Tanta007
17-07-2023, 19:38 Subject: T5 Caravelle Fault Code Brake |
Hello, I'm having a problem with my bus, specifically:
In the fault memory, the braking electronics show the following error:
Relay for Magnet Coil for Brake Pressure 00812
Okay, so now the problem: Brake light switch has already been replaced but without success, as the switch state is not recognized by VCDS. I am assuming a cable break or similar. Can anyone tell me where pins 2 and 3 of the brake light switch go?
Thank you in advance and have a nice Monday.
| Description: |
| File size: |
5.14 MB |
| Viewed: |
860 times |
E30_V8 Profi-Schrauber
Joined: 06/15/2022 Posts: 94 Karma: +111 / -0 Location: ...aus dem Herzen der Natur! 2005 Skoda Fabia  Premium Support
dieselschrauber likes this. |
17-07-2023, 22:08 Subject: T5 Caravelle Fault Code Brake |
More information about the vehicle (VIN, year of manufacture, etc.) and a complete vehicle scan would be helpful!
I strongly advise using the correct wiring diagram and the manufacturer's repair manual for such work! Therefore, the following
Statements without warranty and subject to verification:
According to part number, the control unit is from ATE/ITT Automotive and is for the hydraulic unit, with ESP. In this case, the brake light switches and brake pedal switches are housed in a single enclosure and connected with 4 cables.
The brake pedal switch is located between pin 2 (cable color blue/red) and pin 3 (black/green, to ABS control unit pin 37).
Best regards, Richard
Polo V 1,6 Tdi (CAY)
Profile PM Garage |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
17-07-2023, 22:12 Subject: T5 Caravelle Fault Code Brake |
Usually, you have a pedal switch (adjustable, to adjust, pull out completely and brake once) located at the top of the brake pedal.
Then a push-button or push-rod on the main brake cylinder.
The F84 is different; the switch is located on the brake booster. I would then take a look at the plugs and cables, and a picture would be helpful.
Best regards, Rainer
Profile PM WWW Garage |
Tanta007
18-07-2023, 6:13 Subject: T5 Caravelle Fault Code Brake |
E30_V8 wrote: | Hi,
Best regards, Richard |
So, T5 Caravelle, year 2006, MKB BNZ, 2.5 4motion, only ESP control needs checking, I can do an auto-scan sometime in the next few days.
