Assign label file to Audi S3 A B T
Garage4451
Post24-01-2023, 23:05    Subject: Assign label file to Audi S3 A B T Quote
Hello everyone,
Today, I tried to read the measurement data from the engine control unit (ECU) of an S3 8P manufactured in 2008, but I found that there was no label file available. I then searched on Google and discovered that this might be due to the A B T control unit, which has "A B T" in its part number. I also read something about a redirect file.
"Could someone possibly explain how to find and open the actual label file for the engine (CDLA 2.0)? Or even how to use the redirect file method?"
If I had a list showing which block contains each value, that would be enough for now. The vehicle is experiencing misfires on cylinder 3.
VIN: WAUZZZ8P99A076808
Best regards from Switzerland.
Translated on 18-07-2026, 16:34.
Post24-01-2023, 23:49    Subject: Assign label file to Audi S3 A B T Quote
Yes, unfortunately, the engine control unit then provides a modified VAG part number.
Please post an Autoscan result. I would like to try copying the correct label file and then modifying it with the part number from the Autoscan.
It's possible that this could conflict with the redirection.
Translated on 18-07-2026, 16:36.
Garage4451
Post26-01-2023, 18:29    Subject: Assign label file to Audi S3 A B T Quote
Unfortunately, I don't have a scan available right now; the vehicle will be brought in for diagnosis next week.
According to AKTE, the part number is: 8P0 907 115 AP.
I couldn't find that label file under the "LABELS" directory.
What could be the reason for that?
Best regards, Mischa.
Translated on 18-07-2026, 16:37.
Post26-01-2023, 18:46    Subject: Assign label file to Audi S3 A B T Quote
"Wildcards" are used in the label search.
Ross-Tech wrote:
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part Number (Software): 8P0 907 115 AP Hardware: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
The label file is 06F-907-115-CDL.clb icon_wink.gif.
Translated on 18-07-2026, 16:38.
Garage4451
Post26-01-2023, 19:10    Subject: Assign label file to Audi S3 A B T Quote
Thank you very much, Rainer.
Can I view this as plain text somehow, or simply rename the file to the "A B T number"?
Translated on 18-07-2026, 16:39.
Post26-01-2023, 19:17    Subject: Assign label file to Audi S3 A B T Quote
The .clb file is encrypted. Use VCDS to access the engine control unit and rename the copied file to match the part number shown by A B T. Replace spaces with hyphens. Make sure to keep the .clb extension.
Translated on 18-07-2026, 16:40.
Garage4451
dieselschrauber and E30_V8 likes this.
Post03-02-2023, 18:08    Subject: Problem solved Quote
I just wanted to let you know that the solution with copying and renaming worked perfectly.
Mischa.
Translated on 18-07-2026, 16:41.
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
Post03-02-2023, 18:40    Subject: Assign label file to Audi S3 A B T Quote
Polo V 1,6 Tdi (CAY)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Label File: Definition and Usage On-Board Diagnostics (OBD)
No new posts Label File 2.6L ABC On-Board Diagnostics (OBD)
No new posts Label-Files for VAG-COM / FB to ZV On-Board Diagnostics (OBD)
No new posts Label Files: How to Create & Use Them On-Board Diagnostics (OBD)
