Offset always at -25.5
erwin.b
Post13-09-2022, 17:19    Subject: Offset always at -25.5 Quote
Hello everyone,
I know this topic is old, but I have a related problem.
I had problems with the DPF (Diesel Particulate Filter) in my 1.9 TDI.
Since the exhaust system had to be replaced anyway, I also had the DPF cleaned. After that, it was reinstalled, and the ash content was reset to 0 using VCDS.
After a few kilometers, the engine check light came on, and VCDS showed several errors related to the differential pressure sensor. So, I replaced the sensor as well and re-initialized it using VCDS. However, something seems not to have worked correctly during the process.
The sensor shows values between -5 and -10 when the engine is off, with an offset of -25.5.
"Also, the error is appearing again:"
Code:
001137 - Drucksensor 1 für Abgas (G450)
P0471 - 000 - unplausibles Signal
Umgebungsbedingungen:
Fehlerstatus: 01110000
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 255
Kilometerstand: 286259 km
Zeitangabe: 0
Datum: 2000.00.00
Zeit: 15:38:52
Drehzahl: 798 /min
Geschwindigkeit: 0.0 km/h
(keine Einheit): -5.10
(keine Einheit): -25.50
keine Einheit): 36.0
Temperatur: 270.0°C
Temperatur: 15.3°C
It looks like the offset is incorrect.
I have tried to re-calibrate the sensor several times, but nothing changes. The offset is always at -25.5.
I also tried the pairing process with the ignition on for 5 seconds and off for 40 seconds (repeated 5 times), but there was no difference.
Do you have any other ideas?
Translated on 22-08-2026, 9:30.
Post14-09-2022, 22:20    Subject: Offset always at -25.5 Quote
If the offset cannot be adjusted to at least a single-digit value via OBD, then the sensor is broken. icon_idea.gif
Translated on 22-08-2026, 9:32.
erwin.b
Post15-09-2022, 15:03    Subject: Offset always at -25.5 Quote
Thank you, dieselschrauberViewing profile: dieselschrauber.
"But I suspect you're wrong here; the sensor is almost new, and furthermore, I looked at the readings. To do this, I accelerated from idle speed to 4000 RPM with full throttle. The measured value of the differential pressure (MW67/3) increases from -2.55 to 85. See also the attached diagram."
 Diagram Motordrehzahl Ladedruck und Differenzdruck
 File size:  23.03 KB
 Viewed:  1422 times
Post15-09-2022, 16:09    Subject: Offset always at -25.5 Quote
You yourself are writing that the readings when the engine is off are incorrect. What do you think the reason for this might be?
A sensor defect is the most common cause. Could you please clarify what you think answers your question?
Translated on 22-08-2026, 9:33.
erwin.b
Post15-09-2022, 20:35    Subject: Offset always at -25.5 Quote
I think the offset is incorrect. The offset in measurement 67/4 is -25.5, and the reading when the engine is off is -2.55. I thought the sum should be 0 when the engine is off. Unfortunately, I can't set the offset, and recalibration doesn't seem to be working.
"Dieselschrauber", have you seen the progress? It looks pretty good so far.
I've also attached the complete data here. It's in CSV format and a bit more readable.
Do you really think the sensor is defective? This would be the second sensor to fail within 6 months.
MW11_67_68_____2.xlsx
 File name:  MW11_67_68_____2.xlsx
 File size:  34.83 KB
 Downloaded:  193 times
MW11_67_68_____2.CSV
 Messwerte als CSV
Messwerte als CSV
 File name:  MW11_67_68_____2.CSV
 File size:  1.96 KB
 Downloaded:  259 times
Translated on 22-08-2026, 9:34.
erwin.b
Post18-09-2022, 13:26    Subject: Offset always at -25.5 Quote
Today I read the error memory again, and guess what:
Two error codes found:
001137 - Exhaust gas pressure sensor 1 (G450).
P0471 - 000 - Implausible signal.
Environmental conditions:
Error status: 01100000
Error priority: 2
Error frequency: 1.
Lost Count: 255
Time: 0.
Speed: 0 RPM.
Speed: 0.0 km/h
(no unit): 0.00
(no unit): -25.50
(no unit): 0.0
Temperature: 168.0°C
Temperature: 17.1°C
001138 - Exhaust gas pressure sensor 1 (G450).
P0472 - 000 - Short circuit to ground - Intermittent.
Error status: 00100000
Error priority: 2
Error frequency: 12
Lost Count: 255
Time: 0.
Speed: 1008 RPM
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.17 V
Mileage: 30 km
Temperature: 6.0°C
Pressure: 948.6 mbar
Perhaps there is a problem with the wiring (maybe caused by a weasel or something).
Can the cable be replaced all the way to the control unit?
Does anyone know which pins on the control unit lead to the sensor?
Thank you.
Translated on 22-08-2026, 9:38.
erwin.b
dieselschrauber likes this.
Post17-10-2022, 22:40    Subject: Offset always at -25.5 Quote
Brief reply.
The sensor was working correctly, and replacing the cables (the first 50 cm) near the sensor resolved the issue. After that, it needed to be re-paired, and since then, it has been functioning properly for 2000 km.
Unfortunately, I still don't know about the PINs for the engine control unit.
Translated on 22-08-2026, 9:42.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF differential pressure sensor output voltage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
New posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Der Differenzdrucksensor Diesel Engine Technology
No new posts T5 Differenzdrucksensor On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor Diesel Engine Technology
No new posts When is a differential pressure sensor dead? Diesel Engine Technology
