959 655 D HW: 8F0 959 655 D
Part: AirbagVW-AU10 H15 0430
Serial Number: 003KGDB06L37
Encoding: 30394135353130303030554A304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 3972EDC8B80E1F89EE-806D
Crash sensor for driver's side side airbag:
Serial Number: 6334MSME4D091574G
Serial Number: 6344MSME4D3A4A1DW
Crash sensor for side airbag on the driver's side rear:
Serial Number: 6352QSME09503A52B
Crash sensor for side airbag on the passenger side:
Serial Number: 6362QSME2B4B2050D
Serial Number: 63732SME1E4D52443
Serial Number: 63832SME734F4270%
Address 16: Steering Electronics (J527) Label file: DRV\8K0-953-568.clb
Part: Steering Module H04 0005
Revision: -------- Serial Number: 90372OB4000ZZ
Encoding: 0000DE
VCID: 448C8C3CC7CC52618D-8011
Part Number: E221 - MFL H03 0004
Part Number SW: 8T0 920 932 S HW: 8T0 920 932 S
Component: COMBINATION INSTRUMENT H36 0567
Revision: 00100000 Serial Number: 5PN45DY1G
Encoding: 13EF190047010008000000
VCID: 4894980CFBE4760161-801D
Part Number SW: 8R0 907 468 P HW: 8R0 907 468 D
Part Number: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial Number: 3041Z152010F6B
Encoding: 80CF07FF00
VCID: 4C9CA41CEF9C9A2145-8019
Serial Number: 5479125603
Part: J532_DCDCStab H17 0042
Serial Number: 15035002287021200181
1 Error found:
000 - -
Error Priority: 1
Lost Count: 162
Mileage: 35070 km
Time: 0
Date: 2017.05.12
Time: 21:43:39
Binary Value: 10111
Voltage: 11.80 V
Number: 6
Address 20: Long-Range Assist System (J844) Label file: DRV\8K0-857-511.clb
Part Number SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Part: FLA H04 0012
Revision: AA001002
Encoding: 02018A64747464545425363E00
VCID: 7CFC34DCFFBCEAA1B5-8029
Address 26: Electrical. Roof. (J256) Label file: 8F0-959-255.clb
Part Number SW: 8F0 959 255 HW: 8F0 959 255
Part Number: VSG-AUDI-B8 H12 0190
Encoding: 010000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71E215E8A0FE97C916-8025
Part Number SW: 8T0 959 793 P HW: 8T0 959 793 G
Part Number: TSG FA H10 0305
Encoding: 011C53725E08330C03
VCID: 56A846742150D0F1E3-8003
Part Number SW: 8K0 909 144 J HW: 8K0 909 144 B
Part: RCEPS H41 0509
Revision: 00001000 Serial Number: 0028458316
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: 3874E8CC8304068111-806D
Revision: 00002001 Serial Number: 0359221778
Encoding: 01000EB800B900A18330033680000047
Part Number SW: 8T0 959 792 P HW: 8T0 959 792 G
Part: TSG BF H10 0305
Encoding: 011C53325E08330C03
VCID: 55AA41783C56DBE9EA-8001
Part Number SW: 8K0 907 801 N HW: 8K0 907 801 J
Part: EPB-4 H02 0005
Revision: -------- Seriennummer: 10000000497090
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A70F2C4BD081491E7-806F
Part Number SW: 4G0 035 061 Q HW: 4G0 035 061
Part: Radio U DAB H60 0150
Revision: AB001007 Serial Number: 109B/0F8007967
Encoding: 010103020100000101
VCID: 2B5EC7804A52BD196C-807F
Part Number SW: 8T0 907 217 A HW: 4E0 907 217 C
Part Number: J759 HC 0040
Revision: 00H08006 Serial Number: 600215205001EA
Encoding: 0022002
VCID: 3776EBF0461A09F918-8063
1 Error found:
Error Priority: 6
Frequency of Errors: 5
Lost Count: 163
Mileage: 35070 km
Time: 0
Date: 2017.05.12
Time: 21:43:38
Part Number SW: 8R1 035 670 J HW: 8R1 035 670 J
Part Number: H-BNT-EU H49 0897
Revision: -------- Seriennummer: 516B30F7509497
Encoding: 130100030006EBED2D80CB5E00000401040000000000000000
VCID: 3A70F2C4B5081491E7-806F
Subsystem 1 - Part Number: 8R0 060 884 CH
Part: EUR 2014 2004
Subsystem 2 - Part Number SW: 8R0 919 604 A HW: 8R0 919 604 A
Part Number: DU7 High H42 0104
Serial Number: A130BO0F3251772
Subsystem 3 - Part Number SW: 8T0 919 611 L HW: 8T0 919 611 C
Part: E0380 Operates H02 0030
Serial Number: 00000002125567
Subsystem 4 - Part Number: 8R0 060 961 G
Component: CD Database 5950
Part Number SW: 8T0 959 795 F HW: 8T0 959 795 F
Component: TSG HL H09 0305
Encoding: 010C13304008370C03
VCID: 4E98AE141980A8312B-801B
VCID: 3668E6F48110F0F103-8063
Address 72: Door electrical switch, right (J389) Label file: 8K0-959-794.clb
Part: TSG HR H09 0305
Ende----------------------------(Duration: 03:45)-----------------------------
Post16-05-2017, 10:10    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Dana from Ross-Tech gave me some tips:
Dana wrote:
Hi Rainer,
The Q5 requires numerous modifications when retrofitting a 69-Trailer module. This list may not be 100% complete - but it usually includes:
* 19-CAN Gateway - [Installation List] feature
* 01-Engine
* 03-ABS Brakes - Security Access, followed by Long Coding bit(s)
* 9 cents. Elect. - "Trailer Hitch/Recognition active"
* 10-Park/Steer Assist - Not Applicable here.
* 13-Auto District. Reg - Security Access required
* 3C - Lane Change - Not Applicable here.
* 5C-Lane Maintain
* 6C-Backup Camera. - Not Applicable here.
* 69-Trailer
He didn't add 69 to the Installation List (not registered), so I would suggest that when you ask for the original condition scan, you should specify that. The 13th coding requires HEX to DEC conversion:
> Encoding: 00CFB0 = 53168
xxxx?: Features
1 = Towing hitch installed
8 = Towing hitch NOT installed
I would change the 13th coding from 53168 to 53161 and convert it back to HEX for him: 00CFA9
Best Regards,
Dana
"Besides the fact that the trailer control unit (address 69) is not registered in the installation list, the trick lies in the fact that, apparently, a tooltip for adjustment appears when using the ACC, but the user is unable to understand the values."
"Normal coding" is simply a system where each bit, when represented in binary, corresponds to a specific function or setting.
If the values in decimal notation are specified in the tooltips and the control unit provides them in hexadecimal notation, then you naturally have to convert them accordingly.
At 00CFB0, it is clear that it is a hexadecimal number; at 002222, this would not be clear.
Does anyone have a Screenshot of the code display? My suggestion is that, if we're already doing it this way, instead of using pre-made buttons, we should write the number base first, such as 0b1111, 0x0f, or 15.
@BenniViewing profile: Benni: Please test the proposal suggested by Dana above.
Benni
Post16-05-2017, 12:22    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Thank you!
I will do that.
I deliberately chose the virgin scan. In the meantime, I had registered the 69 and also informed ESP that there was now a tow hitch, so that the fair could proceed and I wouldn't have to drive without ESP.
This morning, the car was brought to the workshop because it was leaking oil from all the seals. Subsequently, the AHK (vehicle identification) is registered via SVM (online), and I then send a new vehicle scan.
When I was encoding in ACC, I didn't wait for a tooltip and immediately clicked on the "Long Coding Assistant," which was then empty.
Benni
Post29-05-2017, 20:07    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Here is the result after the SVM:
Encoding: 00CFA9
Operating Number: WSC 49974 002 1048576
I couldn't find a tooltip or similar, I only have the Long Coding Assistant, and it doesn't provide any documentation.
However, the result does confirm, at least, the Ross-Tech statement.
Post29-05-2017, 20:13    Subject: A4 B8 FL: ACC (Adaptive Cruise Control) coding after AHK (Automatic High Beam) installation Quote
Thank you for your feedback! Could you please provide a Screenshot of the control unit information for the affected control unit?
I have a suspicion...
misler11
Post02-08-2017, 1:56    Subject: ACC and AHK Quote
Good day
I'm just joining in here, I hope this is okay?
I have installed a trailer hitch on my S4 B8 and now I'm having problems with the trailer hitch control unit. The ACC (Adaptive Cruise Control) system is shutting down when it should be actively braking while towing.
The supplier's support team says I have incorrectly coded it and now they want to sell me the coding as well.
However, I would prefer to handle the coding myself using my VCDS.
Could someone with professional expertise please take a look at the scan of my car and point out any potential issues?
Best regards and greetings
Marco
Fehlerspeicher Audi S4 Komplett.pdf
 Auto scan
Auto scan
 File name:  Fehlerspeicher Audi S4 Komplett.pdf
 File size:  161.7 KB
 Downloaded:  1093 times
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat-Einbau-Probleme Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts GRA Installation Error: Troubleshooting Guide Diesel Engine Technology
No new posts Adjust timing belt tension after installation Diesel Engine Technology
No new posts Noise after installation of 0.216 injectors Diesel Engine Technology
