dieselschrauber wrote: |
For model years 2018 and later, not much can be done without a VCDS HEX-V2.
Is there any information available regarding the limitations I might have with my old Hex-Can interface, or will have in the future?
I thought I would just have to wait for an updated VCDS version. However, when I do an automatic scan, it says "Vehicle/model not supported" for every control unit. If I need a new interface, I already have to start polishing the hammer for the piggy bank...
Here's the car scan:
Monday, September 10, 2018, 1:09:47:37090
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x64.
VCDS Version: RKS 18.2.1.0
Data as of: 20180904 DS287.4
http://shop.dieselschrauber.org/en
Vehicle Identification Number: WVWZZZAAZKD100XXX
License plate: XX-XXXX
Mileage: 317. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: AA (1S0)
Scan: 01 03 08 09 10 15 17 19 25 44 47 5F 61 A9 AD
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
A9 Body Sound Actuator -- Status: OK 0000
AD sensorics for braking systems -- Status: OK 0000.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-DKRA) Label file: . DRV\04E-907-309-V1.clb
Part number SW: 04C 906 025 F, HW: 04C 907 309 BA.
Part: R3 1.0l TFS H20 6355
Revision: D8H20000
Encoding: 00190032232401000000
Operating number: WSC 31414 790 00001
ASAM Dataset: EV_ECM10TFS01104C906025F 003009
ROD: n.v.
VCID: 234E606D2A451A5C1C-8076
Vehicle/model not supported.
No ASAM data available: "EV_ECM10TFS01104C906025F" ().
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics (J104)
Label file: .1S0-614-517.clb
Part number SW: 1S0 614 517 P Hardware: 1S0 614 517 P
Component: EBC 460 ESP H17 0030
Serial number: A01TMZZ
Encoding: B9BF64712BAD02F19D0026FDD4AD40505FB000
ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
ROD: n.v.
VCID: 3C7CBB11B7FB45A43D-8068
No ASAM data available: "EV_Brake1ESPEBC460TRW" ().
Address 08: Climate Control/Heating Unit (J255)
Label file: None
Part number SW: 1S0 907 044 Hardware: 1S0 907 044
Component: Climatronic
H05 0102
Revision: K0000000
VCID: 6CDC4B518F1B1524ED-8038
Address 09: Central Electronics (J519)
Label file: None
Part number SW: 1S0 937 090 J, Hardware number: 1S0 937 090 J.
Part number: BCM PQ25 1MX4 H82 0762.
Revision: BW082001 Serial Number: 8901199181938
Encoding: 62B82B0000010000010807C06CEB8ED079C0706D60CF2D602101000B0900
VCID: 3A70BD09B5CF7B942F-806E
Subsystem 1 - Part number: 5K7 955 559 C. Label file: DRV\5K7-955-559.CLB.
Component: RLS 170718 05 50 0106
Encoding: 0228DD
Subsystem 2 - Part number SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 29180001392390018262.
Encoding: A4FFFF
Address 10: Parking Assist 2 (J446) Label file: .1Sx-919-475.clb
Part number SW: 1S0 919 475 B, HW: 1Q0 919 475.
Component: PARKING ASSIST 3K H03 0013.
Revision: -------- Serial Number: 32931820107221
Encoding: 308004
ASAM Dataset: EV_EPHVA14VW1200000 001009
ROD: n.v.
VCID: 3972A205B8C9708C26-806C
No ASAM data available: "EV_EPHVA14VW1200000" ().
Address 15: Airbag (J234) Label file: . DRV\5K0-959-655.clb
Part number SW: 1S0 959 655 E, Hardware: 1S0 959 655 E.
Part number: VW10Airbag02N 010 0007
Revision: -------- Serial Number: 003EQ000HJHA
Encoding: 0000000000000000000000000000000
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: n.v.
VCID: 4084CFE1DB13214461-8014
Subsystem 1 - Serial number: 3497ARB405J5B0LQ5PI
Subsystem 2 - Serial number: 3507ARB405P59RLEHA6Y.
Subsystem 3 - Serial number: 3557BRB40575B0LQGOM.
No ASAM data available: "EV_AirbaVW10BPAVW12X" ().
Address 17: Terminal block (J285) Label file: . DRV\1Sx-920-xxx-17.clb
Part number SW: 1S0 920 870 C HW: 1S0 920 870 C
Component: COMBINATION H12 0100
Revision: X0012001 Serial Number: 00000000000000
Encoding: 114A010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: n.v.
VCID: 31629A2560B9B8CC9E-8064
No ASAM data available: "EV_KombiUDSMM9RM10" ().
Address 19: Diagnostic interface (J533)
Label file: None
Part number SW: 1S0 909 901, HW: 1S0 937 090 J.
Component: GW-K-CAN TP20 H82 0762
Revision: BW082001
Encoding: 001201
VCID: 70E45F21A333F1C4D1-8024
Address 25: Immobilizer (J334) Label file: . DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 1S0 920 870 C
Component: IMMO H12 0100
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: n.v.
VCID: 6AD04D498DEF0B149F-803E
No ASAM data available: "EV_ImmoUDSMM9RM10" ().
Address 44: Steering Assist (J792)
Label file: . DRV\6Rx-909-144-V2.clb
Part number SW: 6R1 909 144 AN, HW: 6R1 909 144 E.
Part: EPS_TRW_ALow 313 3150
Serial number: CI7Q1484
Encoding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: n.v.
VCID: 030E00ED8A85FA5C3C-8056
No ASAM data available: "EV_SteerAssisUDSTRW" ().
Address 47: Soundsystem (R12) Label file: 5K0-035-456.clb
Part number: 5K0 035 456 E
Component: Corporate Amplifier 8K H09 6631.
Revision: -------- Serial Number: EAA101C0082532
ASAM Dataset: EV_AudioAmplifier8ChannelSTT3 001003
ROD: n.v.
VCID: 2C5C8B51479BD524AD-8078
No ASAM data available: "EV_AudioVerst8KanalSTT3" ().
Address 5F: Information selection. I (J794) Label file: 5G0-035-MIB-ENT2.clb
Part number SW: 1S0 035 869 B Hardware: 1S0 035 869 B
Component: MU-E-D-EU 068 7338
Serial number: 21061800021093.
Encoding: 02210100AA00000041111103018002001F000AD40001010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: n.v.
VCID: 356AAE3594D194ECC2-8060
No ASAM data available: "EV_MUEnt4CGen2LGE" ().
Address 61: Battery Management (J840) Label file: . DRV\1K0-907-534.clb
Part number SW: 1S0 907 534 Hardware: 1S0 937 090 J
Component: Battery management system H82 0762.
Serial number: 8901 199181938.
Encoding: 032B7856
Subsystem 1 - Part number SW: 1S0 915 181 D HW: 1S0 915 181 D
Part number: J367-BDM H08 0270
Serial number: 55143K55546060945217
Address A9: Body sound actuator (J869)
Label file: None
Part number SW: 1S0 907 159, HW: 4H0 907 159 A.
Component: SAS-GEN 2 H07 0003
Serial number: 180628201218.
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: n.v.
VCID: 73EE502DDA25CADC2C-8026
No ASAM data available: "EV_SoundActuaGen2AU64X" ().
Address AD: Sensors for Brake Systems (J939)
Label file: 1S0-907-201.clb
Part number SW: 1S0 907 201 A, Hardware: 1S0 907 201 A.
Component: CV-SENSOR H08 0460
ASAM Dataset: EV_CVSen 001001
ROD: n.v.
VCID: 285477415363F90449-807C
No ASAM data available: "EV_CVSen" ().
End----------------------------(Duration: 02:36)-----------------------------
"Dirk"
