Polo 9N3: Oil pressure light flickers intermittently
stolley
Karma: +38 / -1   Thank you, like it!
Post02-07-2023, 21:44    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
Hello everyone,
My Polo 9N3 (mileage 615,000 km) is acting up again:
Overall, the oil pressure light illuminated and beeped three times during my return trip.
I've experienced this before - see /viewtopic.php?t=29452.
This time, however, I didn't have to complain about any performance loss.
I naturally checked the oil level - it was correct.
So far, no symptoms. I will not be driving anymore for now, but I am actually driving more carefully after the events.
That might not have been the smartest decision, but at that moment, I just wanted to go home.
In the error memory, such events are not stored, are they?! In the engine control unit, I at least don't see any error messages.
How would you proceed now? My hope is that it might be a problem with the oil pressure switch.
Thank you very much!
Volker
dieselschrauber and E30_V8 likes this.
Post03-07-2023, 4:32    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
Would you like to restart the discussion in your previous post? Everything that needs to be said has already been said there. First and foremost, what needs to be addressed immediately.
stolley
Post03-07-2023, 4:43    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
stolley
Post08-07-2023, 16:42    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
Hello everyone,
Just checked the oil pressure, photos and video attached.
Looks good to me, what do you think?
What I noticed: The engine sound seems to indicate that a piston ring has again worn out due to the camshaft. But this leads more to an error message on the mass flow meter, rather than the oil pressure sensor?
Thank you all!
Polo 9N3: Oil pressure light flickers intermittently - IMG_2040.mov
 File size:  60.95 MB
 Viewed:  523 times
 File size:  2.61 MB
 Viewed:  1107 times
 File size:  1.91 MB
 Viewed:  589 times
E30_V8 likes this.
Post08-07-2023, 18:11    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
I actually don't feel like watching movies. You can simply post the values for temperature, RPM, and oil pressure here (reference values as per RLF).
The engine running sounds almost like a piston has again worn through the camshaft. But this is more likely to result in an error message on the mass flow meter, rather than the oil pressure sensor.
Is it hot today?
stolley
dieselschrauber likes this.
Post08-07-2023, 19:56    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
Hi Herbert,
What does RLF mean?
Values as follows:
Oil Temperature: Approximately 65°C.
Oil pressure at idle speed: approximately 2 bar.
Oil pressure at approximately 2,500 RPM: approximately 4.5 to 5 bar.
Hello, how are you?
Volker
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
dieselschrauber and stolley likes this.
Post08-07-2023, 21:23    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
stolley wrote:
What does RLF mean?
I'm quoting myself from another post:
E30_V8 wrote:
What does RLF stand for?
RLF = Original VW repair manual/workshop manual.
Many technical terms and abbreviations are underlined and punctuated in this forum, and they display an explanation when you hover your mouse over them icon_exclaim.gif
It seems that highlighting doesn't work on the smartphone/tablet...
Best regards, Richard
Polo V 1,6 Tdi (CAY)
stolley
dieselschrauber, Hutfahrer and E30_V8 likes this.
Post20-09-2023, 10:08    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
Short feedback from me:
Since replacing the oil pressure switch, I have been able to drive 7,000 km without the oil pressure light coming on again.
It probably was due to the switch.
Karma: +1100 / -0   Thank you, like it!
Post20-09-2023, 15:12    Subject: Polo 9N3: Oil pressure light flickers intermittently Quote
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Airbag warning light is constantly ill... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light illuminates intermittently with engine ru... Diesel Engine Technology
No new posts ABS Light On: VW Polo 6N1 Troubleshooting Transmission, Chassis, Body & Interior
No new posts ESP light is constantly on. Diesel Engine Technology
No new posts ESP Light On: What It Means & Troubleshooting Diesel Engine Technology
