Brake Cleaner: Bosch vs. Pierburg - Which is Best?
Manuel Thomas
Post13-06-2003, 17:49    Subject: Brake Cleaner: Bosch vs. Pierburg - Which is Best? Quote
Is this tip about cleaning with brake cleaner only applicable to Bosch mass airflow sensors, or can I also use it on my older, one-piece Pierburg sensor?
What is the minimum safe distance that must be maintained when spraying?
Thank you all!
The topic can be deleted by the moderators after it has been answered.
Manuel.
Translated on 29-08-2026, 4:28.
Post14-06-2003, 5:48    Subject: Brake Cleaner: Bosch or Pierburg for LMM? Quote
Manuel Thomas wrote:
Does the tip for cleaning with brake cleaner only apply to the Bosch MAF sensor, or can I also use it on my old, one-piece Pierburg MAF sensor?
What is the minimum distance that must be maintained when spraying?
Hi Manuel,
I also treated my old Pierburg with brake cleaner. After that, my tractor didn't run noticeably better, but apparently nothing broke icon_wink.gif.
I had pushed the nozzle through the grid until it was about 1 cm away from the sensor plate (the middle one of the three "rods").
Translated on 29-08-2026, 4:29.
Julian
Post14-06-2003, 7:19    Subject: Brake Cleaner: Bosch vs. Pierburg - Which is Best? Quote
It works perfectly. I've already cleaned several MB-LMMs (or better, HMLMs) with it. Just be careful not to let the brake cleaner touch the 'sensor plate,' that's all.
Translated on 29-08-2026, 4:30.
diesel.gustav
Post14-06-2003, 22:02    Subject: Brake Cleaner: Bosch vs. Pierburg - Which is Best? Quote
Deleted upon request.
Translated on 29-08-2026, 4:31.
Manuel Thomas
Post14-06-2003, 22:54    Subject: Brake Cleaner: Bosch vs. Pierburg - Which is Best? Quote
I took out the mass airflow sensor today!
According to the production date, it was the first one. This one has now lasted 210,000 km without any problems!
Apparently, Pierburg components are not as prone to failure as Bosch components!
Since I arrived late, I didn't have time to clean it. I'm unfortunately afraid of breaking it, and then being without a working engine, because all the shops are closed, and I have to drive 300km to work on Sunday.
I will clean the sensor next week, during the dealer's opening hours!
However, I noticed that the grille on the air filter side was so dirty that it was blocking about 1/4 of the airflow. I cleaned it, and I can already feel a positive effect!
Manuel.
Translated on 29-08-2026, 4:32.
Julian
Post14-06-2003, 23:23    Subject: Brake Cleaner: Bosch vs. Pierburg - Which is Best? Quote
Hello Julian,
Argh...it seems I was too late...I meant 'HeißfilmLMM,' or better, 'mass airflow sensor.' icon_wink.gif
Translated on 29-08-2026, 4:33.
Manuel Thomas
Post19-06-2003, 18:33    Subject: Brake Cleaner: Bosch vs. Pierburg - Which is Best? Quote
Okay, I did it today!
It was quite simple, and a decent amount of black liquid came out of the LMM.
Actually, it's not surprising, especially after seeing the grid.
I actually thought I didn't have an LMM (lambda sensor) problem, but you can definitely notice a significant difference starting around 170 km/h.
He achieves the maximum speed as before, but now it takes 4 seconds less to reach it, specifically from 100-200 km/h in fifth gear.
Manuel.
Translated on 29-08-2026, 4:34.
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Bosch ABS/ESP 5.3: Basic Settings & Configuration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts LMM Pierburg: Replacement for Bosch Mass Air Flow Sensor Diesel Engine Technology
No new posts Galaxy: Replace Pierburg MAF sensor with Bosch? Diesel Engine Technology
No new posts DPF Removal vs. Cleaning: Which is Best? On-Board Diagnostics (OBD)
No new posts 1.9 TDI AFN: Use Pierburg MAF from Mercedes Sprinter? Diesel Engine Technology
