Software for BMW?
Heiner111
Karma: +27 / -0   Thank you, like it!
Post12-05-2024, 20:03    Subject: Software for BMW? Quote
hello,
I once bought a VCDS device and the adapter for my Audis here. Now my daughter has a Mini (which is a BMW).
I just read that, surprisingly, it's apparently possible to read the engine control unit of BMWs with VCDS, but probably not much else.
So it seems that the adapter can also be used with BMW vehicles. Is there now any affordable software with a similar range of features to VCDS?
Here, I found older posts suggesting that there's nothing comparable to it. But those were already more than 10 years old.
Does anyone else carry BMW parts in addition to VCDS, and can anyone recommend anything?
Andreas
Ich_Can_nix
dieselschrauber likes this.
Post12-05-2024, 22:59    Subject: Software for BMW? Quote
Hello Andreas,
There are many possible solutions.
First of all, I would like to recommend this tool to you, which is available in our shop.
https://shop.dieselschrauber.org/en/obd-diagnosegeraet-p-363.php
It's a small, sleek multi-brand tool that offers a good level of diagnostic depth for BMW vehicles. And you can find support here.
What expectations do you have for this tool?
I personally use the OEM Tester as an organizational tool. Version.
as well as with Bimcom, BimmerLink, and Bimcom.
BimCom is very similar to VCDS in terms of structure and function, and the updates are free of charge.
Diagnosis is very good; coding and replacing control units are partially possible.
Bimmerlink only for diagnostics / data readings.
Bimmercode can only be used for coding.
To the best of my knowledge, they don't offer any support or a forum. I would prefer not to commit to a specific course of action here, as I can always seek support from the AOS portal if needed.
Michael.
Heiner111
Post20-05-2024, 10:12    Subject: Software for BMW? Quote
Thanks, that helped me a bit. The CG680pro seems really good and offers an interesting price-performance ratio. Although the description doesn't clearly explain what it can do compared to VCDS. But since I already have the latter, including the adapter and laptop, I was thinking more of a purely software-based solution. Bimcom would probably be an option, but at almost 700 euros, it's way too expensive for occasional use on just one vehicle. Maybe Bimmerlink or Bimmercode in combination. However, even in this case, I have only found inadequate descriptions so far.
Perhaps someone else has tips based on their own experience or application?
Heiner111
Post31-07-2024, 21:52    Subject: Software for BMW? Quote
After a long break due to lack of time, I've revisited the topic. Unfortunately, Bimmerlink/-com is only a temporary solution for smartphones. It would only be suitable for emergencies; it's too uncomfortable for longer tasks like extended error scans, and the screen is too small for measurements, etc.
While it's often said that you can access the OBD functions with VCDS, nothing is happening for me. Rheingold/INPA also seems to be overloaded and complicated, but opinions on that seem to be divided in the forums.
Despite all its quirks, VCDS seems to be far superior to BMW's solutions. Perhaps that's why there are so many different versions for BMW/Mini, because none of them are truly satisfactory. BimCom would probably be the best option, but as I mentioned before, it's no longer acceptable for private users given that it costs twice as much as VCDS.
I am open to further suggestions. Best regards,
Andreas
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Update software On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Update ALH on ASV software? On-Board Diagnostics (OBD)
No new posts VAS software on a laptop? On-Board Diagnostics (OBD)
No new posts AFN/ALH Technology: Software & Systems Diesel Engine Technology
