VCDS HEX-USB+CAN: CAN bus not ready
stolley
Karma: +38 / -1   Thank you, like it!
Post11-03-2024, 7:49    Subject: VCDS HEX-USB+CAN: CAN bus not ready Quote
Good morning, everyone.
This morning I updated VCDS on my computer, and after running the connection test, I'm getting a message that the CAN bus is not ready.
So far, VCDS has always worked without any problems.
Do you have any advice for me?
 File size:  23.68 KB
 Viewed:  564 times
Post11-03-2024, 9:21    Subject: VCDS HEX-USB+CAN: CAN bus not ready Quote
Was the interface connected to a vehicle with CAN communication via the OBD2 connector during the interface testing, and was the ignition turned on?
stolley
Post11-03-2024, 21:48    Subject: VCDS HEX-USB+CAN: CAN bus not ready Quote
Hello Rainer,
Thank you for your reply.
The ignition was on, and it was also plugged into the OBD2 port. But I'm not 100% sure if the Polo 9N3 is a vehicle that uses CAN bus technology.
LG
Volker.
Post11-03-2024, 23:29    Subject: VCDS HEX-USB+CAN: CAN bus not ready Quote
Your classic car should use the K-Line for diagnostics.
VCDS on classic cars, compatibility
Recognizable by the red stripe, specifically for the Polo 9N model.
stolley
dieselschrauber likes this.
Post12-03-2024, 22:02    Subject: VCDS HEX-USB+CAN: CAN bus not ready Quote
I've now connected VCDS to a newer vehicle again and performed the connection test. This time, the CAN test was also successful!
Now that the configuration is complete, I can also read data from my old device again – which wasn't working before.
But I probably made a mistake somewhere else.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: CAN Bus Not Ready - Troubleshooting On-Board Diagnostics (OBD)
No new posts CAN Error: Not Ready - Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts CAN Communication Error: Not Ready After Test Electrical Systems, Vehicle Electronics, Multimedia
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
