Mercedes-Benz Sprinter 907 BMS battery pairing
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
ruler
Post10-12-2024, 19:43    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
Hello everyone,
I have been the owner of a Mercedes-Benz Sprinter of the 907 series for a few days now.
I had to replace the battery there. Now, I want to inform the BMS that a new battery has been installed.
Since I also own the CG680Pro from CGSULIT in addition to VCDS, I wanted to use it to connect to the BMS control unit. Unfortunately, I'm unable to establish a connection. "I'm seeing several control units listed, such as BMS front, BMS center, etc., but I'm unable to connect to any of them."
I can access the engine control unit without any problems and read live data, clear error codes, etc.
I've been reading a lot online about Mercedes' Safety Gate Way (SGW) and that it's not as easy to bypass as some people claim.
Does anyone have experience with the Sprinter 907 and the CG680Pro?
Can someone tell me if access is possible?
Thank you in advance.
Best regards, Thomas.
Karma: +796 / -0   Thank you, like it!
Post10-12-2024, 21:11    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
Hello Thomas,
Unfortunately, I have no idea about the 907. However, specific data about the vehicle or the vehicle's onboard network control unit would be helpful.
ruler
dieselschrauber likes this.
Post11-12-2024, 16:16    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
Hi Rainer,
It's a Mercedes-Benz Sprinter model 907, manufactured in April 2020, with a 2.1L 216 CDI (OM 651) engine producing 163 horsepower.
The image attached shows the battery management systems.
I need to fix something, but I can't access the engine control unit. Only in the control panel housing and some other control units.
If I want to use the BRT function, I can't even select model 907.
 File size:  3.91 MB
 Viewed:  1480 times
 File size:  4.66 MB
 Viewed:  1415 times
ruler likes this.
Post11-12-2024, 17:21    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
I followed up and am waiting for a response from the manufacturer. icon_idea.gif
ruler
Post04-02-2025, 11:49    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
Hello Mr. Kaufmann,
Have you received any feedback on this?
Post04-02-2025, 17:29    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
ruler wrote:
Hello Mr. Kaufmann,
Did you receive any feedback on this?
It seems to have disappeared, but I noticed that the Sprinter isn't listed under Mercedes (for passenger cars), but rather under "Sprinter." Did you choose the right vehicle?
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
ruler
Post08-02-2025, 18:20    Subject: Mercedes-Benz Sprinter 907 BMS battery pairing Quote
As I mentioned, if I want to use the BRT function, I can't even select the Mercedes model 907. I can't select the "Sprinter" option directly from the menu.
Regarding diagnosis, it's possible to directly select the Sprinter model, rather than going through Mercedes -> Sprinter, but directly. However, I can't access the control units there, as shown in the images attached in previous posts.
I've heard that Mercedes-Benz has separated its passenger car and commercial vehicle divisions. I don't know to what extent this will affect diagnostic software.
Furthermore, my vehicle has a truck registration from the factory. Okay, the key number is 2222/ARL, not 1313/xxx.
No new posts Documentary: LD errors on the Sprinter 315CDI, two-stage ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2002, Batterie entladen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Batterie (Akkumulator): Tipps zu Check und Wartung Technical Articles
No new posts Mercedes-Benz S124 200Td: More power and at least a 30% l... Diesel Engine Technology
No new posts OBD beim Mercedes Sprinter On-Board Diagnostics (OBD)
No new posts Mercedes Sprinter 311 CDI misfires and EDC light is on Diesel Engine Technology
No new posts Golf 6 Variant 1.6 TDI Battery Registration/Calibration Electrical Systems, Vehicle Electronics, Multimedia
