Polo 1.9 TDI: Exhaust, AGR Valve Problems
mozz
Post22-06-2003, 17:51    Subject: Polo 1.9 TDI: Exhaust, AGR Valve Problems Quote
Hello everyone!
Since my friend recently bought a Polo 1.9 SDI, the weekend seemed like a good opportunity to take a closer look at it.
1. The problem of returns always comes up; I thought that wouldn't be a problem, it's just a frame and a gear system! icon_evil.gif I thought!
After 2 hours of adjustment (at the long hole and on the rod!), things hadn't improved at all. So, I simply detached the rod and manually engaged the reverse gear, securing the whole thing with a thick cable tie.
After a few meters, the cable tie simply broke, and it popped out icon_eek.gif. It also pops out when you hold the shift lever in place!
Is the gearbox messed up? Can I disassemble it using standard tools? Can I adjust anything on the shift forks? - All other gears shift normally.
2. Problem: It was misfiring at full throttle, not severely, but it was misfiring! The error memory was empty.
First, I replaced the air filter, which actually didn't look too bad. Then, I removed this plastic cover from the intake manifold icon_eek.gif. What I saw underneath is indescribable; it was so covered in soot and oil residue, it's truly unbelievable (photos will follow, I only had an old-style camera). I immediately removed these strange plastic intake pipes, including the intake manifold, and saw that the 4th cylinder was completely blocked up to half its height (no exaggeration, you'll see the photos!).
I first soaked it in gasoline and then scraped it off, which was a real mess and it didn't come off easily!
I carefully removed the soot and ash from inside the head and vacuumed it out (of course, I made sure to keep each valve closed!).
"As a little extra, I added a Hohnstein to the intake manifold, then reassembled everything. (It's pointless to leave the plastic tubes exposed because the intake path would be too short, and it would lose almost all its power!)"
I used a piece of metal, cut to the size of the gasket, to seal the AGR valve, and surprisingly, it doesn't produce any soot anymore!
Translated on 11-10-2026, 16:05.
donalexo
Post22-06-2003, 19:00    Subject: Polo 1.9 TDI: Exhaust, AGR Valve Problems Quote
Hello mozz,
I'm really looking forward to seeing your pictures icon_eek.gif icon_eek.gif!!!
It would also be interesting to know the current mileage of the vehicle in order to put the deposits into perspective.
Equally interesting might be the type of oil used (viscosity class) and whether the engine was run partially or completely on biodiesel, or exclusively on diesel.
I'm still having trouble finding the right engagement point for the gears. Does the Polo have a synchronized reverse gear?
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 11-10-2026, 16:08.
mozz
Post23-06-2003, 10:37    Subject: Polo 1.9 TDI: Exhaust, AGR Valve Problems Quote
Hello!
110,000 km, 15W40 oil (Billigsdorf brand), has never seen biodiesel!
I don't know if the return process is synchronized, but I highly doubt it!
best regards, martin
Translated on 11-10-2026, 16:09.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo Starting Problems: 1.4L TDI PD Engine Diesel Engine Technology
No new posts VW Polo 1.4 TDI: Starting Issues, Misfires, Stalling Diesel Engine Technology
No new posts Audi A4 B7: Seat Occupancy Disable Coding On-Board Diagnostics (OBD)
No new posts Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Diesel Engine Technology
