Audi BLS Engine Problems: Jerking & Troubleshooting
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Klaus-Peter
Post29-08-2022, 10:22    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Hello forum,
In March, I experienced a connecting rod bearing failure during the inspection and maintenance of my BLS engine.
The engine has been replaced. The turbocharger is old, and the injectors are my old ones that have been reconditioned with new seals. The DPF has been regenerated.
Symptoms: I'd describe it as "micro-stuttering" across all RPM ranges. It's most noticeable on long drives, but hardly noticeable in city traffic. Additionally, I've noticed that this jerking occurs when the engine is running at a constant RPM, and it feels like a slight loss of power.
The car was already taken to a Bosch service center, which specializes in diesel engines. Unfortunately, they couldn't find a solution. The error memory is also empty.
Does anyone have any other suggestions?
Thank you and best regards.
Peter.
Translated on 22-10-2026, 19:11.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post29-08-2022, 14:44    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Hello Peter,
Please provide the text you would like me to translate from German to English.
What are the values for the idle speed control?
Is the intake manifold airtight?
Michael.
Translated on 22-10-2026, 19:12.
Klaus-Peter
Post29-08-2022, 20:46    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Hi Michael,
Regarding the auto-scan, I need to wait until my mechanic has time for it.
I also have no information about the idle speed. Is it possible to read this data via VCDS?
What do you mean by "dense"?
P.
Translated on 22-10-2026, 19:13.
Post29-08-2022, 21:35    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Hello Klaus-Peter,
Yes, you can read the values of the idle speed control using VCDS.
Record a segment of driving where you experience jolting or stuttering. If you see any interruptions or glitches in the log, it could indicate problems with the power supply to the engine control unit.
Translated on 22-10-2026, 19:14.
Karma: +647 / -0   Thank you, like it!
Post30-08-2022, 5:04    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Are the PD (Power Distribution) elements in the wiring harness old, or have they been replaced during a refurbishment?
Klaus-Peter
Post30-08-2022, 21:36    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
@Rüdi
It's the old one. And I already regret not having renewed it just for the sake of it.
Translated on 22-10-2026, 19:15.
Klaus-Peter
Post06-09-2022, 16:10    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Hello, I now have a PDF and a TXT file for Autoscan and LLRR.
LLRR:
Address 01: Engine Control Module (03G 906 021 RD)
18:54:11 Block 001: Injection amount.
819 /min Motor speed (G28)
4.1 mg/H injection volume.
7.7 kW, Operating time (target value)
78.3°C Coolant temperature (G62)
18:54:11 Block 013: Idle speed control (fuel injection quantity deviation).
-0.12 mg/H Einspritzm.-Abw. Cylinder 1.
-0.35 mg/H Einspritzm.-Abw. Cylinder 2.
0.16 mg/H Einspritzm.-Abw. Cylinder 3.
0.33 mg/H Einspritzm.-Abw. Cylinder 4.
18:54:11 Block 023: Switching times.
-3.0 Schaltzeitabweich. Cylinder 1.
3.0 Schaltzeitabweich. Cylinder 2.
2.0 Schaltzeitabweich. Cylinder 3.
-4.0 Shift time deviation. Cylinder 4.
1097.txt
 File name:  1097.txt
 File size:  1.07 KB
 Downloaded:  195 times
Translated on 22-10-2026, 19:16.
Klaus-Peter
Post06-09-2022, 16:11    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
Autoscan attached.
18489(1)(1).pdf
 File name:  18489(1)(1).pdf
 File size:  18.62 KB
 Downloaded:  238 times
Translated on 22-10-2026, 19:18.
Post06-09-2022, 16:31    Subject: Audi BLS Engine Problems: Jerking & Troubleshooting Quote
VCDS is a clone. Therefore, goodbye.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi 80 B4 On-Board Diagnostics (OBD)
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi AFB STG: Repair & Replacement Diesel Engine Technology
