9561 - NOx Sensor 2 for Bank 1, P229E
kickpanther
Post10-03-2022, 19:42    Subject: 9561 - NOx Sensor 2 for Bank 1, P229E Quote
I have the following errors related to NOx.
Perhaps you can help me with this.
Here's the error message.
Thursday, March 10, 2022, 17:21:48:11429
VCDS version: DRV 21.9.0 is running on Windows 10 x64.
shop.dieselschrauber.org
Address 01: Engine Control Module
Label file: DRV\059-907-401-V2.clb
Control unit part number: 8K5 907 589 C. Hardware: 4G0 907 589 B.
Component and/or version: 3.0BTD EDC17 X23 0008
Encoding: 2A2A4032257603030000
Operating number: WSC 92521 052 00000
ASAM Dataset: EV_ECM30BTD0118K5907589C 001010 (AU48)
ROD: EV_ECM30BTD0118K5907589C.rod
VCID: 41CA6754D0A56F810A-8014
2 error codes found:
9561 - NOx sensor, bank 1, donor 2.
P229E 00 [237] - Electrical fault.
Warning light ON - confirmed - checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 2
Mileage: 103,927 km
Date: 2022.02.27
Time: 22:51:37
Motor speed: 799.50 rpm.
Normalized load value: 11.8%
Vehicle speed: 0 km/h
Coolant temperature: 89 °C
Intake air temperature: 15 °C
Ambient air pressure: 1010 mbar.
Voltage at terminal 30: 14.660 V.
Lost count after OBD: 40
NOx Sensor 2: NOx concentration: -100 ppm.
Com r Lam Lin Rec Cat2 Ds: -0.1450
NOx Sensor 2: Supply voltage: 14080 mV.
Setpoint for the heating temperature of the NOx sensor, 2 bits, range 0-7: 1.
Com st N Ox Vld Cat2 Ds-Bits 0-7: 0
Exh st Lam Stat No Cat2 Ds-Bits 0-7: 1
Exhaust temperature sensor 4: 524.9 °C
9880 - NOx sensor heater, bank 1, sensor 2.
P22A7 00 [096] - implausible signal.
Sporadically - unconfirmed - checked since last deletion.
Error priority: 2
Error frequency: 1
Mileage: 103,431 km
Date: 2022.02.18
Time: 17:29:49
Motor speed: 704.50 rpm.
Normalized load value: 18.0 %
Coolant temperature: 74 °C
Intake air temperature: 19 °C
Atmospheric pressure: 970 millibars.
Voltage at terminal 30: 14.360 V.
Lost count after OBD: 5
NOx Sensor 2: NOx concentration: 115 ppm.
Com r Lam Lin Rec Cat2 Ds: 0.2100
NOx Sensor 2: Supply voltage: 13760 mV.
Exhaust temperature sensor 4: 137.5 °C
Readiness: 1 1 0 0 0
I would really appreciate your help.
Best regards, Kickpanther.
Vielen Dank.
Gruß Kickpanther
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
Post10-03-2022, 20:39    Subject: 9561 - NOx Sensor 2 for Bank 1, P229E Quote
Good evening.
Would you like to tell us which vehicle or engine we are talking about?
Are you going with the organization? Manufacturer's software or an alternative solution?
Have you already done anything to the vehicle / checked anything?
Did the vehicle start?
Michael.
kickpanther
Post10-03-2022, 20:50    Subject: 9561 - NOx Sensor 2 for Bank 1, P229E Quote
Hello and sorry,
Sure, I'll tell you the details.
Audi SQ5 V6 8R, year 2016, 240 kW, 3.0L engine.
The vehicle is in its standard configuration but has been modified for increased performance.
I haven't checked anything yet, I've only read the error codes.
No, not forced.
Vielen Dank.
Gruß Kickpanther
Post10-03-2022, 21:10    Subject: 9561 - NOx Sensor 2 for Bank 1, P229E Quote
In case of electrical faults, I would first rule out damage caused by rodents.
kickpanther
Post11-03-2022, 9:50    Subject: NOx Quote
Good morning.
I once looked up from below.
All the lines are in good working order.
That should be the right NOx sensor, right?
Vielen Dank.
Gruß Kickpanther
kickpanther
dieselschrauber likes this.
Post25-03-2022, 14:34    Subject: 9561 - NOx Sensor 2 for Bank 1, P229E Quote
So, it's the last sensor in the exhaust system.
I've replaced them now, and so far, there have been no errors.
Vielen Dank.
Gruß Kickpanther
Post26-03-2022, 12:53    Subject: 9561 - NOx Sensor 2 for Bank 1, P229E Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Bunkerrace
Karma: +0 / -1   Thank you, like it!
2016 Audi Q5
Post02-11-2022, 6:30    Subject: NOx sensor bank 1 sensor 2 Quote
Hello kickpanther, I'm having the same problem. Could we exchange information about which sensor you replaced? Maybe with a picture or a sketch.
Karma: +438 / -0   Thank you, like it!
Post02-11-2022, 12:27    Subject: Re: Nox sensor bank 1 sensor 2 Quote
Bunkerrace wrote:
Hello kickpanther, I'm having the same problem. Could we chat about which sensor you replaced? Maybe with a picture or a sketch.
Have you ever had your car lifted up on a lift and inspected the exhaust system?
In my opinion, the statement is quite clear:
kickpanther wrote:
so, it's the last sensor in the exhaust.
So, it's the sensor located behind the DPF (Diesel Particulate Filter) and the storage catalyst. There's only one sensor there, so it's practically impossible to confuse it with another one. Otherwise, please upload a picture of your car from underneath, and we can circle the area in question.
Hendrik.
Bunkerrace
2016 Audi Q5
Post02-11-2022, 12:55    Subject: NOx sensor bank 1 sensor 2 Quote
Then it should be this one.
removed
Please do not post any images or text here that are subject to copyright. This includes excerpts from repair manuals. This kind of thing only causes problems for the forum administrator.
You can get a complete set of vehicle-specific repair manuals for a low price from Erwin.
No new posts Error code 15733 - NOx catalyst, bank 1 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0420 - Catalytic converter system, Bank 1, efficiency to... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0171 Fuel System Bank 1 Lean Mixture Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reduction system, bank 1 / SCR NOx catalyst, bank 1 Diesel Engine Technology
No new posts Voltage Sensor 1 - Probe 1 too small On-Board Diagnostics (OBD)
No new posts DPF error - 19226 - Particle filter, bank 1, P2002 Diesel Engine Technology
No new posts Catalytic Converter Error Code 16804: Low Efficiency On-Board Diagnostics (OBD)
