DSG Lifespan and Durability
Go to page: 1, 2  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post16-04-2018, 10:16    Subject: DSG Lifespan and Durability Quote
Some vehicle models are now only available with DSG (direct-shift gearbox) instead of a manual transmission.
How is the lifespan of dual-clutch transmissions (DSG) doing today?
Please share your experiences with...
- DSG Type
- Vehicle Model
- Distance covered
- Chiptuning: Yes/No
- Possible damage at ... (mileage)
Best regards, Rainer
JohannLeon
dieselschrauber likes this.
Post16-04-2018, 21:10    Subject: DSG Lifespan and Durability Quote
- DSG Type DQ200
- Vehicle model Octavia Combi 1Z5 1.6 TDI
- Odometer reading: 151,000 km
- No chiptuning
- Clutches and DMF replaced at 108,000 km
The reason for the disassembly (repair) of the DSG was a noise - a small metal part was found that was causing the noise. The origin of the part could not be determined. The clutches were still okay, but were replaced because they were already removed.
Johann
Skoda Octavia Combi EZ 01/2011 Motor CAYC, DSG, Standheizung
151 tkm
vag-driver
Post29-05-2018, 14:43    Subject: DSG Lifespan and Durability Quote
New purchase:
- DSG Type DQ250
- Vehicle model VW Sharan 7N
- Mileage 24000 km
- Chiptuning yes/no No
- Possible damage at ... (mileage) - still none - hopefully remains so...
Andreas
Linse83
Post02-06-2018, 10:40    Subject: DSG Lifespan and Durability Quote
Vehicle was newly purchased, manufactured in 1/2016
- DSG Type DQ200
- Polo 6C GTI
- Mileage: 23,000 km
- Chiptuning is allowed (further enhanced clutch installed and torque increased to 460 Nm, no OEM turbocharger installed.)
- no damage
It should also be noted that the shifting behavior with OEM software was a disaster, with wild and erratic shifting and clunking noises... all these issues have been resolved since the optimization.
hVgti
2010 Volkswagen Golf
Post26-06-2018, 22:17    Subject: DSG Lifespan and Durability Quote
- DSG Type: DQ250
- Vehicle Model: Golf 6 GTI CCZB
- Mileage: 101200
- Chiptuning yes, since approximately 30,000 km
- Potential damage at ... None, but required recalibration/reprogramming at approximately 80,000 km due to harsh downshifting.
Golf 6 GTI - DSG - MKB: CCZB - MJ: 2011
Karma: +438 / -0   Thank you, like it!
Post28-06-2018, 10:49    Subject: DSG Lifespan and Durability Quote
- DSG Type DQ350
- Vehicle model VW Passat 3C BMP / KCU 2007
- Mileage 310.000 km
- Chiptuning No
- Possible damage at ... (Mileage) According to VW history, the mechatronic and the entire DSG gearbox were replaced by the previous owner in 2008 at approximately 85,000 km. Taken over in 2009 with 105,000 km. In the last three to four years, approximately once a year, the gearbox would remain in first gear when starting and would not shift to second gear. Restarting the vehicle resolves the issue. Can I live with it?
Petrol
Post02-12-2018, 18:39    Subject: DSG Lifespan and Durability Quote
Part Number: GSG DSG AG6 511 2602
Revision: 05351112 Serial Number: 00001012040962
Encoding: 0000020
Operating Number: WSC 05311 000 00000
VCID: 1B1A8C07DA30849220-804E
Passat (Var.) 3C/7B (Year 2011)
Mileage: 198000km
Chiptuning no
no damage
Switching operations (cold or warm) without any noticeable issues
First oil change at 112,000 km, then at 180,000 km, both with {PRODUCT_NAME}
ATF oil change machine including cleaner/lube (approx. 13 liters). The last batch of used oil was quite a dark, brownish liquid.
No signs of coolant in the oil.
tdi-erwin
Post04-12-2018, 15:18    Subject: DSG Lifespan and Durability Quote
DSG TYPE: GSG DSG 081 1403
Vehicle Model: Golf 5+ Year: 08/2007 First Owner
Mileage: 136,700 km, including approximately 15,000 km with a caravan.
Chiptuning: no
No damage! Oil change at approximately 60,000 and 110,000 km.
Normal/Unauffällig.
Best regards
tdi-erwin
Boldor
Avatar-Boldor
Karma: +20 / -0   Thank you, like it!
2014 Volkswagen Sharan Consumption
Post10-04-2019, 20:39    Subject: DSG Lifespan and Durability Quote
DSG Type: DQ250
Vehicle Model: Golf V Variant 1.9 TDI BLS
Running distance: 329 TKm
Chiptuning: no
All-round, 60 TKm oil change, no repairs or damage.
Completely unremarkable behavior.
Greetings
Ralf
Für mich gibt es keine Alternative...
VW Tiguan 5N 2,0 TDI 4Motion mit DSG
(125TKM)
Motorcode: CFGC /Bj.2014
VW Sharan 7N 2.0 TDI mit DSG
(254TKM)
Motorcode: CFFB /Bj. 2014
Flac
Karma: +13 / -0   Thank you, like it!
Post22-12-2019, 0:14    Subject: DSG Lifespan and Durability Quote
DSG Type: DQ250
Vehicle Model: Golf VI GTD
Mileage: 200tkm
Chiptuning: no
No problems until the sale.
vag-driver
dieselschrauber and Rüdi likes this.
Post06-02-2020, 12:58    Subject: DSG Lifespan and Durability Quote
DSG Type DQ250
- Vehicle model VW Sharan 7N / Year of manufacture 2015
- Mileage 54000 km
- Possible damage at ... (mileage) - no damage - Oil change has just been performed. Although I didn't have any problems with the gear shifting, the oil change is noticeably better. Gear changes are now faster and smoother. I strongly advise everyone to get their oil change sooner rather than later.
Andreas
Hans Dampf
Karma: +9 / -0   Thank you, like it!
2013 Ford Galaxy
dieselschrauber, brezelmann01, guste100, Rüdi and Herbert likes this.
Post07-02-2020, 11:08    Subject: DQ250 Damage Quote
DQ250 (GKB "HUW")
Audi A3 V6, Year: 2005
183 tkm
Chiptuning: no
The vehicle required a 3rd DSG oil change at 183tkm. While loosening the overflow pipe to drain the oil, it made a brief clicking sound, and the overflow pipe broke above. After a long search with the endoscope, I discovered that the parking lock wheel (which is located on the differential) had moved and had worn away the overflow pipe during operation. A new overflow pipe could no longer be installed because the parking lock wheel was located directly above the drain screw.
So far, the transmission has been functioning perfectly, and the parking lock has also been working without any issues.
Please see the attached images for context.
 File size:  364.1 KB
 Viewed:  2307 times
 File size:  343.64 KB
 Viewed:  2344 times
 File size:  3.2 MB
 Viewed:  2018 times
 File size:  3.01 MB
 Viewed:  1971 times
 File size:  2.29 MB
 Viewed:  3568 times
Audi A4 AKE
Scout5e
Post15-08-2020, 17:52    Subject: DSG Lifespan and Durability Quote
- DSG Type: DQ250
- Vehicle Model: Octavia 5E Scout 2.0 TDI 4x4
- Odometer reading: 108998km
- Chiptuning: no, instead, regular towing between 0.6 and 1.8 tons
- Possible damage at: no damage, no tears, no noise. Turn on softly.
Gear oil change at 59750km, gear flush planned at 119500km, not just a simple change.
dennis91
Post11-10-2020, 22:45    Subject: DSG Lifespan and Durability Quote
- DQ250
- Passat Variant B8 2.0TDI 190PS
- Odometer reading: 71,500 km
- Oil change at 60,500 km
- No chip tuning
- So far, no problems
Boldor
Avatar-Boldor
Post12-10-2020, 20:42    Subject: DSG Lifespan and Durability Quote
Update:
DSG Type: DQ250
Running distance: 356 TKm
Chiptuning: no
Greetings
Ralf
(125TKM)
(254TKM)
Flac
Post06-12-2020, 12:25    Subject: DSG Lifespan and Durability Quote
Golf 6 GTD
DQ 250
Absolutely no issues until sale with 200,000 km.
Currently, a Golf 7 GTD (DQ250) has been remapped, and despite having 90,000 km on the odometer, there are no issues.
No new posts 1.8T Engine: Reliability and Durability Diesel Engine Technology
No new posts H7 Bulb Lifespan: How Long Do They Last? Diesel Engine Technology
No new posts Fuel Injector Lifespan: How Long Do They Last? Diesel Engine Technology
No new posts Durable PDEs: Longevity and Reliability Diesel Engine Technology
