Sharan 2.0 P0087 - Low Rail Pressure
Go to page: 1, 2  Next
martl10
Post06-06-2021, 19:27    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Hello, the vehicle I'm having trouble with is a 2013 Sharan 4Motion 2.0 TDI with 140 horsepower, engine code CFFB.
When the engine is cold and for the first 10 kilometers, it runs perfectly. However, once it's properly warmed up, after about 10 kilometers, the limp mode engages as soon as I exceed 3000 RPM. The spiral indicator blinks, the ignition cuts out and then comes back on, and then it runs again for a short period until it exceeds 3000 RPM again.
I have already replaced the following parts:
- Fuel filter
- Rail pressure sensor
- Fuel pressure regulator
- No abnormalities detected during reflux volume measurement.
Initially, replacing the fuel quantity control valve and adjusting it using VCDS brought about an improvement.
The error now occurred very rarely.
This happened six months ago, and now it's starting up again.
I replaced the CR pump as a precaution, and it seems to have reduced the frequency of the limp-home mode.
However, the error is still there...
What now...?
I hope you can help me...
Thank you, Martin.
Fuel level has no influence.
Sunday, June 6, 2021, 7:52:21 PM: 28029
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 20.4.1.1 HEX-NET CB: 0.4543.4
Data as of: 20200709 DS317.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number: WVWZZZ7NZCV040921 License plate:
Mileage: 169,970 km. Repair order: Andre.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 47 4C 4F 52
53 55 56 61 62 69 6C 6D 72 77 BE BF
Vehicle Identification Number: WVWZZZ7NZCV040921 Mileage: 169970 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-way heater -- Status: Error 0010.
19-Diagnosis interface -- Status: OK 0000.
22-All-wheel drive -- Status: OK 0000
Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C Tire Pressure II -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam angle adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: OK 0000
6C Reverse Camera -- Status: OK 0000
Rear hatch (6D) -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
Rear left sliding door -- Status: OK 0000.
Rear right sliding door -- Status: OK 0000.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CFFB) Label file: .DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 HK, HW: 03L 907 309 Q.
Part: R4 2.0l TDI H27 9978
Revision: 44H27--- Serial number:
Encoding: 0019001A043601080000
Operating number: WSC 26158 186 00000
ASAM Dataset: EV_ECM20TDI01103L906018HK 003013
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: FAB875897DB2A456C4-80AE
"1 error found:"
5211 - Fuel system (bank 1): Rail/system pressure too low.
P0087 00 [172] - -
Warning light ON - Intermittent - Confirmed - Checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 5
Mileage: 169,967 km
Date: 2021.06.06
Time: 03:14:38
Motor speed: 3773.50 RPM.
Normalized load value: 99.6%
Vehicle speed: 51 km/h
Coolant temperature: 77 °C
Inlet air temperature: 30 °C
Atmospheric pressure: 960 millibars.
Voltage at terminal 30: 14.660 V.
Lost count after OBD: 40
Fuel temperature: 25.4 °C
Average injection amount: 51.23 mg/stroke.
Rail pressure regulation: Status bits 0-7: 5
Fuel pressure: Actual value: 1.0206e+006 hPa.
Fuel high pressure: Target value: 1.7442e+006 hPa.
Adaptation factor of the pressure regulating valve: 1.0425.
Fuel level: 12.00 liters.
Readiness: 1 1 0 0 0
Address 03: Brake Electronics Label file: 7N0-614-109.clb
Part number SW: 7N0 614 109 N, Hardware number: 7N0 614 109 N.
Component: J104 C3 450M VDC3 0021
Revision: --H07--- Serial number: 00000005418427
Encoding: 0018973
Operating number: WSC 00020 790 00000
VCID: B83CAF81CB3E764672-80EC
No error codes found.
Address 08: Climate Control/Heater (J255) Label file: | DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 FN
Part number HW: 5K0 907 044 FN
Part: Clima-Sharan H18 0204
Revision: 00001003
Encoding: 0200104409
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_ClimatronicSharan A01005
text
ROD: EV_ClimaAutoSharaBasis.rod
VCID: FCB4739177869A66D6-80A88
Address 09: Central Electronics (J519)
Label file: .DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 086 M, Part number HW: 5K0 937 086 M.
Part: BCM PQ35 M 021 0064
Revision: BC021001
Encoding: 40590A3B89251AC0500800C0740009E443D51408636D2D22E484872000C1
VCID: BE30B999291A4876B8-80EA
Subsystem 1 - Part number SW: 7N1 955 119 A, HW: 7N1 955 119, Label file: DRV\1KX-955-119.CLB.
Component: WWS 120209 31 0032
Serial number: 120221154845
Encoding: 004DBD
Subsystem 2 - Part number SW: 7N0 955 559 HW: 7N0 955 559 Label file: DRV\7N0-955-559.CLB
Part number: RLFS 021 0024.
Serial number: Y12M02D27h23m47s19S1
Encoding: 0280BB
Address 10: Parking Assist 2 (J446) Label file: | DRV\1Q0-919-475.clb
Part number SW: 7N0 919 475 A, HW: 7N0 919 475.
Part: PARKING ASSIST 8K H06 0012
Revision: -------- Serial Number: 28261205500709
Encoding: 318001
ASAM Dataset: EV_EPHVA18VW4280000 001005
FILE: EV_EPHVA18VW4280000.rod
VCID: B93AAA8538346F4E8D-80EC
Address 15: Airbag (J234) Label file: | DRV\5K0-959-655.clb
Part number SW: 7N0 959 655 C, HW: 7N0 959 655 C.
Part number: VW10Airbag00Z H10 0014
Serial number: 003LGP37XKZY
Encoding: 00305A
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: BFCEC49D2610417EB3-80EA
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60F7C10914DD%
Encoding: 000000
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Left --- ---
Serial number: 3503ETS60E45681159DP
Encoding: 000000
Rear side airbag crash sensor (driver's side):
Subsystem 3 - Part number: SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60F1730A14DDR
Encoding: 000000
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: --- HW: ---
Component: S. Sensor, Front, Right --- ---
Serial number: 3523ETS60DD4C8115DD1
Encoding: 000000
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS605E89FD13DD2
Encoding: 000000
Address 16: Steering wheel electronics (J527)
Label file: | DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 BA, HW: 5K0 953 569 H.
Component: STEERING MODULE 014 0140
Revision: FF010040 Serial number: 20120227200810
Encoding: 118A240000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: EA9845C90D1214D634-80BE
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D HW: 3C8 959 537 D Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 17: Control panel module (J285)
Label file: | DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 7N0 920 870 E, Hardware number: 7N0 920 870 E.
Component: COMBINATION UNIT H03 0609
Serial number: 00000000000000
Encoding: 140F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: B4249BB11F5692265E-80E0
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 E.
Component: Standing heater 043 4941
Revision: 00043000 Serial Number: 09028239000000
Encoding: 0031142
Operating Number: WSC 32825 001 1048576
VCID: B73EACBDC620793E7B-80E2
"1 error found:"
00664 - Fuel level indicator.
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 7
Error frequency: 1
Lost Count: 235
Mileage: 169,964 km
Time: 0
Date: 2015.10.28
Time: 02:56:11
Address 19: Diagnostic interface (J533)
Label file: .DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 P, HW: 1K0 907 951.
Component: J533 Gateway H40 1623.
Revision: H40 Serial Number: 190212F1002292
Encoding: 468002
VCID: BD32BE95241C536EA1-80E8
Translated on 08-07-2026, 15:56.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-06-2021, 15:36    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Can you rule out contaminated fuel? Is there also no leak in the fuel system?
Was the old pump defective? Were there shavings in the system, or was the pump simply replaced?
What pressure is being displayed as fuel pressure?
A potential cause could be a high-resistance connection at the pins of the connector on the high-pressure valve.
Just use KData Scope to create a log and then see if and how much the pressure drops.
Michael.
Translated on 08-07-2026, 16:20.
Karma: +807 / -0   Thank you, like it!
Post07-06-2021, 18:19    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
I would like to log the target and actual rail pressure values, along with the injection quantity and engine speed, and try to reproduce the error.
I suspect the deviation occurs when a high injection quantity is used at high engine speeds.
Here are some possible causes that come to mind:
- The software in the engine control unit is not original, and an "utopian" target value is being attempted. The same applies to a fake box connected to the rail pressure sensor.
- The pressure relief valve is not closing properly / is stuck.
- The pump is not delivering enough fuel because: it is worn out (unlikely, as it was a new pump?), the diesel filter is clogged, there is an obstruction in the fuel intake in the tank, the fuel hose is leaking and drawing in air.
While on vacation, someone poured sugar into the gas tank of the Vito, which had some interesting effects. There were occasional, significant drops in power, the engine sometimes stalled completely, and then the car would start running again...
Translated on 08-07-2026, 16:21.
martl10
Post07-06-2021, 22:02    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Thank you very much.
Fuel quality is fine. It has been regularly driven and refueled.
K-filter already replaced.
The pump was replaced with a refurbished unit by the Bosch service.
There were no shavings in the system.
I've created a log now, but the display is messed up. What am I doing wrong?
Thank you, Martin.
Translated on 08-07-2026, 16:23.
Post08-06-2021, 6:44    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
bitte keine sinnlosen Konvertierungen! Wenn man NICHTS macht und die Datei so öffnet wie sie ist, klappt es auch. icon_idea.gif
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
Translated on 08-07-2026, 16:24.
martl10
Post08-06-2021, 20:19    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Hello, so I think it should work now. I double-clicked the file, and it seems to have been converted icon_rolleyes.gif. This one works... I logged the data at the beginning with a cold engine and at the end with the error...
The emergency mode is triggered relatively late, or at a high RPM. Before the pump was replaced (and also about six months ago when I replaced the quantity control valve on the pump), it wouldn't engage at all, even at 3000 RPM.
Hopefully, something can be made out.
Thank you, Martin.
LOG-01-IDE00021_&7.CSV
 File name:  LOG-01-IDE00021_&7.CSV
 File size:  49.33 KB
 Downloaded:  598 times
Dagomanu
Karma: +55 / -0   Thank you, like it!
Possibly check the pressure of the KST support unit.
Check the fuel injection quantity deviation of the injectors. A value above 1 may indicate a faulty injector (only consider the positive (+) range, do not include negative values).
Possibly the new/used HD pump is defective.
Best regards, Dago.
Translated on 08-07-2026, 16:25.
Post10-06-2021, 18:07    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
I immediately found an operating point at approximately 4000 rpm where the desired pressure and the actual pressure closely matched when using the full injection amount.
This implies that the pump cannot be subject to mechanical wear.
Possible causes include a stuck pressure regulating valve or problems with fuel intake, such as those caused by dirt, foreign objects, or leaky hoses.
Is the fuel tank vent working? If the pressure difference can be induced, try a test drive with the fuel cap only very loosely tightened.
Translated on 08-07-2026, 16:26.
martl10
Post16-06-2021, 6:23    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Hello and thank you very much.
Yes, I assume the pump fits, because there's no reason why the old one and the new one would produce the same error message.
The fuel vent is working correctly, I haven't experienced any issues, and there are no changes.
On Saturday, I drove 50km with a trailer, and the misfires were noticeable much earlier.
The next day, the engine worked very well when it was cold, but it started having problems again once it got hot. I've attached another log file.
Thank you.
The error codes currently appearing in the fault memory are 5527 and 5211.
Sunday, June 13, 2021, 9:51:57 PM: 28029
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 21.3.0.0 HEX-NET CB: 0.4543.4
Data as of: 20210314 DS325.0
Label file: DRV\03L-906-018-CFF.clb
Control unit part number: 03L 906 018 HK. Hardware: 03L 907 309 Q.
Part and/or version: R4 2.0l TDI H27 9978
ASAM Dataset: EV_ECM20TDI01103L906018HK 003013 (VW36)
ROD: EV_ECM20TDI01103L906018H_VW36.rod
VCID: FAB875897DB2A45B0D-80AE
2 error codes found:
P0087 00 [104] - -
Sporadically - confirmed - checked since last deletion.
Error priority: 2
Error frequency: 40.
Mileage: 169,967 km
Date: 2024.14.06
Time: 03:14:38
5227 - Fuel system (Bank 1) - Rail/system pressure too low.
P0087 00 [096] - -
Sporadically - unconfirmed - checked since last deletion.
Error priority: 2
Error frequency: 2
Mileage: 170,105 km
Date: 2024.14.11
Time: 17:12:40
Motor speed: 2765.50 rpm.
Vehicle speed: 62 km/h
Coolant temperature: 87 °C
Intake air temperature: 38 °C
Voltage at terminal 30: 13,400 V.
Fuel temperature: 35.2 °C
Average injection amount: 41.87 mg/stroke.
Rail pressure regulation: Status bits 0-7: 4.
Fuel pressure: Actual value: 1,218,400 hPa.
Fuel pressure: Target value: 1,547,500 hPa.
Adaptation factor of the pressure regulating valve: 1.0068.
Fuel level: 28.00 liters.
Readiness: 0 1 0 0 0
 File size:  271.93 KB
 Viewed:  2315 times
LOG-01-IDE00021_&10.CSV
 File name:  LOG-01-IDE00021_&10.CSV
 File size:  36.25 KB
 Downloaded:  384 times
Translated on 08-07-2026, 16:33.
Post16-06-2021, 17:36    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Could you please include the fuel injection quantity deviation in the logging data to improve the temporal resolution?
Is there a measured value used to control the pressure regulating valve?
If so, I would log the following: pressure (target and actual), control signals, and fuel temperature.
The way the control system behaves when the engine is "hot" versus "cold" can provide clues as to where there are issues with the pressure regulation.
Translated on 08-07-2026, 16:40.
Phil.kr
Post12-03-2022, 13:44    Subject: Solution available? Quote
Good day.
Has a solution to this problem been found?
I'm experiencing the same problem. It always goes into limp mode and stalls at 3300 RPM.
P0087: Rail pressure too low.
Already replaced:
Fuel pump.
Auxiliary fuel pump.
Rail pressure sensor.
Control valve.
"Solidarity with the HDP."
Injector, cylinder 2 (due to a return flow volume that was approximately 50% higher).
Sincerely,
Phil.
Translated on 08-07-2026, 16:41.
pasy115
Karma: +3 / -1   Thank you, like it!
Post26-02-2023, 13:31    Subject: Sharan 2013 4Motion 2.0 TDI with 140 hp, engine code CFFB Quote
Hello.
I have been following the issue with the rail pressure on the Sharan with the CFFB engine code, as I am currently experiencing the exact same problem with a vehicle.
Sharan 2012 4Motion, 2.0 TDI with 140 hp, engine code CFFB, mileage 121,000 km.
"In my case, the error is reproducible when I drive at low RPMs and gently accelerate."
That means the engine speed is around 1200-1500 RPM, and I don't even have to fully accelerate for the glow plug warning light to come on in the instrument cluster, and then the car goes into limp mode.
Once you replace the ignition coil, everything goes back to normal.
So far, I have checked and replaced quite a few things, just like you have.
Pre-charge pressure checked -- Target value: 4.5 bar - value was correct.
I have renewed.
Fuel filters.
Control valve on the rail.
Metering valve on the high-pressure pump.
2 injectors replaced.
and the other two injectors were swapped again, this time in a different orientation.
Since there hasn't been any lasting improvement, I wanted to ask if and how you were able to resolve the issues?
What I find implausible is that the error occurs even with very slight acceleration, which, from the perspective of fuel consumption, shouldn't require much fuel.
Because if I avoid driving in that RPM range and drive a bit faster, the car runs without any problems.
Therefore, in the low-pressure fuel supply section, I did not perform any further quantity checks after verifying the pre-supply pressure.
The VW ODIS program I use for diagnostics suggests this fuel rail pressure and quantity test three times in the case of a fuel rail pressure error.
First, directly after the high-pressure pump's fuel inlet, then before the fuel filter, and finally directly at the fuel tank's front unit.
The pre-pressure should be 4.5 bar, and 1.0 liter of fuel should end up in the measuring cup within 30 seconds.
So, good advice is expensive right now, and I really don't want to buy any more unnecessary and expensive spare parts.
So, what happens next?
Translated on 08-07-2026, 16:45.
Karma: +1359 / -0   Thank you, like it!
Post26-02-2023, 19:22    Subject: Sharan 2.0 P0087 - Low Rail Pressure Quote
Please post the complete Autoscan output with the error message.
That makes it easier.
Translated on 08-07-2026, 16:48.
pasy115
Post02-03-2023, 8:52    Subject: Autoscan Quote
Okay, I'll upload it.
Log-WVWZZZ7NZCV031026.txt
 File name:  Log-WVWZZZ7NZCV031026.txt
 File size:  781 Bytes
 Downloaded:  181 times
pasy115
Post02-03-2023, 8:54    Subject: Log of test drives Quote
Log of test drives.
 File size:  87.2 KB
 Downloaded:  228 times
pasy115
Post02-03-2023, 8:56    Subject: Log of test drives Quote
Upload 2-3 log files.
LOG-01-IDE00188_&6.CSV
 File name:  LOG-01-IDE00188_&6.CSV
 File size:  56.31 KB
 Downloaded:  215 times
Translated on 08-07-2026, 16:49.
No new posts Fuel pressure too low (P0087) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low rail pressure, 3.0 CR-TDI General Tips
No new posts P2303 - Ignition Coil B, Primary Circuit: Signal too low Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 3.0 Biturbo P0087 - Insufficient fuel rail pressure Diesel Engine Technology
No new posts Fabia: Low Fuel Rail Pressure - Troubleshooting On-Board Diagnostics (OBD)
No new posts Caddy: Jerky Engine, G28 Sensor, Low Rail Pressure Diesel Engine Technology
No new posts 1.2 TDI CFWA P0087 Delphie CR Injector Diesel Engine Technology
