Touran 1T - Gear Oil Capacity
vwSchrauber
Post03-12-2014, 16:17    Subject: Touran 1T - Gear Oil Capacity Quote
I am currently working on a 1T from 2006 with a 77/105 BKW engine and a 6-speed gearbox, and I am changing the gearbox oil because the gearbox occasionally makes a scratching sound when shifting gears.
According to the manufacturer, 1.9 liters are required. I've been using 0.5 liters and I don't want to use more than 0.5 liters, then it overflows.
Post04-12-2014, 1:31    Subject: Touran 1T - Gear Oil Capacity Quote
Impossible. Where did you drain the oil? The drain screw (17mm Allen key) should be located on the underside of the gearbox.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
vwSchrauber
Post04-12-2014, 7:37    Subject: Touran 1T - Gear Oil Capacity Quote
One should disconnect the lower part of the balance gear (normal drain screw) and keep the rest for storing the shift fork attachment.
Then approximately 1.5 liters are poured in, and the rest is filled in via the reverse gear switch.
That wouldn't be the first transmission from VW that is "overfilled" in a controlled manner...
Post04-12-2014, 16:51    Subject: Touran 1T - Gear Oil Capacity Quote
That will probably be an MQ250.
At least in the Golf 5, it definitely becomes "overfilled," meaning so much comes in that the "control screw" is "under water."
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post05-01-2015, 20:22    Subject: Touran 1T - Gear Oil Capacity Quote
Hello, I strongly advise you to "overfill" the gearbox with 200-300 ccm.
When I was on the 6th gear, the 5/6 gear group was malfunctioning. During the removal, I noticed a rusty bearing there! Specifically, very little oil is found in the gear linkages and bearings in places where people are particularly frugal with fuel and careful about tire wear.
There is a kit with additional preload adjustment shims located between the timing rings, which is intended to improve shifting.
After the overhaul at 50,000 km, it was just as before: slight rattling when shifting. Even with the expensive VAG oil. After approximately 10,000 km, it was easily maintained until today, 158,000 km later (almost) perfectly.
Workshop Tip: Slightly overfill. icon_idea.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
vwSchrauber
Post17-02-2015, 13:03    Subject: Touran 1T - Gear Oil Capacity Quote
I filled it to about 400ml+, and the transmission shifts much more smoothly.
Customer (Sparmeister) called a few days later and was very pleased icon_biggrin.gif
Post17-02-2015, 22:03    Subject: Touran 1T - Gear Oil Capacity Quote
What exactly do you mean by "overcrowding"?
(1) Beyond the specification, which already exceeds the side screw.
(2) simply through the hole, in order to achieve the requirement as easily as possible.
DieselBär30x
Avatar-DieselBär30x
Post17-02-2015, 22:40    Subject: Touran 1T - Gear Oil Capacity Quote
Hello everyone!
Martin, there are very clear instructions here regarding the RLF, specifically that the gearbox oil fill opening should NOT be seen as the maximum level, as the oil level is higher.
Affects in relation to R. exclusively the transversely mounted engine-gearbox combinations with a design-related (and further "unplanned?") inclination of the gearbox.
I had previously posted an excerpt here, but unfortunately, I can't find it anymore using the search function.
Best regards from Munich!
Post17-02-2015, 23:21    Subject: Touran 1T - Gear Oil Capacity Quote
Yes, I understand that the MQ250 needs to be filled higher than "the screw".
The MQ350, however, is different.
What do you mean by "overfilling by 300ml"?
So, nochmal 300 ml mehr, als bereits vorgeschrieben?
Post18-02-2015, 14:40    Subject: Touran 1T - Gear Oil Capacity Quote
What do you mean by filling it to 300ml?
If I remember correctly -> 300ml above the bottom of the filling screw... means to fill up to the dripping point on a flat surface, then + 300ml.
Post19-05-2024, 13:18    Subject: Touran 1T - Gear Oil Capacity Quote
kreysel wrote:
Alternatively, you can collect the drained oil in a measuring container and add as much back as has been drained. If there has been no oil loss, it should then fit again. Since I can't find any fill volumes, I'll have to go back to doing it this way "
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document Touran 1T, Driving Performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V 1.4 BUD - Coolant capacity? Gasoline Engine Technology
No new posts Climatronic Passat 3BG - Correct refrigerant charge at ATU? Transmission, Chassis, Body & Interior
No new posts Gear Oil: Buy Online | Best Prices Diesel Engine Technology
No new posts Change Transmission Fluid: DIY Guide & Tips Diesel Engine Technology
