T5 Caravelle Fault Code Brake
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Tanta007
Post17-07-2023, 20:38    Subject: T5 Caravelle Fault Code Brake Quote
Hello, I'm having a problem with my bus, specifically:
In the fault memory, the braking electronics show the following error:
Relay for Magnet Coil for Brake Pressure 00812
Okay, so now the problem: Brake light switch has already been replaced but without success, as the switch state is not recognized by VCDS. I am assuming a cable break or similar. Can anyone tell me where pins 2 and 3 of the brake light switch go?
Thank you in advance and have a nice Monday.
 File size:  5.14 MB
 Viewed:  752 times
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
dieselschrauber likes this.
Post17-07-2023, 23:08    Subject: T5 Caravelle Fault Code Brake Quote
More information about the vehicle (VIN, year of manufacture, etc.) and a complete vehicle scan would be helpful!
I strongly advise using the correct wiring diagram and the manufacturer's repair manual for such work! Therefore, the following
Statements without warranty and subject to verification:
According to part number, the control unit is from ATE/ITT Automotive and is for the hydraulic unit, with ESP. In this case, the brake light switches and brake pedal switches are housed in a single enclosure and connected with 4 cables.
The brake pedal switch is located between pin 2 (cable color blue/red) and pin 3 (black/green, to ABS control unit pin 37).
Best regards, Richard
Polo V 1,6 Tdi (CAY)
Karma: +782 / -0   Thank you, like it!
Post17-07-2023, 23:12    Subject: T5 Caravelle Fault Code Brake Quote
Usually, you have a pedal switch (adjustable, to adjust, pull out completely and brake once) located at the top of the brake pedal.
Then a push-button or push-rod on the main brake cylinder.
The F84 is different; the switch is located on the brake booster. I would then take a look at the plugs and cables, and a picture would be helpful.
Best regards, Rainer
Tanta007
Post18-07-2023, 7:13    Subject: T5 Caravelle Fault Code Brake Quote
So, T5 Caravelle, year 2006, MKB BNZ, 2.5 4motion, only ESP control needs checking, I can do an auto-scan sometime in the next few days.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seviceintervallanzeige auf Longlife umstellen? Caravelle TDi Diesel Engine Technology
No new posts T6 Caravelle: Top-area cooling, bottom-area heating. Transmission, Chassis, Body & Interior
No new posts T6 Caravelle rear heater only provides cold air Transmission, Chassis, Body & Interior
No new posts Fehlerspeicher 1Z-TDI Diesel Engine Technology
