Coding Haldex 4 Control Unit
MH-Softwaretuning
Post10-03-2025, 18:51    Subject: Coding Haldex 4 Control Unit Quote
Hello.
I hope someone can help me here. I installed a new Haldex unit, using what was supposed to be the same Haldex control unit. Now I'm having a small problem: the diagnostic system shows "Transmission control unit, no communication." I thought it might possibly be related to coding.
Unfortunately, VCDS doesn't provide a list; it directs me to contact support via email. I disassembled the old ECU, and to my dismay, it was completely corroded. I'm attaching everything to the email.
I hope it can be resolved. Available tools: VCDS, VCP, Odis S, Odis E.
Thank you for your help.
Vehicle: VW Tiguan, Year of Manufacture: 09/2009.
Engine code: CBA, 103 kW.
 Haldexstg. Original
 File size:  340.77 KB
 Viewed:  2079 times
 Haldexstg Gebraucht
 File size:  322.97 KB
 Viewed:  1943 times
Haldex Original.rar
 Steuergerät Abbild Original Haldexstg.
 File name:  Haldex Original.rar
 File size:  2.36 KB
 Downloaded:  732 times
Haldex Gebraucht.rar
 Steuergerät Abbild Gebrauchte Haldexstg.
 File name:  Haldex Gebraucht.rar
 File size:  2.36 KB
 Downloaded:  664 times
Log-WVGZZZ5NZAW019820-183650km.txt
 Log mit Gebrauchten Haldexstg.
 File name:  Log-WVGZZZ5NZAW019820-183650km.txt
 File size:  11.49 KB
 Downloaded:  683 times
Post10-03-2025, 20:29    Subject: Coding Haldex 4 Control Unit Quote
According to your files, the old and new Haldex control units have the same coding.
SW:0AY-907-554-C HW:0AY-907-554-C --- All-wheel drive.
Component: Haldex 4Motion, Code: 0000005.
If you are certain that the used Haldex control unit actually works, the next step is to investigate why it is communicating with a transmission control unit, which seemingly doesn't exist because there is a manual transmission.
Are you sure that the old Haldex control unit was original and not incorrectly programmed or the wrong control unit?
Edit: Found it.
Error code 01315 is triggered when there is no communication with the automatic or DSG transmission via the CAN network. This error usually occurs because a used Haldex control unit, originally from a car/DSG vehicle, has been installed in a vehicle with a manual transmission.
The Haldex control units are pre-configured to work with the correct type of transmission. You can replace an automatic transmission control module with a manual transmission control module, but not the other way around.
If you want to get rid of code 01315, simply use VCDS or another good diagnostic tool:
- Go to the 22-AWD module, navigate to "Basic Settings," select channel number "20," and then click the "On" button at the top of the window.
- After that, turn the ignition off, then on again, and you will find that the 01315 code has been cleared.
MH-Softwaretuning
dieselschrauber likes this.
Post10-03-2025, 20:37    Subject: Haldex 4 Quote
Hello Rainer.
I am aware of that. But with the old TCU, I had the DTC code 02248 from the pressure control valve, and everything was fine after I cleared it. I will test tomorrow to see if the all-wheel drive is working, but I won't receive the filter package and oil until tomorrow. Then I will test it. It's strange, though, that the numbers 5WP33522-02 0902 from the O-ring and 5WP33522-01 2458 might be related to this. I've never experienced anything like that before.
MH-Softwaretuning
Post10-03-2025, 20:46    Subject: Haldex 4 Quote
I wanted to let you know that it worked, setting the basic configuration to channel number 20 and turning it ON. icon_smile_thumb_up.gif Thank you for the information; I wouldn't have figured that out.
Post10-03-2025, 21:06    Subject: Coding Haldex 4 Control Unit Quote
Great, thanks for the feedback!
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding the ABS control unit for a Polo 6n On-Board Diagnostics (OBD)
No new posts Haldex Gen4 Control Unit Replacement Transmission, Chassis, Body & Interior
No new posts AHK Coding On-Board Diagnostics (OBD)
No new posts Motorcycle ECU Programming: How To Guide On-Board Diagnostics (OBD)
