Schmierpfote Schrauber
Joined: 07/31/2016 Posts: 93 Karma: +21 / -0 Location: Erfurt
11-12-2024, 7:17 Subject: Rejected by the control unit, VCDS |
Hello everyone in the forum,
Basically, I can select whatever I want, but I'm only getting error messages from the control unit. What can I do to get it working again? Best regards, Wolfgang.
Profile PM Email |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
dieselschrauber likes this. |
11-12-2024, 10:27 Subject: Rejected by the control unit, VCDS |
Hi Wolfgang,
"I have a German car that is having a problem with the transmission." What can I do?
Do you understand?
Both requests are missing a significant amount of crucial information.
At your place:
- Vehicle / Car scan.
- which ECU?
- Which login are you using?
- What is the goal?
Guste.
Profile PM Garage |
11-12-2024, 16:26 Subject: Rejected by the steering device |
Hello Guste,
Thank you for the help. I tried to start the "SCR efficiency test" via motor electronics and basic settings, but no matter what I select in the dropdown list, I get an error. Extended measurements, etc. are working fine.
My VCDS software doesn't like Windows 11 or the HP laptop.
| Description: |
 Download |
| File name: |
Log-HX-WV2ZZZ7HZHH091255-316430km-scan.txt |
| File size: |
12.95 KB |
| Downloaded: |
1165 times |
Profile PM Email |
11-12-2024, 18:01 Subject: Rejected by the control unit, VCDS |
Okay.
It's been a long time since I last adjusted the basic settings.
Is a login prompt displayed when you click on the "Login" button?
guste100 wrote: | | - Which login is being used? |
Profile PM Garage |
11-12-2024, 18:11 Subject: Rejected by the control unit, VCDS |
Hello Guste, select the engine control unit, choose the basic settings, and then select from the dropdown menu what you want to check.
Press "Start" to begin. I'm getting an error, and no suggestions are being offered.
Profile PM Email |
12-12-2024, 17:03 Subject: Rejected by the control unit, VCDS |
Hello Wolfgang,
I have to admit that I'm starting to lose interest, as you're not providing the information I'm looking for. Therefore, here's one last attempt:
guste100 wrote: | Is a login prompt offered to you when you click on "Login"?
guste100 wrote: | | - Which login is being used? | |
Please go to the MSG page, and then click on "Login" instead of "Reset to Default."
If none of that works, I'm afraid I'm completely clueless.
Profile PM Garage |
12-12-2024, 18:12 Subject: Rejected by the control unit |
Hello Guste,
There's a guide in the forum by Rainer titled "Calibrating the NOX DPF sensor." As I mentioned, select "Check SCR efficiency" from the dropdown menu and press "Start." Now the VCDS program is running. I'm getting an error message. I will go to the MSG this weekend, as you wrote, and then to Login.
I will report, greetings Wolfgang.
Profile PM Email |
Joined: 04/12/2002 Posts: 18138 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
Profile PM WWW Garage |
12-12-2024, 18:43 Subject: Rejected by the steering device |
Thank you, Rainer.
Greetings, Wolfgang.
Profile PM Email |
15-12-2024, 15:15 Subject: Rejected by the steering device |
Hello Rainer and Guste,
Thank you for your help.
No error codes found.
Profile PM Email |
