"Engine running via K-line," VCDS
Post05-02-2025, 19:06    Subject: "Engine running via K-line," VCDS Quote
Today, I received the following request:
After I downloaded the latest software and installed the new interface, I received the following message when reading the data from the TIGUAN:
"The 'Motor via K-line' option is enabled." (see attachment).
Unfortunately, I can't find any information in the manual or on the forums that I can understand.
What can I do about that?
Autoscan:
Friday, January 31, 2025, 2:11:04:17815
VCDS, a Windows-based VAG/VAS emulator, now runs on Windows 11 x64.
VCDS Version: RKS 24.7.1.0 HEX-V2 CB: 0.4643.5
Data as of: 20241105 DS356.3
Vehicle Identification Number: WVGZZZ5NZJW000000 License Plate: -
Mileage: 000000 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
42 44 4B 52 5F 6C 6D 82 A5 BB BC CF D6 D7
Vehicle Identification Number: WVGZZZ5NZJW000000 Mileage: 000000 km
01-Motor electronics -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module.
unavailable
Cannot reach address 01.
The "Motor via K-line" option is enabled.
http://shop.dieselschrauber.org/en
Solution:
Within the VCDS program settings, there are checkboxes that allow you to specify whether the engine should be accessed via the K-Line interface instead of the CAN bus. This makes sense if K-Line is explicitly required and other methods should not even be attempted.
Therefore, the checkbox must be disabled when attempting to communicate with an engine control unit that is connected via CAN bus. This is the case with the Tiguan.
 File size:  22.61 KB
 Viewed:  1753 times
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C: Raise Ride Height with Auto Leveling On-Board Diagnostics (OBD)
No new posts Tuning: Adapting via Channel On-Board Diagnostics (OBD)
No new posts "Service reminder function with VCDS" On-Board Diagnostics (OBD)
No new posts VCDS Probleme mit Anpassung "Einschaltverhalten" C On-Board Diagnostics (OBD)
