Relay for Skoda Octavia 1U5
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
claus49
Post08-08-2024, 20:13    Subject: Relay for Skoda Octavia 1U5 Quote
Hello everyone,
Can anyone explain the function of relay 3 in the Skoda Octavia 1U5?
In the wiring diagram (from "So wirds gemacht"), the relay is labeled "Amplifier for lighting," and its part number is 1U0 941 243 C.
It has 6 connection pins and consists of a circuit board with 3 silicon diodes and 3 low-power metal film resistors.
Its connections include 3 different positive terminals, 1 for the trunk light, 1 for the seat heater lamp, and 1 for the ventilation control lamp.
I cannot detect any amplification effect from the combination of components, nor do I see any purpose for these low current loads in general.
I would be very grateful for any explanatory notes.
Greetings.
Claus.
Translated on 02-09-2026, 12:08.
Post08-08-2024, 20:40    Subject: Relay for Skoda Octavia 1U5 Quote
The book series you mentioned already had issues with incorrect wiring diagrams in my Audi A3 8L... I suspect a translation error.
Using three diodes, it would be possible to create a simple, non-blocking "OR" functionality.
For example, a shared light turns on when any one of several switches is activated and provides power to one of the inputs, without simultaneously providing power to the remaining inputs.
Translated on 02-09-2026, 12:10.
claus49
dieselschrauber likes this.
Post09-08-2024, 23:48    Subject: Relay for Skoda Octavia 1U5 Quote
Thank you for this description. I will try to create a circuit diagram of the relay to verify this circuit configuration.
Greetings.
Claus.
Translated on 02-09-2026, 12:11.
Karma: +1349 / -0   Thank you, like it!
Post10-08-2024, 8:14    Subject: Relay for Skoda Octavia 1U5 Quote
The term "Relais 3" probably isn't quite right. It likely refers to the relay in slot 3 of the relay carrier, which is actually labeled as "Amplifier for Lighting" in the RLF documentation. I suspect a translation error from Czech or English ("Controller" or "Control Unit").
Do you have a wiring diagram from Etzold, and if so, could the relevant part be sketched out for discussion here?
And - curiosity - what's the problem behind it?
Translated on 02-09-2026, 12:12.
Karma: +646 / -0   Thank you, like it!
Post11-08-2024, 17:29    Subject: Relay for Skoda Octavia 1U5 Quote
This relay is used for various purposes within the Volkswagen Group, and essentially it only serves to switch voltages on and off.
Translated on 02-09-2026, 12:13.
claus49
Post19-08-2024, 22:25    Subject: Relay for Skoda Octavia 1U5 Quote
I mentioned that I wanted to create a circuit diagram for the relay. Unfortunately, it took a bit longer than expected.
The terminals of the relay are not labeled, so I couldn't include any labels in the diagram. I took the "3 Plus" input labels from Etzold's diagram. I already described the outputs in my first post.
Looking at the circuit, I would associate the 1N5406 component with the power consumption of the trunk light.
However, the function of all the components is completely incomprehensible to me, and I wonder why the outputs weren't simply connected directly to the positive terminal. What is the purpose of the diodes?
The question was about the reason for my inquiry: The trunk light stopped working in hot weather. When it gets cooler in the evening, it works again. And no, the microswitch in the tailgate lock is fine; the problem is actually a lack of power reaching the lamp.
Greetings.
Claus.
 File size:  2.95 MB
 Viewed:  307 times
Translated on 02-09-2026, 12:14.
Herbert likes this.
Post20-08-2024, 8:09    Subject: Relay for Skoda Octavia 1U5 Quote
The diodes prevent current from flowing in reverse.
Translated on 02-09-2026, 12:15.
Post20-08-2024, 8:58    Subject: Relay for Skoda Octavia 1U5 Quote
To be more precise, above 58, the two control lamps receive a small amount of current (dimmed) through the resistors when the light is on, while above 58b, the current flows through the instrument lighting regulator. Of course, you wouldn't want to short-circuit these two sources. It would also make sense to use the 15 with a fuse instead of the 58.
I don't know why the trunk light is going through the diode. Perhaps the common ground point in the rear is playing a role.
Translated on 02-09-2026, 12:16.
claus49
Post20-08-2024, 20:29    Subject: Relay for Skoda Octavia 1U5 Quote
Thank you for the information; I learned something new.
Greetings.
Claus.
Translated on 02-09-2026, 12:17.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1.9: Specs, Problems, & More On-Board Diagnostics (OBD)
No new posts Skoda Octavia 1Z5 RS Cornering Light On-Board Diagnostics (OBD)
No new posts Skoda Octavia ABS Fault Transmission, Chassis, Body & Interior
No new posts Skoda Octavia 5E battery coding Electrical Systems, Vehicle Electronics, Multimedia
